    Newsfeed and Calendar not loading
    11 Posts 5 Posters 7.7k Views 5 Watching
    • L Offline
      Lausbuab1
      @vindoan I have the same problem (RP0) in serveronly mode.
      If the newsfeed is broken, that is okay, but my calendar (shared iCloud calendar) is always in the state of “loading”.
      Does anyone know a solution?
      • V Offline
        vindoan @bhepler
        @bhepler Yep! I have full access to the internet, I can even access the websites I have in the config file
        • V Offline
          vindoan @Mykle1
          @Mykle1 Thanks for the tip, I already tried http://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml too and that didnt see to work either.
            Mykle1 Project Sponsor Module Developer @vindoan
            @vindoan
            Well, this is the default NY Times url, which is somewhat different from the url you posted above.
            http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
            		module: "newsfeed",
            		position: "bottom_bar",
            			feeds: [
            					title: "New York Times",
            				showSourceTitle: true,
            				showPublishDate: true
            • V Offline
              vindoan @Mykle1
              @Mykle1 if you follow the link, the URL changes and I copied that one. I tried both the default one and the one posted and both didnt work at all.
              • V Offline
                vindoan
                Im not sure if this is important or not. Im on nodejs version 0.10.29 (stable). There is a more current version but for some reason its not updating to it. Im not sure if thats the issue.\
                • V Offline
                  vindoan
                  I FIGURED IT OUT, nodejs had to at least 0.10.40 to work with the modules, had to follow this post to force update it https://raspberrypi.stackexchange.com/questions/48303/install-nodejs-for-all-raspberry-pi
                  0 1 Reply Last reply Reply Quote 1
                  • 0 Offline
                    0livia @vindoan
                    @vindoan Hi thanks for your help, to upgrading to the latest nodejs solved it.
                    I have a jessie box so i upgraded a different way what you linked for the Pi.
                    So here it is if using a linux box instead of Pi
                    sudo npm cache clean -f /cleanup the package
                    sudo npm install -g n /you’ll need npm’s n module
                    sudo n stable
                    node -v /you should have the latest nodejs
