    Newsfeed and Calendar not loading
    11 Posts 5 Posters 8.2k Views 5 Watching
    • V Offline
      vindoan @bhepler
      @bhepler Yep! I have full access to the internet, I can even access the websites I have in the config file
      • V Offline
        vindoan @Mykle1
        @Mykle1 Thanks for the tip, I already tried http://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml too and that didnt see to work either.
          Mykle1 Project Sponsor Module Developer @vindoan
          @vindoan
          Well, this is the default NY Times url, which is somewhat different from the url you posted above.
          http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
          		module: "newsfeed",
          		position: "bottom_bar",
          			feeds: [
          					title: "New York Times",
          				showSourceTitle: true,
          				showPublishDate: true
          • V Offline
            vindoan @Mykle1
            @Mykle1 if you follow the link, the URL changes and I copied that one. I tried both the default one and the one posted and both didnt work at all.
            • V Offline
              vindoan
              Im not sure if this is important or not. Im on nodejs version 0.10.29 (stable). There is a more current version but for some reason its not updating to it. Im not sure if thats the issue.\
              • V Offline
                vindoan
                I FIGURED IT OUT, nodejs had to at least 0.10.40 to work with the modules, had to follow this post to force update it https://raspberrypi.stackexchange.com/questions/48303/install-nodejs-for-all-raspberry-pi
                0 1 Reply Last reply Reply Quote 1
                • 0 Offline
                  0livia @vindoan
                  @vindoan Hi thanks for your help, to upgrading to the latest nodejs solved it.
                  I have a jessie box so i upgraded a different way what you linked for the Pi.
                  So here it is if using a linux box instead of Pi
                  sudo npm cache clean -f /cleanup the package
                  sudo npm install -g n /you’ll need npm’s n module
                  sudo n stable
                  node -v /you should have the latest nodejs
