    602 Posts 67 Posters 2.4m Views 68 Watching
    • evroomE
      evroom @evroom
      @bill22
      Just a disclaimer.
      I do not use this module any more for my stream (a webcam using h.265).
      See first post on this page:
      https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/262?page=27
      I could try to set it up again for a sat stream.
      MagicMirror version: 2.37.0
        bill22
        @evroom
        Thanks and i entered the command in the right way again:
        pi@raspberrypi:~ $ /usr/bin/omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
        [1] 27791
        [2] 27792
        [3] 27793
        [4] 27794
        [5] 27795
        [6] 27796
        [7] 27797
        [3]   Fertig                  bw=8
        [4]   Fertig                  msys=dvbc
        Log:
        20:16:28 T:11869916 DEBUG: DllBcm: Using omx system library
        20:16:29 T:12283107 DEBUG: DllOMX: Using omx system library
        20:16:29 T:12283969 DEBUG: DllAvFormat: Using libavformat system library
        20:16:29 T:12285949 WARNING: Failed to acquire D-Bus name ‘org.mpris.MediaPlayer2.omxplayer’
        20:16:29 T:12286105 WARNING: DBus connection failed, trying alternate
        20:16:29 T:12287974 DEBUG: DBus connection succeeded
          bill22
          @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
          @evroom Thanks a lot for your support especially as you are not using the module actually anymore…
          Am i right that the RTSPStream module is the best option/only one i could use for my case?
          evroomE 1 Reply Last reply
          • evroomE
            evroom @bill22
            @bill22
            I think I have the same issue as you:
            It would be the best option, if it would work. :-)
            As a workaround for my IP cam issue, I use omxplayer as a separate process.
            It is an overlay on top of your screen anyway.
            For you, it is first priority to get your stream using omxplayer working, outside of MM
            So disable the module and restart MM.
            module: "MMM-RTSPStream",
                disabled: true,
            Then we take it from there.
            Can you confirm that your stream is MPEG-4 (vlc player media information) ?
              bill22
              yes, that would be great having the module just working :-)
              Picture looks same as on mine…
              Module is disabled.
              Just checked again in VLC.
              Codec: MPEG-1/2 Video (mpgv)
              • evroomE
                evroom @bill22
                @bill22
                Can you confirm that this works ?
                $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                I have to say that the error message using your stream looks rather ugly
                I do not know what is does.
                The help says:
                --dbus_name name.     Set D-Bus bus name (default: org.mpris.MediaPlayer2.omxplayer)
                  bill22
                  @evroom
                  pi@raspberrypi:~ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                  Video codec omx-h264 width 240 height 160 profile 578 fps 30.000000
                  Audio codec aac channels 2 samplerate 12000 bitspersample 16
                  Subtitle count: 0, state: off, index: 1, delay: 0
                  V:PortSettingsChanged: 240x160@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                  displays the Bunny video and audio in the lower part of the screen. Video is half visible but i believe this is not important for the moment.
                  • evroomE
                    evroom @bill22
                    @bill22
                    Hi, last posts for today.
                    I found 2 parameters to test.
                    Can you do
                    $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                    and send the output ?
                    And
                    $ /usr/bin/omxplayer --genlog --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                    and send the omxplayer.log ?
                      bill22
                      @evroom
                      output:
                      pi@raspberrypi:~ $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                      [1] 989
                      [2] 990
                      [3] 991
                      [4] 992
                      [5] 993
                      [6] 994
                      [7] 995
                      [2]   Fertig                  freq=394
                      [3]   Fertig                  bw=8
                      pi@raspberrypi:~ $
                      requested log for:
                      Log:
                      21:51:55 T:1443630962 DEBUG: DllBcm: Using omx system library
                      21:51:55 T:1443632668 DEBUG: DllOMX: Using omx system library
                      21:51:55 T:1443633892 DEBUG: DllAvFormat: Using libavformat system library
                      21:51:55 T:1443636500 DEBUG: DBus connection succeeded
                      Thank you and have a good evening!
                      • evroomE
                        evroom @bill22
                        @bill22
                        2 more commands.
                        Just to be sure of a few things.
                        The --hw option did change the log output and the D-bus errors are gone.
