    602 Posts 67 Posters 2.4m Views 68 Watching
      bill22
      @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/262?page=27
      @evroom Thanks a lot for your support especially as you are not using the module actually anymore…
      Am i right that the RTSPStream module is the best option/only one i could use for my case?
      evroomE 1 Reply Last reply
      • evroomE
        evroom @bill22
        @bill22
        I think I have the same issue as you:
        It would be the best option, if it would work. :-)
        As a workaround for my IP cam issue, I use omxplayer as a separate process.
        It is an overlay on top of your screen anyway.
        For you, it is first priority to get your stream using omxplayer working, outside of MM
        So disable the module and restart MM.
        module: "MMM-RTSPStream",
            disabled: true,
        Then we take it from there.
        Can you confirm that your stream is MPEG-4 (vlc player media information) ?
        MagicMirror version: 2.37.0
          bill22
          yes, that would be great having the module just working :-)
          Picture looks same as on mine…
          Module is disabled.
          Just checked again in VLC.
          Codec: MPEG-1/2 Video (mpgv)
          • evroomE
            evroom @bill22
            @bill22
            Can you confirm that this works ?
            $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
            I have to say that the error message using your stream looks rather ugly
            WARNING: Failed to acquire D-Bus name ‘org.mpris.MediaPlayer2.omxplayer’
            I do not know what is does.
            The help says:
            --dbus_name name.     Set D-Bus bus name (default: org.mpris.MediaPlayer2.omxplayer)
              bill22
              @evroom
              pi@raspberrypi:~ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
              Video codec omx-h264 width 240 height 160 profile 578 fps 30.000000
              Audio codec aac channels 2 samplerate 12000 bitspersample 16
              Subtitle count: 0, state: off, index: 1, delay: 0
              V:PortSettingsChanged: 240x160@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
              displays the Bunny video and audio in the lower part of the screen. Video is half visible but i believe this is not important for the moment.
              • evroomE
                evroom @bill22
                @bill22
                Hi, last posts for today.
                I found 2 parameters to test.
                Can you do
                $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                and send the output ?
                And
                $ /usr/bin/omxplayer --genlog --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                and send the omxplayer.log ?
                  bill22
                  @evroom
                  output:
                  pi@raspberrypi:~ $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                  [1] 989
                  [2] 990
                  [3] 991
                  [4] 992
                  [5] 993
                  [6] 994
                  [7] 995
                  [2]   Fertig                  freq=394
                  [3]   Fertig                  bw=8
                  pi@raspberrypi:~ $
                  requested log for:
                  Log:
                  21:51:55 T:1443630962 DEBUG: DllBcm: Using omx system library
                  21:51:55 T:1443632668 DEBUG: DllOMX: Using omx system library
                  21:51:55 T:1443633892 DEBUG: DllAvFormat: Using libavformat system library
                  21:51:55 T:1443636500 DEBUG: DBus connection succeeded
                  Thank you and have a good evening!
                  • evroomE
                    evroom @bill22
                    @bill22
                    2 more commands.
                    Just to be sure of a few things.
                    The --hw option did change the log output and the D-bus errors are gone.
                    $ /usr/bin/omxplayer --version
                    I get:
                    omxplayer - Commandline multimedia player for the Raspberry Pi
                            Build date: Fri, 07 Jun 2019 19:49:22 +0000
                            Version   : f06235c [master]
                            Repository: https://github.com/popcornmix/omxplayer.git
                    And:
                    /usr/bin/omxplayer --info --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '6351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                    I get:
                    Input #0, rtsp, from 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov':
                      Metadata:
                        title           : BigBuckBunny_115k.mov
                      Duration: 00:09:56.48, start: 0.000000, bitrate: N/A
                        Stream #0:0: Audio: aac (LC), 12000 Hz, stereo, fltp
                        Stream #0:1: Video: h264 (Constrained Baseline), yuv420p(progressive), 240x160, 24 fps, 24 tbr, 90k tbn, 48 tbc
                    have a nice day ;)
                      bill22
                      @evroom
                      Hi and good evening!
                      Looks i get the same as you:
                      I get:
                      I get:
                        Metadata:
                      have a nice day ;)
                      • evroomE
                        evroom @bill22
                        @bill22
                        Looks like you are doomed to watch Buck Bunny for the rest of your Magic Mirror life :-)
                        You did not get an error with — hw in your previous mail.
                        It did return with the prompt, right ?
                        You did not have to stop it using control C, I mean to say?
                        Normally omxplayer exits with: have a nice day ; )
                        Can you try
                        /usr/bin/omxplayer --genlog --hw --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                        And check the log file.
                          bill22
                          @evroom
                          Hopefully not…! we may need to find another one if we cannot fix it… :-)
                          No i didn’t stop it using control C.
                          returns:
                          [1] 1897
                          [2] 1898
                          [3] 1899
                          [4] 1900
                          [5] 1901
                          [6] 1902
                          [7] 1903
                          [2]   Fertig                  freq=394
                          [4]   Fertig                  msys=dvbc
                          Log shows:
                          17:08:24 T:2113103317 DEBUG: DllBcm: Using omx system library
                          17:08:24 T:2113104714 DEBUG: DllOMX: Using omx system library
                          17:08:24 T:2113105528 DEBUG: DllAvFormat: Using libavformat system library
                          17:08:24 T:2113107746 DEBUG: DBus connection succeeded
                          • evroomE
                            evroom @bill22
                            @bill22
                            Okay, I think it is stumbling over the ampersands in your RTSP URL.
                            Try it with the RTSP part single quoted, like:
                            $ /usr/bin/omxplayer --genlog --hw --win '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                            Quotes work in general. Tested it on friend Buck Bunny.
                              bill22
                              @evroom
                              Allright! :thumbs_up:
                              i have a picture overlay with the omxplayer showing the live stream TV signal!
                              Unfortunately it runs for a second and stops, continuously . > (buffer, cache,…?)
                              Audio is not there correctly. It sounds like white noise for a second and stops continuously.
                                bill22
                                @evroom
                                FYI:
                                shows:
                                Video codec omx-mpeg2 width 720 height 576 profile 4 fps 25.000000
                                Audio codec mp2 channels 2 samplerate 48000 bitspersample 16
                                Subtitle count: 1, state: off, index: 1, delay: 0
                                V:PortSettingsChanged: 720x576@25.00 interlace:3 deinterlace:1 anaglyph:0 par:1.42 display:0 layer:0 alpha:255 aspectMode:0
                                • evroomE
                                  evroom @bill22
                                  @bill22
                                  Getting somewhere.
                                  Now you need to slowly add additional parameters.
                                  Like --live --video_queue 4
                                    bill22
                                    i might be wrong. I added it here and received the error message “…file not found”:
                                    /usr/bin/omxplayer --genlog --hw --win --live --video_queue 4 '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                                    Do i need to add those parameters somewhere else?
                                    • evroomE
                                      evroom @bill22
                                      @bill22
                                      /usr/bin/omxplayer --genlog --hw --live --video_queue 4 --win '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                                        bill22
                                        @evroom
                                        Thanks!
                                        OK, positive effect on the video, running pretty smooth now!
                                        Audio still missing…
                                        • evroomE
                                          evroom @bill22
                                          @bill22
                                          With Buck Bunny you had audio, right?
                                          Audio over hdmi or audio jack?
                                          Try adding --audio_queue 4
                                          Then try removing --hw
                                            bill22
                                            @evroom
                                            yes with Buck Bunny the audio was there.
                                            I use audio over HDMI.
                                            adding
                                            --audio_queue 4
                                            didn’t change the behaviour .
                                            removed
                                            --hw
                                            Audio is working smoothly together with video ! !
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 30
                                            • 31
                                            • 16 / 31
