    Problem with Weather Underground Forecast
    19 Posts 3 Posters 13.4k Views 3 Watching
    • Y Offline
      yawns Moderator @xeroxu
      @xeroxu
      No worries. So you don’t see anything of this module?
      X 1 Reply Last reply Reply Quote 0
      • X Offline
        xeroxu @yawns
        @yawns , Right I see nottthin, no Cuurent weather no forecast , nothing ,I dont know in the configuration options I´ve read about Locid, but i only find pws in my MMM-WunderGround.js. Is that the error
          Mykle1 Project Sponsor Module Developer @xeroxu
          @xeroxu said in Problem with Weather Underground Forecast:
          I see the locid reference in the config options, too, but I don’t think that’s your problem. I just used your pws: 'pws:IGELDERL219', in my WunderGround and it loads and displays just fine.
          • X Offline
            xeroxu @Mykle1
            @Mykle1 no chance it will no show up :…( where can I check my Weathe Underground API KEY, maybe is soething wrong with tthe API KEY, Whats the difference between API KEY and KEY ID? Sorry for my dumb questions,
              You can check your API key by going to https://www.wunderground.com/ and signing into your account. Once you’ve signed in, at the bottom of the page is Weather API. Click that! Your API KEY will be on the right side of the page, about 1/3 of the way down from the top. Copy and paste it into your config.js so it looks like this:
              apikey: '1234567891011',
              If you manually typed yours in you may have made a mistake and that’s all it takes to get no response from WonderGround.
              • X Offline
                xeroxu @Mykle1
                @Mykle1 This also not works, I regenerate the Key and with the New One also nothing. Í think I stay on the default weather modules .
                • X Offline
                  xeroxu @xeroxu
                  @Mykle1 There must be something wrong with the apikey. iI try it with the wuforecast module, and here also nothing show up.I have free Membership and choose the anvil plan. Have I to make big changes in the weatherunderground.js? I put in my API and Location pws.
                    You shouldn’t make any changes in the MMM-WunderGround.js file. Only make changes to the config.js file. If you have made changes to your MMM-WunderGround.js file then I suggest you revert them. If you can’t remember exactly what you changed then it would be easier for you to delete the entire folder and git clone https://github.com/RedNax67/MMM-WunderGround.git into your ~/MagicMirror/modules/ directory. Then add this to your config.js file, entering your WunderGround API key exactly and your pws
                    		disabled: false,
                        	module: 'MMM-WunderGround', // Just for forecast w/css entry
                        	position: 'top_right',
                            apikey: 'YOUR_API_KEY', // private; don't share!
                            pws: 'pws:YOUR_PWS', // Richmondtown Weather Station - Very Cool
                    		currentweather: 0,
                            coloricon: true,
                            hourly: '1',
                            fctext: '1',
                            fcdaycount: "10",
                            fcdaystart: "0",
                            hourlyinterval: "2",
                            hourlycount: "1",
                    		animationSpeed: 5000,
                            alerttime: 10000,
                            alerttruncatestring: "english:",
                        	roundTmpDecs: 0,
                        	UseCardinals: 1,
                        	layout: "vertical",
                    		windunits: "mph",
                        	sysstat: "0"
                    That should get you this:
                    • X Offline
                      xeroxu @Mykle1
                      @Mykle1 Thank you Mykle1,now it work,now i hve to make the colour and Icon configuration, the Earth did net not show up but thats no bi deal you helped me so much. I stil got a nothe Problem with the startuo I have to Fix , maybe Ill find the Answer here in the Forum.
                        You’re welcome. You are not going to see the earth as part of WunderGround. That is another module I am working on. It’s giving me some trouble right at the very end and I can’t seem to solve it.
                        You may also want to change this in your config.js file
                        currentweather: 0, Change the 0 to 1
                        What is your problem with startup?
                        • X Offline
                          xeroxu @Mykle1
                          @Mykle1 Each Time I starr reboot my Rasberry 3 chromium starts and says that he is not been close7 right before shutdown (cant explain it in english) but I found nothing in an atutostart.
                            @xeroxu
                            Are you running MM in Kiosk mode?
                            • X Offline
                              xeroxu @Mykle1
                              @Mykle1 where can I see that.sorry I saw it too late that you where on the chat
                                @xeroxu
                                Some people set up chromium to autostart in Kiosk mode. That is why I asked.
                                • X Offline
                                  xeroxu @Mykle1
                                  @Mykle1 Thank you you also ssolve this problem, It I s great to know that here are People that can help you so fast, :clap:
                                    @xeroxu
                                    You’re welcome. Glad I could help you. Have fun! :thumbsup_tone1:
