Noob current amd forecast weather
I’m new, i lost my weather when i changed it to the city i need it to read. Entered the id, the city name and the api, but it no longer shows up on my screen
Location ID from OpenWeatherMap This will override anything you put in location.
Leave blank if you want to use location.Make absolutely sure your API key is correctly entered. Alternately, you could post your config entry for weather here
Api was copied and pasted. Should be right.
Sorry. I’m extremely new. It says no helper found for current weather. Same for weather forecast
Got it to show up, but the time is wrong. Can i just eliminate the clock on the weather?
@relluts said in Noob current amd forecast weather:
That is not an error. The terminal is simply reporting that there is no helper file (ex: node_helper) associated with these modules. If they did have associated helper files, the terminal would have reported ex:
Module helper loaded: MMM-Cocktails
.If your mirror is displaying all other modules EXCEPT these two then the error lies within your config entry. Post your config entry for weather here so I can see it. X-out your API key first
That is the sunset time. After the sun sets, it will then display sunrise time.
