    602 Posts 67 Posters 2.3m Views 68 Watching
    • evroomE Offline
      evroom @bill22
      @bill22
      I would remove stream1 from the config (and rename stream2 to stream1) since you know “test1” passed.
      What does this say ?
      $ vcgencmd codec_enabled MPG2
      And when MM is started, do you see omxplayer processes ?
      $ ps -eaf | grep -v grep | grep omxplayer
      $ pm2 status
      And standalone (best without any omxplayer process(es) active) ?
      $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win 351 968 703 1210 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
      MagicMirror version: 2.37.0
        bill22
        @evroom
        Hi and thank you.
        Adapted the config as suggested and renamed the streams.
        checked your requested topics:
        pi@raspberrypi:~ $ vcgencmd codec_enabled MPG2
        MPG2=disabled
        Is the MPG2 codec mandatory?
        pi@raspberrypi:~ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win 351 968 703 1210 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
        [1] 1346
        [2] 1347
        [3] 1348
        [4] 1349
        [5] 1350
        [6] 1351
        [7] 1352
        [2]   Fertig                  freq=394
        [3]   Fertig                  bw=8
        [4]   Fertig                  msys=dvbc
        [5]   Fertig                  mtype=256qam
        pi@raspberrypi:~ $ File "968" not found.
        Starting stream stream1 with args: [
            "--avdict",
            "rtsp_transport:tcp",
            "--win",
            "351, 708, 703, 950",
            "--live",
            "--video_queue",
            "4",
            "--fps",
            "30",
            "rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803"
        Starting PM2 for omx_stream1
        PM2 started for omx_stream1
        pi@raspberrypi:~ $ ps -eaf | grep -v grep | grep omxplayer
        pi        3533  2023  0 15:57 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 351, 708, 703, 950 --live --video_queue 4 --fps 30 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
        pi        3551  3533  0 15:57 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 351, 708, 703, 950 --live --video_queue 4 --fps 30 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
        pi@raspberrypi:~ $
        • evroomE Offline
          evroom @bill22
          @bill22
          The last output actually looks good.
          Processes are there.
          Do they remain present after a few minutes, with same PID’s ?
          Can you try this again using quotes around the --win parameter ?
          $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
          It can be that a mpeg2 license is necessary.
          I know that for satellite TS streams it is.
          http://www.raspberrypi.com/mpeg-2-license-key/
          When you stream it via VLC Player, you can see under Media Information - Codec Details what codec is being used.
            bill22
            @evroom
            not sure if i can check this correctly with the processes but if i run the test file (Big Bunny) it runs for minutes…
            tried it with quotes around the win parameter:
            pi@raspberrypi:~ $ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
            [1] 1563
            [2] 1564
            [3] 1565
            bash: $: Kommando nicht gefunden.
            [4] 1566
            [5] 1567
            [6] 1568
            [7] 1569
            [1]   Exit 127                $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1
            [2]   Fertig                  freq=394
            [6]-  Fertig                  sr=6900
            I am also going to check it out with the license as VLC is showing MPEG 1/2 (mpgv) as codec…
              bill22
              @evroom
              MPG2 license is enabled now.
              There is a difference now as the grey box from RTSP Stream module contains a Pause symbol (autostart is enabled) when moving the mouse over it…and becomes a play button when i click on it.
              I have also adapted the frame rate and size towards the parameters shown in the VLC player detail window.
              Any other idea what i could try…?
              • evroomE Offline
                evroom @bill22
                @bill22
                You have to remove the second $ in the command.
                This $ in my examples is just to say to run it from the the command line.
                • evroomE Offline
                  evroom @bill22
                  @bill22
                  You try to add --genlog after the omxplayer command, like
                  omxplayer --genlog --avdict rtsp_transport:tcp ............
                  Then check the omxplayer.log, normally located under the directory where you started the command.
                  Or find it using sudo find . -name omxplayer.log.
