    Help... I need help installing 3rd party modules to Magic Mirror 2
    26 Posts 4 Posters 20.5k Views 3 Watching
      joeytuck
      Has anyone run into the issue where you´ve installed MMM-WunderGround with your api key and pws and it just says
      ¨loading¨ on the magic mirror screen?
        Mykle1 Project Sponsor Module Developer @joeytuck
        @joeytuck
        That usually means one or more of the following:
        Your API key is entered incorrectly.
        Your API key is not valid.
        Your pws is entered incorrectly.
        Your pws is down. Choose another.
        I’ll test your pws on my machine if you tell me which one you are using.
          joeytuck @Mykle1
          @Mykle1 This might sound really ignorant but do I actually need PWS equipment to run this module? Can I not just receive and not transmit? My PWS is KTNMADIS13
            @joeytuck said in Help... I need help installing 3rd party modules to Magic Mirror 2:
            No, you don’t need your own PWS equipment. I meant the pws that you chose from WeatherUnderground. It would be cool to have your own though.
            The PWS that you gave me (KTNMADIS13) is either down, or not valid. I tested it and it does not work. As soon as I returned mine to my config, it fired right up.
            You can try mine as a test. This is the whole line from the config:
            pws: 'pws:KNYNEWYO103',
            In any case, you’ll have to choose another pws from the WunderMap at WeatherUnderground because yours is not working. If you can’t manage that then I can get one for you and test it. I would need the name of your country, city, town, neighborhood if that is the case. Or the name of your nearest airport. They all have weather stations.
              joeytuck
              I found a pws nearby and everything is working great now. Thanks for the help!!
                You’re welcome. :thumbsup:
