    602 Posts 67 Posters 2.4m Views 68 Watching
    • 0
      0YXmEQ
      Started at page 17 and running on the latest develop branch and trying to use omxplayer. Open GL fake is running with 128. Using VLC on a windows PC I’m able to get the RTSP stream working.
      In VLC I chose network stream use the URL
      rtsp://admin:******@192.168.200.4:554/cam/realmonitor?channel=1&subtype=0
      I do have select ‘Active Transcoding’ and use Video -H.264 + MP3 (MP4)
      When I run it on MagicMirror I get this:
      It’s an Amcrest Camera. I’m able to test using the “Big Buck Bunny” and that works great.
      0 1 Reply Last reply
      • 0
        0YXmEQ @0YXmEQ
        @0YXmEQ
        Update: This issue appears specific to my Amcrest Camera. I’m able to stream my Arecont Camera.
        On that not my Arecont Camera has 4 lenses. How could have to RTSP stream windows side by side? Each showing one lense with no border?
        rtsp://192.168.200.10/h264.sdp2?res=full&doublescan=0&ssn=466
        rtsp://192.168.200.10/h264.sdp3?res=full&doublescan=0&ssn=467
          SH20192 @0YXmEQ
          Im trying to use the VLC player on the “develop” branch code. Im running into issues with VLC. If I set my localplayer to omxplayer then everything works fine. If I change it to “vlc” I dont not get a picture. Is there something else I need to change for it to work? Thanks!
            SH20192 @SH20192
            @SH20192 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            disregard. didnt realize I needed to reload the node modules. seems to have fixed the issue.
            • Cr4z33C
              Cr4z33
                jimmysmalls
                Hey guys I’m running into trouble getting my Reolink cameras to show. I can open the stream in vlc player but just get an outlined box on my magicmirror. Any idea what I’m doing wrong? It’s probably something simple. Here’s my code minus the username and password of course :)
                    module: "MMM-RTSPStream",
                    position: "middle_center",
                    header: "Front",
                        autoStart: true,
                        rotateStreams: false,
                        rotateStreamTimeout: 10,
                        moduleWidth: 354,
                        moduleHeight: 240,
                        localPlayer: 'omxplayer',
                        remotePlayer: 'none',
                        showSnapWhenPaused: true,
                        remoteSnaps: true,
                        stream1: {
                            url: 'rtsp://user:pass@192.168.1.42:554//h264Preview_01_main',
                            frameRate: '10',
                            snapshotType: 'url',
                            snapshotRefresh: 10,
                            width: undefined,
                            height: undefined,
                • BKeyportB
                  BKeyport Module Developer
                  Check your IP string here: https://www.ispyconnect.com/man.aspx?n=Reolink mine uses h264Preview_01_sub for instance.
                  I do use ffmpeg for the picture as it seems to work better for my system - I have an RLC-410.
                  		position: "top_center",
                  			autoStart: true,
                  			moduleWidth: 640,
                  			moduleHeight: 360,
                  			localPlayer: 'ffmpeg',
                  			remotePlayer: 'ffmpeg',
                  			showSnapWhenPaused: false,
                  			remoteSnaps: false,
                  			omxRestart: 2,
                  			stream1: {
                  				url: 'rtsp://user:pass@FrontCam/h264Preview_01_sub',
                  				protocal: "ucp",
                  				width: 640,
                  				height: 360,
                  				ffmpegPort: 9999,
                  				shutdownDelay: 0,
                  Oh, and if you want to get rid of the white box (I find it distracting) in your custom.css file:
                  .MMM-RTSPStream .innerWrapper {
                  border: 0;
                  J 1 Reply Last reply
                    jimmysmalls @BKeyport
                    @BKeyport
                    Thanks for the link. Mine is the RLC-420 and says h264Preview_01_main. I even tried just using your code and replacing with my credentials but all I can get is a gray box. Strange thing is I can open main or sub in vlc just fine. I thought this was going to be an easy project haha
                    • BKeyportB
                      try ffmpeg, might be something wrong with the main player.
                        @BKeyport
                        I did actually. It shows a pause button when I hover over it but just gives me a black screen. :(
                        • BKeyportB
                          hmmm. have you tried changing to “sub” rather than “main”? The “sub” feed is the lower quality feed, and better suited for RPI…
                            bill22
                            Hey Guys,
                            i face some problems to get the RTSP module to work with my stream and wonder if @shbatm or someone else can help.
                            Objective is to use the live dvb-c feed provided by an AVM FritzBox 6490 cable router to display the tv program on the MagicMirror (v2.7.1).
                            The link given by the FritzBox is working fine with the VLC player on the Raspberry but when using the same link in the RTSP module it remains a black screen.
                            Stream Link FritzBox:
                            rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                            Config used from generator:
                                    autoStart: true,
                                    moduleWidth: 354,
                                    moduleHeight: 240,
                                    remoteSnaps: false,
                                    stream1: {
                                        url: 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov',
                                        frameRate: 'undefined',
                                        width: undefined,
                                        height: undefined,
                                    stream2: {
                                        url: 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803',
                                        width: undefined,
                                        height: undefined,
                            Some findings:
                            • When using above link from the FritzBox in VLC player, the stream is working inside VLC Player
                            • When using the Big Bunny test file on the mirror its starts automatically and running well
                            • Tried both in the config generator, rotating streams and show streams in parallel, it brings the same result.