                        $ /usr/bin/omxplayer --version
                        I get:
                        omxplayer - Commandline multimedia player for the Raspberry Pi
                                Build date: Fri, 07 Jun 2019 19:49:22 +0000
                                Version   : f06235c [master]
                                Repository: https://github.com/popcornmix/omxplayer.git
                        And:
                        /usr/bin/omxplayer --info --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '6351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                        I get:
                        Input #0, rtsp, from 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov':
                          Metadata:
                            title           : BigBuckBunny_115k.mov
                          Duration: 00:09:56.48, start: 0.000000, bitrate: N/A
                            Stream #0:0: Audio: aac (LC), 12000 Hz, stereo, fltp
                            Stream #0:1: Video: h264 (Constrained Baseline), yuv420p(progressive), 240x160, 24 fps, 24 tbr, 90k tbn, 48 tbc
                        have a nice day ;)
                          bill22
                          @evroom
                          Hi and good evening!
                          Looks i get the same as you:
                          I get:
                          I get:
                            Metadata:
                          have a nice day ;)
                          • evroomE
                            evroom @bill22
                            @bill22
                            Looks like you are doomed to watch Buck Bunny for the rest of your Magic Mirror life :-)
                            You did not get an error with — hw in your previous mail.
                            It did return with the prompt, right ?
                            You did not have to stop it using control C, I mean to say?
                            Normally omxplayer exits with: have a nice day ; )
                            Can you try
                            /usr/bin/omxplayer --genlog --hw --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                            And check the log file.
                              bill22
                              @evroom
                              Hopefully not…! we may need to find another one if we cannot fix it… :-)
                              No i didn’t stop it using control C.
                              returns:
                              [1] 1897
                              [2] 1898
                              [3] 1899
                              [4] 1900
                              [5] 1901
                              [6] 1902
                              [7] 1903
                              [2]   Fertig                  freq=394
                              Log shows:
                              17:08:24 T:2113103317 DEBUG: DllBcm: Using omx system library
                              17:08:24 T:2113104714 DEBUG: DllOMX: Using omx system library
                              17:08:24 T:2113105528 DEBUG: DllAvFormat: Using libavformat system library
                              17:08:24 T:2113107746 DEBUG: DBus connection succeeded
                              • evroomE
                                evroom @bill22
                                @bill22
                                Okay, I think it is stumbling over the ampersands in your RTSP URL.
                                Try it with the RTSP part single quoted, like:
                                $ /usr/bin/omxplayer --genlog --hw --win '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                                Quotes work in general. Tested it on friend Buck Bunny.
                                  bill22
                                  @evroom
                                  Allright! :thumbs_up:
                                  i have a picture overlay with the omxplayer showing the live stream TV signal!
                                  Unfortunately it runs for a second and stops, continuously . > (buffer, cache,…?)
                                  Audio is not there correctly. It sounds like white noise for a second and stops continuously.
                                    bill22
                                    @evroom
                                    FYI:
                                    shows:
                                    Video codec omx-mpeg2 width 720 height 576 profile 4 fps 25.000000
                                    Audio codec mp2 channels 2 samplerate 48000 bitspersample 16
                                    Subtitle count: 1, state: off, index: 1, delay: 0
                                    V:PortSettingsChanged: 720x576@25.00 interlace:3 deinterlace:1 anaglyph:0 par:1.42 display:0 layer:0 alpha:255 aspectMode:0
                                    • evroomE
                                      evroom @bill22
                                      @bill22
                                      Getting somewhere.
                                      Now you need to slowly add additional parameters.
                                      Like --live --video_queue 4
                                        bill22
                                        i might be wrong. I added it here and received the error message “…file not found”:
                                        /usr/bin/omxplayer --genlog --hw --win --live --video_queue 4 '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                                        Do i need to add those parameters somewhere else?
                                        • evroomE
                                          evroom @bill22
                                          @bill22
                                          /usr/bin/omxplayer --genlog --hw --live --video_queue 4 --win '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                                            bill22
                                            @evroom
                                            Thanks!
                                            OK, positive effect on the video, running pretty smooth now!
                                            Audio still missing…
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 30
                                            • 31
                                            • 16 / 31
