    Problem with Weather Underground Forecast
    19 Posts 3 Posters 13.9k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @xeroxu
      @xeroxu said in Problem with Weather Underground Forecast:
      where can I check my Weathe Underground API KEY, maybe is soething wrong with tthe API KEY,
      You can check your API key by going to https://www.wunderground.com/ and signing into your account. Once you’ve signed in, at the bottom of the page is Weather API. Click that! Your API KEY will be on the right side of the page, about 1/3 of the way down from the top. Copy and paste it into your config.js so it looks like this:
      apikey: '1234567891011',
      If you manually typed yours in you may have made a mistake and that’s all it takes to get no response from WonderGround.
      X 1 Reply Last reply Reply Quote 0
      • X Offline
        xeroxu @Mykle1
        @Mykle1 This also not works, I regenerate the Key and with the New One also nothing. Í think I stay on the default weather modules .
        • X Offline
          xeroxu @xeroxu
          @Mykle1 There must be something wrong with the apikey. iI try it with the wuforecast module, and here also nothing show up.I have free Membership and choose the anvil plan. Have I to make big changes in the weatherunderground.js? I put in my API and Location pws.
            You shouldn’t make any changes in the MMM-WunderGround.js file. Only make changes to the config.js file. If you have made changes to your MMM-WunderGround.js file then I suggest you revert them. If you can’t remember exactly what you changed then it would be easier for you to delete the entire folder and git clone https://github.com/RedNax67/MMM-WunderGround.git into your ~/MagicMirror/modules/ directory. Then add this to your config.js file, entering your WunderGround API key exactly and your pws
            		disabled: false,
                	module: 'MMM-WunderGround', // Just for forecast w/css entry
                	position: 'top_right',
                    apikey: 'YOUR_API_KEY', // private; don't share!
                    pws: 'pws:YOUR_PWS', // Richmondtown Weather Station - Very Cool
            		currentweather: 0,
                    coloricon: true,
                    hourly: '1',
                    fctext: '1',
                    fcdaycount: "10",
                    fcdaystart: "0",
                    hourlyinterval: "2",
                    hourlycount: "1",
            		animationSpeed: 5000,
                    alerttime: 10000,
                    alerttruncatestring: "english:",
                	roundTmpDecs: 0,
                	UseCardinals: 1,
                	layout: "vertical",
            		windunits: "mph",
                	sysstat: "0"
            That should get you this:
            • X Offline
              xeroxu @Mykle1
              @Mykle1 Thank you Mykle1,now it work,now i hve to make the colour and Icon configuration, the Earth did net not show up but thats no bi deal you helped me so much. I stil got a nothe Problem with the startuo I have to Fix , maybe Ill find the Answer here in the Forum.
                You’re welcome. You are not going to see the earth as part of WunderGround. That is another module I am working on. It’s giving me some trouble right at the very end and I can’t seem to solve it.
                You may also want to change this in your config.js file
                currentweather: 0, Change the 0 to 1
                What is your problem with startup?
                • X Offline
                  xeroxu @Mykle1
                  @Mykle1 Each Time I starr reboot my Rasberry 3 chromium starts and says that he is not been close7 right before shutdown (cant explain it in english) but I found nothing in an atutostart.
                    @xeroxu
                    Are you running MM in Kiosk mode?
                    • X Offline
                      xeroxu @Mykle1
                      @Mykle1 where can I see that.sorry I saw it too late that you where on the chat
                        @xeroxu
                        Some people set up chromium to autostart in Kiosk mode. That is why I asked.
                        • X Offline
                          xeroxu @Mykle1
                          @Mykle1 Thank you you also ssolve this problem, It I s great to know that here are People that can help you so fast, :clap:
                            @xeroxu
                            You’re welcome. Glad I could help you. Have fun! :thumbsup_tone1:
