    602 Posts 67 Posters 2.3m Views 68 Watching
    • evroomE
      evroom
      @jngo
      So if the video area matches the module area (the red border in this moment) then it is okay for you?
      Could you still till try this?
      „Could you briefly test it with width and height commented out ?“
      MagicMirror version: 2.37.0
        jngo @evroom
        @evroom
        I tried to comment out the W & H, it still did the same issue. I restart the Raspberry and re-install the module, it gets better a bit: Now the right-edge of the stream video is aligned with the weather module, which is what I want to. However, the stream module is still off compare to the red border frame. But I guess it is the best it could get so I set the border to “0” (no border any more). And it is now the closest that I could get!
        One last thing I want to ask you as well: How do I increase the size of the fonts used in the MM? Which lines of code in the “main.css” of the MagicMirror should I look at? My purpose is I want to make the text in the clock, weather, calendar appear bigger a little bit so that we can all see those info from a few feet away.
        Thank you very much for your patience and helps, I really appreciated it.
        • evroomE
          evroom
          @jngo said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
          Actually I was interested in the --win coordinates from the pm2 log in this case.
          If the same, then it means that uncommented is right and the values are being taken from the config.js parameters.
          It looks it can be uncommented.
          One last suggestion:
          Either in the MM-RTSPStream.css or your /home/pi/MagicMirror/css/custom.css:
          .MMM-RTSPStream .innerWrapper {
            position: relative;
            width: 468px; /* Video width + 18px
            height: 253px;
            border-style: none;
            display: inline-block;
            text-align: center;
          Regarding
          you will have to ask this in a separate topic.
          Best is to change things in the custom.css.
          I only made changes regarding the width of some regions.
            Duh3c
              benpoe
              Some tips/improvements.
              I’ve disabled the sound in the omx-stream by adding the arguments “-n”,“-1”, in the node_helper.js
               payload.forEach(s => {
                          var args = ["--live", "--video_queue", "4", "--fps", "30","-n","-1",
                              this.config[s.name].url
              I had problems with the omx-streams (i have three) not restarting correctly. So instead of stopping the processes and then starting, i’ve changed the command to restart.
                              for (var proc in list) {
                                  if ("name" in list[proc] && namesM.indexOf(list[proc].name) > -1) {
                                      if ("status" in list[proc].pm2_env && list[proc].pm2_env.status === "online") {
                                          console.log(`PM2: ${list[proc].name} already running. Stopping old instance...`);
              //                            pm2.stop(list[proc].name, errCB);
                                          pm2.restart(list[proc].name, errCB);
                Smotx
                what is the right process to follow for a new installation? the github page or the explanation on page 17?
                • twosquirrelsT
                  twosquirrels
                  I have RTSP enabled on my Wyze camera, but nothing displays with this module. The URL it provides is in the format:
                  rtsp://USER:PASSWORD@ADDRESS/live
                  I noticed that it doesn’t provide the actual file extension such as .mov so I’m wondering if that’s preventing this from working for me.
                  • evroomE
                    evroom @twosquirrels
                    @twosquirrels
                    Can you try this ?
                    $ omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win "0 0 480 320" rtsp://USER:PASSWORD@ADDRESS/live
                    To see if it works standalone.
                    I forgot if a license is needed for the camera stream, but to know if a license is present:
                    $ vcgencmd codec_enabled MPG2
                    • 0
                      0YXmEQ
                      Started at page 17 and running on the latest develop branch and trying to use omxplayer. Open GL fake is running with 128. Using VLC on a windows PC I’m able to get the RTSP stream working.
                      In VLC I chose network stream use the URL
                      rtsp://admin:******@192.168.200.4:554/cam/realmonitor?channel=1&subtype=0
                      I do have select ‘Active Transcoding’ and use Video -H.264 + MP3 (MP4)
                      When I run it on MagicMirror I get this:
                      It’s an Amcrest Camera. I’m able to test using the “Big Buck Bunny” and that works great.
                      0 1 Reply Last reply Reply Quote 0
                      • 0
                        0YXmEQ @0YXmEQ
                        @0YXmEQ
                        Update: This issue appears specific to my Amcrest Camera. I’m able to stream my Arecont Camera.
                        On that not my Arecont Camera has 4 lenses. How could have to RTSP stream windows side by side? Each showing one lense with no border?
                        rtsp://192.168.200.10/h264.sdp2?res=full&doublescan=0&ssn=466
                        rtsp://192.168.200.10/h264.sdp3?res=full&doublescan=0&ssn=467
                          SH20192 @0YXmEQ
                          Im trying to use the VLC player on the “develop” branch code. Im running into issues with VLC. If I set my localplayer to omxplayer then everything works fine. If I change it to “vlc” I dont not get a picture. Is there something else I need to change for it to work? Thanks!
                            SH20192 @SH20192
                            @SH20192 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                            disregard. didnt realize I needed to reload the node modules. seems to have fixed the issue.
