    Owncloud integration - Birthday Calendar
    owncloudbirthdaycalendar
    6 Posts 2 Posters 3.5k Views 2 Watching
      STH
      Re: OwnCloud integration
      Owncloud calendar integration works fine except for the birthday calendar. Magic Mirror calendar module is not showing the birthdays.
      In the Owncloud Birthday calendar .ics file I found, that the birthday dates are stored with the birth year.
      Example for 22MAY1965
      DTSTART;VALUE=DATE:19650521
      DTEND;VALUE=DATE:19650522
      I assume that the calendar module is only showing entries of the current year.
      Is there a workaround or module existing that could help here?
      Thank you in advance.
        Mykle1 Project Sponsor Module Developer @STH
        @STH said in Owncloud integration - Birthday Calendar:
        If it’s a local ics file (or you can download and edit it and save it as a local file) you can change the dates to:
        DTSTART;VALUE=DATE:20170521
        DTEND;VALUE=DATE:20170522
        Then have the calendar module call the local file via your config.js. I’ve done this with other calendars. I think the calendar module doesn’t like dates before 1970.
        Good luck!
          STH
          Hi Mykle1,
          that is a good idea, thank you! I have a workaround now, but I need to change the files every year :(.
          You can download the Birthday .ics from Owncloud and save it localy.
          In the config.js file I changed the calendar url to work with local .ics file:
          url: ‘webcal://localhost:8080/modules/Birthdays/geburtstage_2017.ics’, //Use a local file
          Then I wrote a small python script (for Windows) to change the year of the .ics file, as you proposed above, and it worked.
          If anyone is interessted you can use my python script below. It will open the “geburtstage.ics” file which needs to be located in the same folder as the python script. The script will ask for the year you want to change to and will create a new ics file containing the changed birthday years.
          //your code here
          **Birthday_ICS.py**
          #Ask for the year you want to change to
          year = input("Please enter the year you want to change to: ")
          fobj_in = open("geburtstage.ics", "r") #Source file
          fobj_out = open("geburtstage_" + year + ".ics","w") #Output file
          for line in fobj_in:
          	if line.find("DTSTART") > -1 or line.find("DTEND") > -1: #Change year of DTSTART oder DTEND lines
          		#Format of the string: DTSTART;VALUE=DATE:19650521	#DTEND;VALUE=DATE:19650522
          		split=line.split(":")
          		helpline=split[0]+":"+year+split[1][4:]
          		fobj_out.write(helpline)
          	else: #Change nothing, just copy the line
          		fobj_out.write(line)
          print("Complete!") #Let me know when you are finished
          #Close the documents
          fobj_in.close()
          fobj_out.close()
            Then I wrote a small python script to change the year of the .ics file, as you proposed above, and it worked.
            Oh, well done! :thumbsup:
              STH
              This post is deleted!
                STH
                Here is the carefree package :)
                The python script will open the Birthday.ics file directly from your Owncloud, change the year automaticly and safe the output file at a fixed location. Python “Requests” library is used to connect to your Owncloud.
                This script works in linux. The script above was only working in MS Windows.
                The script can be run by cron e.g. every 30min so you will see updates and you don’t have to worry about the next year ;)
                #!/usr/bin/env python
                # -*- coding: utf-8 -*-
                # Time functions for current year
                import time
                from time import localtime, strftime
                # Use Requests lib to download Owncloud Birthday calendar .ics file
                import requests #http://docs.python-requests.org/en/master/
                year = strftime("%Y", localtime()) #Get the current year
                try: #Catch errors
                	url = 'https://YOUR_URL/remote.php/dav/calendars/USER/BIRTHDAYCALENDAR?export' # Url to your Owncloud Birthday caldender .ics file. Replace parts written in capitals
                	download = requests.get(url, auth=('USER', 'PASS')) #Replace parts written in capitals
                	fobj_in= download.text.split("\n") #Split file
                	fobj_out = open("/home/pi/MagicMirror/modules/Birthdays/geburtstage.ics","w") #Output file
                			fobj_out.write(helpline.encode('utf-8')+"\n")
                			fobj_out.write(line.encode('utf-8')+"\n")
                	fobj_out.close()
                	download.close()
                except requests.exceptions.RequestException as e:  # This is the correct syntax
                    print(e)
