    Monthly Calendar
    43 Posts 24 Posters 59.3k Views 24 Watching
    • Sandy2503S
      Sandy2503
      Is there a bug or is there a problem with my pi and the mirror ?
      I have my mirror running 2 weeks without a restart of my pi and yesterday i see that your modul shows may 31st and not june 3rd.
      After a reboot of my pi your calendar shows the 3rd june …
      My Mirror and all other modules are up to date.
      Does anyone else have this problem too ???
      Sandy2503
      zdenekZ 1 Reply Last reply Reply Quote 0
      • zdenekZ
        zdenek @Sandy2503
        @Sandy2503 I’ve the same issue. I had to restart MM.
        Zdeněk
        • R
          rmrustem @zdenek
          @zdenek @Sandy2503 noticed that too. I’ve filed an issue to the module rep and suggested a fix. @KirAsh4 please take a look.
          https://github.com/KirAsh4/calendar_monthly/issues/2
          • KimzerK
            Kimzer @McSorley
            @McSorley said in Monthly Calendar:
            Great module. Thank you.
            I am looking for some help with the css. I am looking to change the entire table to a maximum width rather than the 100% of the “top_left” that I have it at just now. I am also looking for the weekends to have a background color of #606060
            Any help would be appreciated.
            Did you figure this out? Also interested in it :)
            • M
              McSorley @Kimzer
              @Kimzer said in Monthly Calendar:
              Being working on getting MMM-voice working recently. I’ll certainly come back to it though and let you know.
              @Kimzer I have been working on the custom.css for the monthly_calendar but it wasn’t a success. I used MMM-remote to hide what I had in the same position (top_left) and once they were hidden the calendar went down to a size that I was comfortable with. When I show it again, the size increases again. This is specific to showing the the default calendar because adding the timer has an ok width.
              Looks like its going to be changing the source CSS rather the custom CSS for monthly_calendar. The work continues…
              • N
                nitram
                Hi, I’m having trouble setting this module up. I want Monday, rather than Sunday, to be the first day of the week, but can’t work out where to specify that. Can anyone point me in the right direction? Cheers.
                • P
                  pjkoeleman @nitram
                  @nitram That is done depending on your country / language settings in the config.js file.
                  For me I use language : ‘nl’, the calendar starts on Monday. When I use ‘us’ as language it starts on Sunday.
                  • N
                    nitram @pjkoeleman
                    @pjkoeleman Many thanks! and thanks for the speedy reply too. That set me on the right track - I am in the UK, so I thought the default setting of language: “en” would have been fine. Just in case anyone else ever gets stuck like I did, switching that to “en-GB” fixed it.
                    • P
                      palmaren
                      Is it possible somehow to add week numbers to the monthly calendar? If so, how?
                      • P
                        pjkoeleman @palmaren
                        @palmaren The monthly Calendar has no option for week numbers. When you want that option ask the creator of the module.
                        The default Clock module has the option showWeek, when set to ‘true’ is shows the actual week number under the clock.
                        • P
                          palmaren @pjkoeleman
                          @pjkoeleman Thank you
                          • M
                            mirrX
                            Is this module still working? I´ve set up a new system and the MM gives me an error and can´t start with this module. I have uploaded in the correct dir and also set up the config file correctly. But it won´t work.
                            • P
                              pjkoeleman @mirrX
                              @mirrX said in Monthly Calendar:
                              Mine is, so have a look at your config and check for errors
                              • slametpsS
                                slametps
                                Mine is also with bug. It is not working well for new month. The calendar not showing nor highlight the 1st date. So, I must restart MM to make it works.
                                regards,
                                Slamet PS
                                • N
                                  Novais
                                  Having an issue displaying the calendar. Got the config set properly as far as i can tell just using the defaults and i have confirmed the config doesn’t contain any errors but the monthly calendar wont display, MM does start up with the other modules.
                                  • J
                                    Jonae @slametps
                                    @slametps i have the same issue, calendar not refreshing at month start. no fix jet?
                                    • BKeyportB
                                      BKeyport Module Developer @Jonae
                                      @jonae I had so many problems I wrote my own version. mmm-multimonth
                                      J 2 Replies Last reply Reply Quote 0
                                      • J
                                        Jonae @BKeyport
                                        @bkeyport said in Monthly Calendar:
                                        mmm-multimonth
                                        thanks, i will try that.
                                        • J
                                          Jonae @BKeyport
                                          @bkeyport
                                          Thanks for the tip, it is perfect, exactly what i need! i hope at the and of the month it will change :)
                                          • BKeyportB
                                            @jonae It’s been working perfectly for me for months. There’s been a couple of quirks, but I’m re-writing it from scratch to eliminate some underpinnings that are difficult. Please, let me know if it continues to work for you.
                                            • 2 / 3
