    [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
    602 Posts 67 Posters 2.1m Views 68 Watching
    • evroomE Online
      evroom
      And from your config.js the moduleWidth, moduleHeight and the width and height from the stream, please.
      MagicMirror version: 2.35.0
      Test environment:
      MagicMirror version: 2.36.0-develop
        jngo @evroom
        @evroom
        from the config.js file:
        moduleWidth: 640
        moduleHeight: 360
        The wdth and height from the stream is also 640 x 360 px
        Is this you are looking for?
        • evroomE Online
          evroom
          @jngo said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
          Yes, but cannot promise anything :-)
          Cannot get the module to run on my MM.
          Most probably a new install will work miracles, but I do not want to spend too much time /effort on it.
          Test environment:
            jngo @evroom
            @evroom
            Yeah, anything would help but i totally understand that you have your MM working now and certainly do not want to mess that up!
            If you could point me what code and where to look at, I may be able to play along… Right now, I have no idea what to adjust…
            Thank you
            • evroomE Online
              evroom
              @jngo
              One more question: what is the size of your display in pixels ?
              Test environment:
                jngo @evroom
                @evroom
                My screen size is 1920 x 1080 pixel
                • evroomE Online
                  evroom
                  @jngo
                  If I understand omxplayer correct and did the calculations right, then this is what you see.
                  Basically you are seeing a streaming window of just 334x242.
                  I do not know where the model window is, but I suppose it is on the same location.
                  Test environment:
                    jngo @evroom
                    @evroom
                    You are genius… Yes, the square that you draw is what I am seeing now…
                    Is there a way to move the whole thing to the right and lower a bit?
                    Thank you again
                    • evroomE Online
                      evroom
                      If you edit your custom.css file and restart MM then you can see the module position better:
                      $ vi /home/pi/MagicMirror/css/custom.css
                      .MMM-RTSPStream .innerWrapper {
                        //border-style: none;
                        border: 1px solid red;
                      You can use the editor of your liking of course.
                      Btw, I see (wrong ??) fixed values MMM-RTSPStream.css:
                      $ cat /home/pi/MagicMirror/modules/MMM-RTSPStream/MMM-RTSPStream.css
                        position: relative;
                        width: 352px; /* Video width + 2*border + 2*padding */
                        height: 242px;
                        border: 1px solid white;
                        /*float: left;*/
                        display: inline-block;
                        text-align: center;
                        margin: 2px;
                      So, whatever your settings are in config.js, the result will be the same.
                      I would try to change it to:
                      width: 658px; /* Video width + 2*border + 2*padding */
                      height: 360px;
                      And then check pm2 logs for the --win settings it results to.
                      Or even comment it out and see what happens:
                      //  width: 352px; /* Video width + 2*border + 2*padding */
                      //  height: 242px;
                      Let me know the result and the pm2 log output (–win part).
                      Test environment:
                        jngo @evroom
                        @evroom
                        I adjusted the width and height in the css file like you instructed and restart MM. The result is that, the video stream window indeed gets bigger (W 658 x H 360) now but it does not really “move” to the right of the screen. Plus, at this size of the width, it becomes too wide that it covers the complimentary wording partially…
                        the “-win” is now “1127, 512, 1767, 872”
                        And with the “red” border of the stream window enabled, I can see that the red border frame aligned perfectly with the right-side of the screen however, the video feed itself does not fit within this red frame but is “top-left” off from the red frame
                        Any idea how I can move the video feed to fit the red border frame and, do not cover the complimentary wordings?
                        Thank you really, for your helps
                        evroomE 2 Replies Last reply Reply Quote 0
                        • C Offline
                          costascontis
                          how can i test with omxplayer that my camera link is playing ok?With vlc my link is ok but using omxplayer with the module i get nothing,empty box.
                            jngo @costascontis
                            @costascontis
                            You can use the command
                            pm2 status
                            to check if it’s working.
                            Also, in the config.js file, you need to specify the omxplayer instead of vlc
                            localPlayer: ‘omxplayer’,
                            • evroomE Online
                              evroom
                              @costascontis said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                              You can test it standalone with:
                              $ omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 640 360" rtsp://[rrtsp_uri]
                              PS
                              Now the coordinates confuse me, but make sense (X-axis, Y-axis)
                              —win x1,   y1 , x2,   y2
                              —win 0,    0,   640,  360
                              Size of video stream:
                              (x2 - x1) x (y2 - y1) =  640 x 360
                              Test environment:
                              • evroomE Online
                                evroom @jngo
                                Could you briefly test it with width and height commented out ?
                                //  height: 242px;
                                Just to see what is happening then.
                                Test environment:
                                • evroomE Online
                                  evroom @jngo
                                  I would try this:
                                  Change the config.js:
                                  moduleWidth: 468,
                                  moduleHeight: 253,
                                          width: 450,
                                          height: 253,
                                  Change the MMM-RTSPStream.css:
                                  width: 468px; /* Video width + 2*border + 2*padding */
                                  height: 253px;
                                  Test environment:
                                    jngo @evroom
                                    @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                    I would try this:
                                    moduleWidth: 468,
                                    moduleHeight: 253,
                                            width: 450,
                                            height: 253,
                                    height: 253px;
                                    So I followed what you recommended: width 468 and height 253. The result is still the same: The red border frame is perfectly aligned with the right size of the screen (in bottom-right setup). But the live video stream window (468x253) is located more to the “left” and higher than the red frame
                                    This thing really drives me nuts…gr.gr…gr…
                                    • evroomE Online
                                      evroom
                                      @jngo
                                      So if the video area matches the module area (the red border in this moment) then it is okay for you?
                                      Could you still till try this?
                                      „Could you briefly test it with width and height commented out ?“
                                      Test environment:
                                        jngo @evroom
                                        @evroom
                                        I tried to comment out the W & H, it still did the same issue. I restart the Raspberry and re-install the module, it gets better a bit: Now the right-edge of the stream video is aligned with the weather module, which is what I want to. However, the stream module is still off compare to the red border frame. But I guess it is the best it could get so I set the border to “0” (no border any more). And it is now the closest that I could get!
                                        One last thing I want to ask you as well: How do I increase the size of the fonts used in the MM? Which lines of code in the “main.css” of the MagicMirror should I look at? My purpose is I want to make the text in the clock, weather, calendar appear bigger a little bit so that we can all see those info from a few feet away.
                                        Thank you very much for your patience and helps, I really appreciated it.
                                        • evroomE Online
                                          evroom
                                          Actually I was interested in the --win coordinates from the pm2 log in this case.
                                          If the same, then it means that uncommented is right and the values are being taken from the config.js parameters.
                                          It looks it can be uncommented.
                                          One last suggestion:
                                          Either in the MM-RTSPStream.css or your /home/pi/MagicMirror/css/custom.css:
                                            position: relative;
                                            width: 468px; /* Video width + 18px
                                            height: 253px;
                                            border-style: none;
                                            text-align: center;
                                          Regarding
                                          you will have to ask this in a separate topic.
                                          Best is to change things in the custom.css.
                                          I only made changes regarding the width of some regions.
                                          Test environment:
                                            Duh3c
                                            This post is deleted!
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 30
                                            • 31
                                            • 14 / 31
