    602 Posts 67 Posters 2.2m Views 68 Watching
      jimmysmalls @BKeyport
      @BKeyport
      I did actually. It shows a pause button when I hover over it but just gives me a black screen. :(
      • BKeyportB Offline
        BKeyport Module Developer
        hmmm. have you tried changing to “sub” rather than “main”? The “sub” feed is the lower quality feed, and better suited for RPI…
          bill22
          Hey Guys,
          i face some problems to get the RTSP module to work with my stream and wonder if @shbatm or someone else can help.
          Objective is to use the live dvb-c feed provided by an AVM FritzBox 6490 cable router to display the tv program on the MagicMirror (v2.7.1).
          The link given by the FritzBox is working fine with the VLC player on the Raspberry but when using the same link in the RTSP module it remains a black screen.
          Stream Link FritzBox:
          rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
          Config used from generator:
              module: "MMM-RTSPStream",
              position: "middle_center",
                  autoStart: true,
                  rotateStreams: false,
                  rotateStreamTimeout: 10,
                  moduleWidth: 354,
                  moduleHeight: 240,
                  localPlayer: 'omxplayer',
                  remotePlayer: 'none',
                  showSnapWhenPaused: false,
                  remoteSnaps: false,
                  stream1: {
                      url: 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov',
                      frameRate: 'undefined',
                      width: undefined,
                      height: undefined,
                  stream2: {
                      url: 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803',
                      width: undefined,
                      height: undefined,
          Some findings:
          • When using above link from the FritzBox in VLC player, the stream is working inside VLC Player
          • When using the Big Bunny test file on the mirror its starts automatically and running well
          • Tried both in the config generator, rotating streams and show streams in parallel, it brings the same result.
          The BigBunny streams is showing correctly with audio and video, FritzBox stream box will show grey frame with black content only and no sound.
          The console shows the following logs:
          Starting stream stream1 with args: [
          “–avdict”,
          “rtsp_transport:tcp”,
          “–win”,
          “351, 708, 703, 950”,
          “–live”,
          “–video_queue”,
          “4”,
          “–fps”,
          “30”,
          “rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov”
          Starting stream stream2 with args: [
          “–avdict”,
          “–win”,
          “351, 968, 703, 1210”,
          “–live”,
          “–video_queue”,
          “4”,
          “–fps”,
          “30”,
          “rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803”
          Starting PM2 for omx_stream2
          PM2 started for omx_stream2
          Starting PM2 for omx_stream1
          PM2 started for omx_stream1
          Great if you have an idea and can let me know what to change to get this running.
          Bill
          • evroomE Offline
            evroom @bill22
            @bill22
            I would remove stream1 from the config (and rename stream2 to stream1) since you know “test1” passed.
            What does this say ?
            $ vcgencmd codec_enabled MPG2
            And when MM is started, do you see omxplayer processes ?
            $ ps -eaf | grep -v grep | grep omxplayer
            $ pm2 status
            And standalone (best without any omxplayer process(es) active) ?
            $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win 351 968 703 1210 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
            MagicMirror version: 2.35.0
            Test environment:
            MagicMirror version: 2.36.0-develop
              bill22
              @evroom
              Hi and thank you.
              Adapted the config as suggested and renamed the streams.
              checked your requested topics:
              pi@raspberrypi:~ $ vcgencmd codec_enabled MPG2
              MPG2=disabled
              Is the MPG2 codec mandatory?
              pi@raspberrypi:~ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win 351 968 703 1210 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
              [1] 1346
              [2] 1347
              [3] 1348
              [4] 1349
              [5] 1350
              [6] 1351
              [7] 1352
              [2]   Fertig                  freq=394
              [3]   Fertig                  bw=8
              [4]   Fertig                  msys=dvbc
              [5]   Fertig                  mtype=256qam
              pi@raspberrypi:~ $ File "968" not found.
                  "--avdict",
                  "rtsp_transport:tcp",
                  "--win",
                  "351, 708, 703, 950",
                  "--live",
                  "--video_queue",
                  "4",
                  "--fps",
                  "30",
                  "rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803"
              pi@raspberrypi:~ $ ps -eaf | grep -v grep | grep omxplayer
              pi        3533  2023  0 15:57 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 351, 708, 703, 950 --live --video_queue 4 --fps 30 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
              pi        3551  3533  0 15:57 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 351, 708, 703, 950 --live --video_queue 4 --fps 30 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
              pi@raspberrypi:~ $
              • evroomE Offline
                evroom @bill22
                @bill22
                The last output actually looks good.
                Processes are there.
                Do they remain present after a few minutes, with same PID’s ?
                Can you try this again using quotes around the --win parameter ?
                $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                It can be that a mpeg2 license is necessary.
                I know that for satellite TS streams it is.
                http://www.raspberrypi.com/mpeg-2-license-key/
                When you stream it via VLC Player, you can see under Media Information - Codec Details what codec is being used.
                Test environment:
                  bill22
                  @evroom
                  not sure if i can check this correctly with the processes but if i run the test file (Big Bunny) it runs for minutes…
                  tried it with quotes around the win parameter:
                  pi@raspberrypi:~ $ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                  [1] 1563
                  [2] 1564
                  [3] 1565
                  bash: $: Kommando nicht gefunden.
                  [4] 1566
                  [5] 1567
                  [6] 1568
                  [7] 1569
                  [1]   Exit 127                $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1
                  [2]   Fertig                  freq=394
                  [6]-  Fertig                  sr=6900
                  I am also going to check it out with the license as VLC is showing MPEG 1/2 (mpgv) as codec…
                    bill22
                    @evroom
                    MPG2 license is enabled now.
                    There is a difference now as the grey box from RTSP Stream module contains a Pause symbol (autostart is enabled) when moving the mouse over it…and becomes a play button when i click on it.
                    I have also adapted the frame rate and size towards the parameters shown in the VLC player detail window.
                    Any other idea what i could try…?
                    • evroomE Offline
                      evroom @bill22
                      @bill22
                      You have to remove the second $ in the command.
                      This $ in my examples is just to say to run it from the the command line.
                      Test environment:
                      • evroomE Offline
                        evroom @bill22
                        @bill22
                        You try to add --genlog after the omxplayer command, like
                        omxplayer --genlog --avdict rtsp_transport:tcp ............
                        Then check the omxplayer.log, normally located under the directory where you started the command.
                        Or find it using sudo find . -name omxplayer.log.
                        Test environment:
                        • evroomE Offline
                          evroom @evroom
                          @bill22
                          Just a disclaimer.
                          I do not use this module any more for my stream (a webcam using h.265).
                          See first post on this page:
                          https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/262?page=27
                          I could try to set it up again for a sat stream.
                          Test environment:
                            bill22
                            @evroom
                            Thanks and i entered the command in the right way again:
                            pi@raspberrypi:~ $ /usr/bin/omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                            [1] 27791
                            [2] 27792
                            [3] 27793
                            [4] 27794
                            [5] 27795
                            [6] 27796
                            [7] 27797
                            [3]   Fertig                  bw=8
                            Log:
                            20:16:28 T:11869916 DEBUG: DllBcm: Using omx system library
                            20:16:29 T:12283107 DEBUG: DllOMX: Using omx system library
                            20:16:29 T:12283969 DEBUG: DllAvFormat: Using libavformat system library
                            20:16:29 T:12285949 WARNING: Failed to acquire D-Bus name ‘org.mpris.MediaPlayer2.omxplayer’
                            20:16:29 T:12286105 WARNING: DBus connection failed, trying alternate
                            20:16:29 T:12287974 DEBUG: DBus connection succeeded
                              bill22
                              @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                              @evroom Thanks a lot for your support especially as you are not using the module actually anymore…
                              Am i right that the RTSPStream module is the best option/only one i could use for my case?
                              • evroomE Offline
                                evroom @bill22
                                @bill22
                                I think I have the same issue as you:
                                It would be the best option, if it would work. :-)
                                As a workaround for my IP cam issue, I use omxplayer as a separate process.
                                It is an overlay on top of your screen anyway.
                                For you, it is first priority to get your stream using omxplayer working, outside of MM
                                So disable the module and restart MM.
                                    disabled: true,
                                Then we take it from there.
                                Can you confirm that your stream is MPEG-4 (vlc player media information) ?
                                Test environment:
                                  bill22
                                  yes, that would be great having the module just working :-)
                                  Picture looks same as on mine…
                                  Module is disabled.
                                  Just checked again in VLC.
                                  Codec: MPEG-1/2 Video (mpgv)
                                  • evroomE Offline
                                    evroom @bill22
                                    @bill22
                                    Can you confirm that this works ?
                                    $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                                    I have to say that the error message using your stream looks rather ugly
                                    I do not know what is does.
                                    The help says:
                                    --dbus_name name.     Set D-Bus bus name (default: org.mpris.MediaPlayer2.omxplayer)
                                    Test environment:
                                      bill22
                                      @evroom
                                      pi@raspberrypi:~ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                                      Video codec omx-h264 width 240 height 160 profile 578 fps 30.000000
                                      Audio codec aac channels 2 samplerate 12000 bitspersample 16
                                      Subtitle count: 0, state: off, index: 1, delay: 0
                                      V:PortSettingsChanged: 240x160@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                                      displays the Bunny video and audio in the lower part of the screen. Video is half visible but i believe this is not important for the moment.
                                      • evroomE Offline
                                        evroom @bill22
                                        @bill22
                                        Hi, last posts for today.
                                        I found 2 parameters to test.
                                        Can you do
                                        $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                        and send the output ?
                                        And
                                        $ /usr/bin/omxplayer --genlog --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                        and send the omxplayer.log ?
                                        Test environment:
                                          bill22
                                          @evroom
                                          output:
                                          pi@raspberrypi:~ $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                          [1] 989
                                          [2] 990
                                          [3] 991
                                          [4] 992
                                          [5] 993
                                          [6] 994
                                          [7] 995
                                          [2]   Fertig                  freq=394
                                          [3]   Fertig                  bw=8
                                          pi@raspberrypi:~ $
                                          requested log for:
                                          Log:
                                          21:51:55 T:1443630962 DEBUG: DllBcm: Using omx system library
                                          21:51:55 T:1443632668 DEBUG: DllOMX: Using omx system library
                                          21:51:55 T:1443633892 DEBUG: DllAvFormat: Using libavformat system library
                                          21:51:55 T:1443636500 DEBUG: DBus connection succeeded
                                          Thank you and have a good evening!
                                          • evroomE Offline
                                            evroom @bill22
                                            @bill22
                                            2 more commands.
                                            Just to be sure of a few things.
                                            The --hw option did change the log output and the D-bus errors are gone.
                                            $ /usr/bin/omxplayer --version
                                            I get:
                                            omxplayer - Commandline multimedia player for the Raspberry Pi
                                                    Build date: Fri, 07 Jun 2019 19:49:22 +0000
                                                    Version   : f06235c [master]
                                                    Repository: https://github.com/popcornmix/omxplayer.git
                                            And:
                                            /usr/bin/omxplayer --info --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '6351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                                            I get:
                                            Input #0, rtsp, from 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov':
                                              Metadata:
                                                title           : BigBuckBunny_115k.mov
                                              Duration: 00:09:56.48, start: 0.000000, bitrate: N/A
                                                Stream #0:0: Audio: aac (LC), 12000 Hz, stereo, fltp
                                                Stream #0:1: Video: h264 (Constrained Baseline), yuv420p(progressive), 240x160, 24 fps, 24 tbr, 90k tbn, 48 tbc
                                            have a nice day ;)
                                            Test environment:
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 30
                                            • 31
                                            • 16 / 31