                            The BigBunny streams is showing correctly with audio and video, FritzBox stream box will show grey frame with black content only and no sound.
                            The console shows the following logs:
                            Starting stream stream1 with args: [
                            “–avdict”,
                            “rtsp_transport:tcp”,
                            “–win”,
                            “351, 708, 703, 950”,
                            “–live”,
                            “–video_queue”,
                            “4”,
                            “–fps”,
                            “30”,
                            “rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov”
                            Starting stream stream2 with args: [
                            “–avdict”,
                            “–win”,
                            “351, 968, 703, 1210”,
                            “–live”,
                            “–video_queue”,
                            “4”,
                            “–fps”,
                            “30”,
                            “rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803”
                            Starting PM2 for omx_stream2
                            PM2 started for omx_stream2
                            Starting PM2 for omx_stream1
                            PM2 started for omx_stream1
                            Great if you have an idea and can let me know what to change to get this running.
                            Bill
                            evroomE 1 Reply Last reply
                            • evroomE
                              evroom @bill22
                              @bill22
                              I would remove stream1 from the config (and rename stream2 to stream1) since you know “test1” passed.
                              What does this say ?
                              $ vcgencmd codec_enabled MPG2
                              And when MM is started, do you see omxplayer processes ?
                              $ ps -eaf | grep -v grep | grep omxplayer
                              $ pm2 status
                              And standalone (best without any omxplayer process(es) active) ?
                              $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win 351 968 703 1210 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                              MagicMirror version: 2.37.0
                                bill22
                                @evroom
                                Hi and thank you.
                                Adapted the config as suggested and renamed the streams.
                                checked your requested topics:
                                pi@raspberrypi:~ $ vcgencmd codec_enabled MPG2
                                MPG2=disabled
                                Is the MPG2 codec mandatory?
                                pi@raspberrypi:~ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win 351 968 703 1210 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                [1] 1346
                                [2] 1347
                                [3] 1348
                                [4] 1349
                                [5] 1350
                                [6] 1351
                                [7] 1352
                                [2]   Fertig                  freq=394
                                [3]   Fertig                  bw=8
                                [4]   Fertig                  msys=dvbc
                                [5]   Fertig                  mtype=256qam
                                pi@raspberrypi:~ $ File "968" not found.
                                    "--avdict",
                                    "rtsp_transport:tcp",
                                    "--win",
                                    "351, 708, 703, 950",
                                    "--live",
                                    "--video_queue",
                                    "4",
                                    "--fps",
                                    "30",
                                    "rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803"
                                pi@raspberrypi:~ $ ps -eaf | grep -v grep | grep omxplayer
                                pi        3533  2023  0 15:57 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 351, 708, 703, 950 --live --video_queue 4 --fps 30 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                pi        3551  3533  0 15:57 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 351, 708, 703, 950 --live --video_queue 4 --fps 30 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                pi@raspberrypi:~ $
                                • evroomE
                                  evroom @bill22
                                  @bill22
                                  The last output actually looks good.
                                  Processes are there.
                                  Do they remain present after a few minutes, with same PID’s ?
                                  Can you try this again using quotes around the --win parameter ?
                                  $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                  It can be that a mpeg2 license is necessary.
                                  I know that for satellite TS streams it is.
                                  http://www.raspberrypi.com/mpeg-2-license-key/
                                  When you stream it via VLC Player, you can see under Media Information - Codec Details what codec is being used.
                                    bill22
                                    @evroom
                                    not sure if i can check this correctly with the processes but if i run the test file (Big Bunny) it runs for minutes…
                                    tried it with quotes around the win parameter:
                                    pi@raspberrypi:~ $ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                    [1] 1563
                                    [2] 1564
                                    [3] 1565
                                    bash: $: Kommando nicht gefunden.
                                    [4] 1566
                                    [5] 1567
                                    [6] 1568
                                    [7] 1569
                                    [1]   Exit 127                $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1
                                    [2]   Fertig                  freq=394
                                    [6]-  Fertig                  sr=6900
                                    I am also going to check it out with the license as VLC is showing MPEG 1/2 (mpgv) as codec…
                                      bill22
                                      @evroom
                                      MPG2 license is enabled now.
                                      There is a difference now as the grey box from RTSP Stream module contains a Pause symbol (autostart is enabled) when moving the mouse over it…and becomes a play button when i click on it.
                                      I have also adapted the frame rate and size towards the parameters shown in the VLC player detail window.
                                      Any other idea what i could try…?
                                      • evroomE
                                        evroom @bill22
                                        @bill22
                                        You have to remove the second $ in the command.
                                        This $ in my examples is just to say to run it from the the command line.
                                        • evroomE
                                          evroom @bill22
                                          @bill22
                                          You try to add --genlog after the omxplayer command, like
                                          omxplayer --genlog --avdict rtsp_transport:tcp ............
                                          Then check the omxplayer.log, normally located under the directory where you started the command.
                                          Or find it using sudo find . -name omxplayer.log.
                                          • evroomE
                                            evroom @evroom
                                            @bill22
                                            Just a disclaimer.
                                            I do not use this module any more for my stream (a webcam using h.265).
                                            See first post on this page:
                                            https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/262?page=27
                                            I could try to set it up again for a sat stream.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 30
                                            • 31
                                            • 15 / 31
