    Default current weather module help.
    4 Posts 2 Posters 3.1k Views 2 Watching
    • E
      Edswald
      Im trying to change the current weather module from Celsius to Fahrenheit and i dont think im doing right its showing degrees i think heres some screen shots . 0_1493249126177_2017-04-26-172005_1824x984_scrot.png 0_1493249136782_2017-04-26-172316_1824x984_scrot.png
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Edswald
        @Edswald
        It’s rather difficult to see those pictures. Could you copy and paste the config.js here?
        What I can see is that you posted a picture of the actual module and NOT the config.js file. It is recommended that you don’t make any changes to the actual module file.
        With that said, go to your config.js file and make sure you have units: "imperial", for Fahrenheit
        • E
          Edswald @Mykle1
          @Mykle1 said in Default current weather module help.:
          imperial
          Thank you that did the trick :)
          • Mykle1M
            @Edswald said in Default current weather module help.:
            You’re welcome! :fireworks:
