    602 Posts 67 Posters 2.4m Views 68 Watching
      bill22
      @evroom
      not sure if i can check this correctly with the processes but if i run the test file (Big Bunny) it runs for minutes…
      tried it with quotes around the win parameter:
      pi@raspberrypi:~ $ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
      [1] 1563
      [2] 1564
      [3] 1565
      bash: $: Kommando nicht gefunden.
      [4] 1566
      [5] 1567
      [6] 1568
      [7] 1569
      [1]   Exit 127                $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1
      [2]   Fertig                  freq=394
      [4]   Fertig                  msys=dvbc
      [5]   Fertig                  mtype=256qam
      [6]-  Fertig                  sr=6900
      I am also going to check it out with the license as VLC is showing MPEG 1/2 (mpgv) as codec…
      evroomE 1 Reply Last reply
        bill22
        @evroom
        MPG2 license is enabled now.
        There is a difference now as the grey box from RTSP Stream module contains a Pause symbol (autostart is enabled) when moving the mouse over it…and becomes a play button when i click on it.
        I have also adapted the frame rate and size towards the parameters shown in the VLC player detail window.
        Any other idea what i could try…?
        • evroomE
          evroom @bill22
          @bill22
          You have to remove the second $ in the command.
          This $ in my examples is just to say to run it from the the command line.
          MagicMirror version: 2.37.0
          • evroomE
            evroom @bill22
            @bill22
            You try to add --genlog after the omxplayer command, like
            omxplayer --genlog --avdict rtsp_transport:tcp ............
            Then check the omxplayer.log, normally located under the directory where you started the command.
            Or find it using sudo find . -name omxplayer.log.
            • evroomE
              evroom @evroom
              @bill22
              Just a disclaimer.
              I do not use this module any more for my stream (a webcam using h.265).
              See first post on this page:
              https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/262?page=27
              I could try to set it up again for a sat stream.
                bill22
                @evroom
                Thanks and i entered the command in the right way again:
                pi@raspberrypi:~ $ /usr/bin/omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                [1] 27791
                [2] 27792
                [3] 27793
                [4] 27794
                [5] 27795
                [6] 27796
                [7] 27797
                [3]   Fertig                  bw=8
                Log:
                20:16:28 T:11869916 DEBUG: DllBcm: Using omx system library
                20:16:29 T:12283107 DEBUG: DllOMX: Using omx system library
                20:16:29 T:12283969 DEBUG: DllAvFormat: Using libavformat system library
                20:16:29 T:12285949 WARNING: Failed to acquire D-Bus name ‘org.mpris.MediaPlayer2.omxplayer’
                20:16:29 T:12286105 WARNING: DBus connection failed, trying alternate
                20:16:29 T:12287974 DEBUG: DBus connection succeeded
                  bill22
                  @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                  @evroom Thanks a lot for your support especially as you are not using the module actually anymore…
                  Am i right that the RTSPStream module is the best option/only one i could use for my case?
                  • evroomE
                    evroom @bill22
                    @bill22
                    I think I have the same issue as you:
                    It would be the best option, if it would work. :-)
                    As a workaround for my IP cam issue, I use omxplayer as a separate process.
                    It is an overlay on top of your screen anyway.
                    For you, it is first priority to get your stream using omxplayer working, outside of MM
                    So disable the module and restart MM.
                    module: "MMM-RTSPStream",
                        disabled: true,
                    Then we take it from there.
                    Can you confirm that your stream is MPEG-4 (vlc player media information) ?
                      bill22
                      yes, that would be great having the module just working :-)
                      Picture looks same as on mine…
                      Module is disabled.
                      Just checked again in VLC.
                      Codec: MPEG-1/2 Video (mpgv)
                      • evroomE
                        evroom @bill22
                        @bill22
                        Can you confirm that this works ?
                        $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                        I have to say that the error message using your stream looks rather ugly
                        I do not know what is does.
                        The help says:
                        --dbus_name name.     Set D-Bus bus name (default: org.mpris.MediaPlayer2.omxplayer)
                          bill22
                          @evroom
                          pi@raspberrypi:~ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                          Video codec omx-h264 width 240 height 160 profile 578 fps 30.000000
                          Audio codec aac channels 2 samplerate 12000 bitspersample 16
                          Subtitle count: 0, state: off, index: 1, delay: 0
                          V:PortSettingsChanged: 240x160@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                          displays the Bunny video and audio in the lower part of the screen. Video is half visible but i believe this is not important for the moment.
                          • evroomE
                            evroom @bill22
                            @bill22
                            Hi, last posts for today.
                            I found 2 parameters to test.
                            Can you do
                            $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                            and send the output ?
