    My display so far...
    Scheduled Pinned Locked Moved Showcase
    66 Posts 18 Posters 90.0k Views 22 Watching
    • rudibaraniR Offline
      rudibarani Project Sponsor @j.e.f.f
      @j.e.f.f It worked before your update and I did not change anything.
      The relevant part is:
      			module: 'MMM-MyWeather',
      			position: 'top_center',
      				apikey: '###', // private; don't share!
      				pws: 'pws:IBRAUNSC93',
      				units: 'metric',
      				coloricon: true,
      				fcdaycount: "3",
      				fcdaystart: "0",
      				lang: 'de',
      				fctext: '1',
      				scaletxt: '0',
      				daily: '1',
      				hourly: '1',
      				hourlyinterval: "3",
      				hourlycount: "3",
      				fade: false,
      				fadepoint: '0.75',
      				initialLoadDelay: 1000,
      				alerttime: 10000,
      				alerttruncatestring: "english:",
      				roundTmpDecs: 1,
      				UseCardinals: 1,
      				windunits: 'bft',
      				layout: "vertical",
      				iconset: 'colourful',
      				currentweather: 1, // 0 to hide
      				currentweatherdetails: 0,
      				forecasttable: 1, // 0 to hide
      				forecasttablecolumnheadericons: 0,
      				forecasttableheadertext: "Home",
      				sysstat: 0
      J 2 Replies Last reply Reply Quote 0
        j.e.f.f Project Sponsor Module Developer @rudibarani
        @rudibarani thanks. I’ll take a look tonight when I get home from work.
          @rudibarani Ok try pulling the latest commit. I indeed broke the default timeFormat setting. I didn’t notice because my config was using an explicit configuration option.
          rudibaraniR 1 Reply Last reply Reply Quote 0
            @j.e.f.f Now its working again, but the timeformat still does not show up in the 24h format:
            Thanks a lot and greetings from Germany.
            • brandongomezB Offline
              brandongomez
              I’m sure there’s a way to do this in css but not sure how. I want to make the icon and temperature smaller.
                @rudibarani in your config, set the timeFormat to HH:mm and you shoudl see 24-hour format.
                I just tried this. My config looks like this:
                        position: 'top_right',
                        classes: 'default everyone',
                          apikey: '...', // private; don't share!
                          pws: 'pws:IONTORON421', //Toronto Beaches
                          units: 'metric',
                          // other configs omitted for clarity
                          timeFormat: 'HH:mm',  //Set this here
                And it looks like this:
                  j.e.f.f Project Sponsor Module Developer @brandongomez
                  @brandongomez You can target both of these in CSS as follows:
                  /* Icon */
                  .MMM-MyWeather .currentWeatherIconWrapper .currentWeatherIcon {
                    max-width: 140px;
                    max-height: 140px; /* play with these two values to get the size you want */
                  /* temperature text */
                  .MMM-MyWeather div.large span.bright {
                    font-size: 65px;
                    line-height: 65px; /* play with these two numbers to adjust text size */
                  brandongomezB 1 Reply Last reply Reply Quote 0
                    @j.e.f.f Ah - you are using the moments-timeformat. Now it works :)
                    I was confused, as the timeformat in the config.js was either “12” or “24”.
                    Thanks for the clarification!
                      @rudibarani Yeah I like using the Moment.js format since it gives you the ultimate flexibility with how you want to display time.
                      Glad it’s working for you now! :)
                        brandongomez @j.e.f.f
                        @j.e.f.f Thanks for the quick response!
                        • 6
                        • 7
                        • 5 / 7
