    Cannot get MM to install on a fresh jessie install.
    5 Posts 2 Posters 3.5k Views 2 Watching
    • E Offline
      EdChamberlain
      Pretty much the title, Im using a fresh install of jessie (with Pixel) on a raspberry pi 3. Using the line of code from front page causes it to install then using npm start brings up errors.
      Debug file: https://pastebin.com/gUCfw1Au
        Mykle1 Project Sponsor Module Developer @EdChamberlain
        @EdChamberlain
        This might be obvious, but are you running npm start in the MagicMirror directory?
        • E Offline
          EdChamberlain
          Judging by the fact I didn’t realise that was a thing… I’m going to guess I’m not!
          I assume the fix is easy, just ‘cd’ to the directory and then run ‘npm start’?
            @EdChamberlain said in Cannot get MM to install on a fresh jessie install.:
            Yes, open a new terminal
            Type cd MagicMirror and Enter
            Type npm start and Enter
            Let me know how you make out. Good luck.
            • E Offline
              EdChamberlain
              Will give it a go when I’m back home on weds! Cant believe I didn’t think of that.
