    602 Posts 67 Posters 2.4m Views 68 Watching
      jngo @evroom
      @evroom
      I adjusted the width and height in the css file like you instructed and restart MM. The result is that, the video stream window indeed gets bigger (W 658 x H 360) now but it does not really “move” to the right of the screen. Plus, at this size of the width, it becomes too wide that it covers the complimentary wording partially…
      the “-win” is now “1127, 512, 1767, 872”
      And with the “red” border of the stream window enabled, I can see that the red border frame aligned perfectly with the right-side of the screen however, the video feed itself does not fit within this red frame but is “top-left” off from the red frame
      Any idea how I can move the video feed to fit the red border frame and, do not cover the complimentary wordings?
      Thank you really, for your helps
      evroomE 2 Replies Last reply
        costascontis
        how can i test with omxplayer that my camera link is playing ok?With vlc my link is ok but using omxplayer with the module i get nothing,empty box.
        J 1 Reply Last reply
          jngo @costascontis
          @costascontis
          You can use the command
          pm2 status
          to check if it’s working.
          Also, in the config.js file, you need to specify the omxplayer instead of vlc
          localPlayer: ‘omxplayer’,
          • evroomE
            evroom
            @costascontis said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            You can test it standalone with:
            $ omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 640 360" rtsp://[rrtsp_uri]
            PS
            Now the coordinates confuse me, but make sense (X-axis, Y-axis)
            —win x1,   y1 , x2,   y2
            —win 0,    0,   640,  360
            Size of video stream:
            (x2 - x1) x (y2 - y1) =  640 x 360
            MagicMirror version: 2.37.0
            • evroomE
              evroom @jngo
              @jngo said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              Could you briefly test it with width and height commented out ?
              //  width: 352px; /* Video width + 2*border + 2*padding */
              //  height: 242px;
              Just to see what is happening then.
              • evroomE
                evroom @jngo
                I would try this:
                Change the config.js:
                moduleWidth: 468,
                moduleHeight: 253,
                        width: 450,
                        height: 253,
                Change the MMM-RTSPStream.css:
                width: 468px; /* Video width + 2*border + 2*padding */
                height: 253px;
                  jngo @evroom
                  @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                  I would try this:
                  moduleWidth: 468,
                  moduleHeight: 253,
                          width: 450,
                          height: 253,
                  height: 253px;
                  So I followed what you recommended: width 468 and height 253. The result is still the same: The red border frame is perfectly aligned with the right size of the screen (in bottom-right setup). But the live video stream window (468x253) is located more to the “left” and higher than the red frame
                  This thing really drives me nuts…gr.gr…gr…
                  • evroomE
                    evroom
                    @jngo
                    So if the video area matches the module area (the red border in this moment) then it is okay for you?
                    Could you still till try this?
                    „Could you briefly test it with width and height commented out ?“
                      jngo @evroom
                      @evroom
                      I tried to comment out the W & H, it still did the same issue. I restart the Raspberry and re-install the module, it gets better a bit: Now the right-edge of the stream video is aligned with the weather module, which is what I want to. However, the stream module is still off compare to the red border frame. But I guess it is the best it could get so I set the border to “0” (no border any more). And it is now the closest that I could get!
                      One last thing I want to ask you as well: How do I increase the size of the fonts used in the MM? Which lines of code in the “main.css” of the MagicMirror should I look at? My purpose is I want to make the text in the clock, weather, calendar appear bigger a little bit so that we can all see those info from a few feet away.
                      Thank you very much for your patience and helps, I really appreciated it.
                      • evroomE
                        evroom
                        Actually I was interested in the --win coordinates from the pm2 log in this case.
                        If the same, then it means that uncommented is right and the values are being taken from the config.js parameters.
                        It looks it can be uncommented.
                        One last suggestion:
                        Either in the MM-RTSPStream.css or your /home/pi/MagicMirror/css/custom.css:
                        .MMM-RTSPStream .innerWrapper {
                          position: relative;
                          width: 468px; /* Video width + 18px
                          height: 253px;
                          border-style: none;
                          display: inline-block;
                          text-align: center;
                        Regarding
                        you will have to ask this in a separate topic.
                        Best is to change things in the custom.css.
                        I only made changes regarding the width of some regions.
                          Duh3c
                            benpoe
                            Some tips/improvements.
                            I’ve disabled the sound in the omx-stream by adding the arguments “-n”,“-1”, in the node_helper.js
                             payload.forEach(s => {
                                        var args = ["--live", "--video_queue", "4", "--fps", "30","-n","-1",
                                            this.config[s.name].url
                            I had problems with the omx-streams (i have three) not restarting correctly. So instead of stopping the processes and then starting, i’ve changed the command to restart.
                                            for (var proc in list) {
                                                if ("name" in list[proc] && namesM.indexOf(list[proc].name) > -1) {
                                                    if ("status" in list[proc].pm2_env && list[proc].pm2_env.status === "online") {
                                                        console.log(`PM2: ${list[proc].name} already running. Stopping old instance...`);
                            //                            pm2.stop(list[proc].name, errCB);
                                                        pm2.restart(list[proc].name, errCB);
                              Smotx
                              what is the right process to follow for a new installation? the github page or the explanation on page 17?
                              • twosquirrelsT
                                twosquirrels
                                I have RTSP enabled on my Wyze camera, but nothing displays with this module. The URL it provides is in the format:
                                rtsp://USER:PASSWORD@ADDRESS/live
                                I noticed that it doesn’t provide the actual file extension such as .mov so I’m wondering if that’s preventing this from working for me.
                                evroomE 1 Reply Last reply
                                • evroomE
                                  evroom @twosquirrels
                                  @twosquirrels
                                  Can you try this ?
                                  $ omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 480 320" rtsp://USER:PASSWORD@ADDRESS/live
                                  To see if it works standalone.
                                  I forgot if a license is needed for the camera stream, but to know if a license is present:
                                  $ vcgencmd codec_enabled MPG2
                                  • 0
                                    0YXmEQ
                                    Started at page 17 and running on the latest develop branch and trying to use omxplayer. Open GL fake is running with 128. Using VLC on a windows PC I’m able to get the RTSP stream working.
                                    In VLC I chose network stream use the URL
                                    rtsp://admin:******@192.168.200.4:554/cam/realmonitor?channel=1&subtype=0
                                    I do have select ‘Active Transcoding’ and use Video -H.264 + MP3 (MP4)
                                    When I run it on MagicMirror I get this:
                                    It’s an Amcrest Camera. I’m able to test using the “Big Buck Bunny” and that works great.
                                    0 1 Reply Last reply
                                    • 0
                                      0YXmEQ @0YXmEQ
                                      @0YXmEQ
                                      Update: This issue appears specific to my Amcrest Camera. I’m able to stream my Arecont Camera.
                                      On that not my Arecont Camera has 4 lenses. How could have to RTSP stream windows side by side? Each showing one lense with no border?
                                      rtsp://192.168.200.10/h264.sdp2?res=full&doublescan=0&ssn=466
                                      rtsp://192.168.200.10/h264.sdp3?res=full&doublescan=0&ssn=467
                                        SH20192 @0YXmEQ
                                        Im trying to use the VLC player on the “develop” branch code. Im running into issues with VLC. If I set my localplayer to omxplayer then everything works fine. If I change it to “vlc” I dont not get a picture. Is there something else I need to change for it to work? Thanks!
                                          SH20192 @SH20192
                                          @SH20192 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                          disregard. didnt realize I needed to reload the node modules. seems to have fixed the issue.
                                          • Cr4z33C
                                            Cr4z33
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 30
                                            • 31
                                            • 14 / 31