                            And
                            $ /usr/bin/omxplayer --genlog --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                            and send the omxplayer.log ?
                              bill22
                              @evroom
                              output:
                              pi@raspberrypi:~ $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                              [1] 989
                              [2] 990
                              [3] 991
                              [4] 992
                              [5] 993
                              [6] 994
                              [7] 995
                              [2]   Fertig                  freq=394
                              [3]   Fertig                  bw=8
                              pi@raspberrypi:~ $
                              requested log for:
                              Log:
                              21:51:55 T:1443630962 DEBUG: DllBcm: Using omx system library
                              21:51:55 T:1443632668 DEBUG: DllOMX: Using omx system library
                              21:51:55 T:1443633892 DEBUG: DllAvFormat: Using libavformat system library
                              21:51:55 T:1443636500 DEBUG: DBus connection succeeded
                              Thank you and have a good evening!
                              • evroomE
                                evroom @bill22
                                @bill22
                                2 more commands.
                                Just to be sure of a few things.
                                The --hw option did change the log output and the D-bus errors are gone.
                                $ /usr/bin/omxplayer --version
                                I get:
                                omxplayer - Commandline multimedia player for the Raspberry Pi
                                        Build date: Fri, 07 Jun 2019 19:49:22 +0000
                                        Version   : f06235c [master]
                                        Repository: https://github.com/popcornmix/omxplayer.git
                                And:
                                /usr/bin/omxplayer --info --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '6351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                                I get:
                                Input #0, rtsp, from 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov':
                                  Metadata:
                                    title           : BigBuckBunny_115k.mov
                                  Duration: 00:09:56.48, start: 0.000000, bitrate: N/A
                                    Stream #0:0: Audio: aac (LC), 12000 Hz, stereo, fltp
                                    Stream #0:1: Video: h264 (Constrained Baseline), yuv420p(progressive), 240x160, 24 fps, 24 tbr, 90k tbn, 48 tbc
                                have a nice day ;)
                                  bill22
                                  @evroom
                                  Hi and good evening!
                                  Looks i get the same as you:
                                  I get:
                                  I get:
                                    Metadata:
                                  have a nice day ;)
                                  • evroomE
                                    evroom @bill22
                                    @bill22
                                    Looks like you are doomed to watch Buck Bunny for the rest of your Magic Mirror life :-)
                                    You did not get an error with — hw in your previous mail.
                                    It did return with the prompt, right ?
                                    You did not have to stop it using control C, I mean to say?
                                    Normally omxplayer exits with: have a nice day ; )
                                    Can you try
                                    /usr/bin/omxplayer --genlog --hw --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                    And check the log file.
                                      bill22
                                      @evroom
                                      Hopefully not…! we may need to find another one if we cannot fix it… :-)
                                      No i didn’t stop it using control C.
                                      returns:
                                      [1] 1897
                                      [2] 1898
                                      [3] 1899
                                      [4] 1900
                                      [5] 1901
                                      [6] 1902
                                      [7] 1903
                                      [2]   Fertig                  freq=394
                                      Log shows:
                                      17:08:24 T:2113103317 DEBUG: DllBcm: Using omx system library
                                      17:08:24 T:2113104714 DEBUG: DllOMX: Using omx system library
                                      17:08:24 T:2113105528 DEBUG: DllAvFormat: Using libavformat system library
                                      17:08:24 T:2113107746 DEBUG: DBus connection succeeded
                                      • evroomE
                                        evroom @bill22
                                        @bill22
                                        Okay, I think it is stumbling over the ampersands in your RTSP URL.
                                        Try it with the RTSP part single quoted, like:
                                        $ /usr/bin/omxplayer --genlog --hw --win '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                                        Quotes work in general. Tested it on friend Buck Bunny.
                                          bill22
                                          @evroom
                                          Allright! :thumbs_up:
                                          i have a picture overlay with the omxplayer showing the live stream TV signal!
                                          Unfortunately it runs for a second and stops, continuously . > (buffer, cache,…?)
                                          Audio is not there correctly. It sounds like white noise for a second and stops continuously.
                                            bill22
                                            @evroom
                                            FYI:
                                            shows:
                                            Video codec omx-mpeg2 width 720 height 576 profile 4 fps 25.000000
                                            Audio codec mp2 channels 2 samplerate 48000 bitspersample 16
                                            Subtitle count: 1, state: off, index: 1, delay: 0
                                            V:PortSettingsChanged: 720x576@25.00 interlace:3 deinterlace:1 anaglyph:0 par:1.42 display:0 layer:0 alpha:255 aspectMode:0
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 30
                                            • 31
                                            • 16 / 31