                            • Cr4z33C
                              Cr4z33
                                jimmysmalls
                                Hey guys I’m running into trouble getting my Reolink cameras to show. I can open the stream in vlc player but just get an outlined box on my magicmirror. Any idea what I’m doing wrong? It’s probably something simple. Here’s my code minus the username and password of course :)
                                    module: "MMM-RTSPStream",
                                    position: "middle_center",
                                    header: "Front",
                                        autoStart: true,
                                        rotateStreams: false,
                                        rotateStreamTimeout: 10,
                                        moduleWidth: 354,
                                        moduleHeight: 240,
                                        localPlayer: 'omxplayer',
                                        remotePlayer: 'none',
                                        showSnapWhenPaused: true,
                                        remoteSnaps: true,
                                        stream1: {
                                            url: 'rtsp://user:pass@192.168.1.42:554//h264Preview_01_main',
                                            frameRate: '10',
                                            snapshotType: 'url',
                                            snapshotRefresh: 10,
                                            width: undefined,
                                            height: undefined,
                                • BKeyportB
                                  BKeyport Module Developer
                                  Check your IP string here: https://www.ispyconnect.com/man.aspx?n=Reolink mine uses h264Preview_01_sub for instance.
                                  I do use ffmpeg for the picture as it seems to work better for my system - I have an RLC-410.
                                  		position: "top_center",
                                  			autoStart: true,
                                  			moduleWidth: 640,
                                  			moduleHeight: 360,
                                  			localPlayer: 'ffmpeg',
                                  			remotePlayer: 'ffmpeg',
                                  			showSnapWhenPaused: false,
                                  			remoteSnaps: false,
                                  			omxRestart: 2,
                                  			stream1: {
                                  				url: 'rtsp://user:pass@FrontCam/h264Preview_01_sub',
                                  				protocal: "ucp",
                                  				width: 640,
                                  				height: 360,
                                  				ffmpegPort: 9999,
                                  				shutdownDelay: 0,
                                  Oh, and if you want to get rid of the white box (I find it distracting) in your custom.css file:
                                  border: 0;
                                    jimmysmalls @BKeyport
                                    @BKeyport
                                    Thanks for the link. Mine is the RLC-420 and says h264Preview_01_main. I even tried just using your code and replacing with my credentials but all I can get is a gray box. Strange thing is I can open main or sub in vlc just fine. I thought this was going to be an easy project haha
                                    • BKeyportB
                                      try ffmpeg, might be something wrong with the main player.
                                        @BKeyport
                                        I did actually. It shows a pause button when I hover over it but just gives me a black screen. :(
                                        • BKeyportB
                                          hmmm. have you tried changing to “sub” rather than “main”? The “sub” feed is the lower quality feed, and better suited for RPI…
                                            bill22
                                            Hey Guys,
                                            i face some problems to get the RTSP module to work with my stream and wonder if @shbatm or someone else can help.
                                            Objective is to use the live dvb-c feed provided by an AVM FritzBox 6490 cable router to display the tv program on the MagicMirror (v2.7.1).
                                            The link given by the FritzBox is working fine with the VLC player on the Raspberry but when using the same link in the RTSP module it remains a black screen.
                                            Stream Link FritzBox:
                                            rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                            Config used from generator:
                                                    autoStart: true,
                                                    moduleWidth: 354,
                                                    moduleHeight: 240,
                                                    remoteSnaps: false,
                                                    stream1: {
                                                        url: 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov',
                                                        frameRate: 'undefined',
                                                        width: undefined,
                                                        height: undefined,
                                                    stream2: {
                                                        url: 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803',
                                                        width: undefined,
                                                        height: undefined,
                                            Some findings:
                                            • When using above link from the FritzBox in VLC player, the stream is working inside VLC Player
                                            • When using the Big Bunny test file on the mirror its starts automatically and running well
                                            • Tried both in the config generator, rotating streams and show streams in parallel, it brings the same result.
                                            The BigBunny streams is showing correctly with audio and video, FritzBox stream box will show grey frame with black content only and no sound.
                                            The console shows the following logs:
                                            Starting stream stream1 with args: [
                                            “–avdict”,
                                            “rtsp_transport:tcp”,
                                            “–win”,
                                            “351, 708, 703, 950”,
                                            “–live”,
                                            “–video_queue”,
                                            “4”,
                                            “–fps”,
                                            “30”,
                                            “rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov”
                                            Starting stream stream2 with args: [
                                            “–avdict”,
                                            “–win”,
                                            “351, 968, 703, 1210”,
                                            “–live”,
                                            “–video_queue”,
                                            “4”,
                                            “–fps”,
                                            “30”,
                                            “rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803”
                                            Starting PM2 for omx_stream2
                                            PM2 started for omx_stream2
                                            Starting PM2 for omx_stream1
                                            PM2 started for omx_stream1
                                            Great if you have an idea and can let me know what to change to get this running.
                                            Bill
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 30
                                            • 31
                                            • 15 / 31