                  • evroomE Offline
                    evroom @evroom
                    @bill22
                    Just a disclaimer.
                    I do not use this module any more for my stream (a webcam using h.265).
                    See first post on this page:
                    https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/262?page=27
                    I could try to set it up again for a sat stream.
                      bill22
                      @evroom
                      Thanks and i entered the command in the right way again:
                      pi@raspberrypi:~ $ /usr/bin/omxplayer --genlog --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                      [1] 27791
                      [2] 27792
                      [3] 27793
                      [4] 27794
                      [5] 27795
                      [6] 27796
                      [7] 27797
                      [3]   Fertig                  bw=8
                      Log:
                      20:16:28 T:11869916 DEBUG: DllBcm: Using omx system library
                      20:16:29 T:12283107 DEBUG: DllOMX: Using omx system library
                      20:16:29 T:12283969 DEBUG: DllAvFormat: Using libavformat system library
                      20:16:29 T:12285949 WARNING: Failed to acquire D-Bus name ‘org.mpris.MediaPlayer2.omxplayer’
                      20:16:29 T:12286105 WARNING: DBus connection failed, trying alternate
                      20:16:29 T:12287974 DEBUG: DBus connection succeeded
                        bill22
                        @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                        @evroom Thanks a lot for your support especially as you are not using the module actually anymore…
                        Am i right that the RTSPStream module is the best option/only one i could use for my case?
                        • evroomE Offline
                          evroom @bill22
                          @bill22
                          I think I have the same issue as you:
                          It would be the best option, if it would work. :-)
                          As a workaround for my IP cam issue, I use omxplayer as a separate process.
                          It is an overlay on top of your screen anyway.
                          For you, it is first priority to get your stream using omxplayer working, outside of MM
                          So disable the module and restart MM.
                          module: "MMM-RTSPStream",
                              disabled: true,
                          Then we take it from there.
                          Can you confirm that your stream is MPEG-4 (vlc player media information) ?
                            bill22
                            yes, that would be great having the module just working :-)
                            Picture looks same as on mine…
                            Module is disabled.
                            Just checked again in VLC.
                            Codec: MPEG-1/2 Video (mpgv)
                            • evroomE Offline
                              evroom @bill22
                              @bill22
                              Can you confirm that this works ?
                              $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                              I have to say that the error message using your stream looks rather ugly
                              I do not know what is does.
                              The help says:
                              --dbus_name name.     Set D-Bus bus name (default: org.mpris.MediaPlayer2.omxplayer)
                                bill22
                                @evroom
                                pi@raspberrypi:~ $ /usr/bin/omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                                Video codec omx-h264 width 240 height 160 profile 578 fps 30.000000
                                Audio codec aac channels 2 samplerate 12000 bitspersample 16
                                Subtitle count: 0, state: off, index: 1, delay: 0
                                V:PortSettingsChanged: 240x160@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                                displays the Bunny video and audio in the lower part of the screen. Video is half visible but i believe this is not important for the moment.
                                • evroomE Offline
                                  evroom @bill22
                                  @bill22
                                  Hi, last posts for today.
                                  I found 2 parameters to test.
                                  Can you do
                                  $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                  and send the output ?
                                  And
                                  $ /usr/bin/omxplayer --genlog --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                  and send the omxplayer.log ?
                                    bill22
                                    @evroom
                                    output:
                                    pi@raspberrypi:~ $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                    [1] 989
                                    [2] 990
                                    [3] 991
                                    [4] 992
                                    [5] 993
                                    [6] 994
                                    [7] 995
                                    [2]   Fertig                  freq=394
                                    [3]   Fertig                  bw=8
                                    pi@raspberrypi:~ $
                                    requested log for:
                                    Log:
                                    21:51:55 T:1443630962 DEBUG: DllBcm: Using omx system library
                                    21:51:55 T:1443632668 DEBUG: DllOMX: Using omx system library
                                    21:51:55 T:1443633892 DEBUG: DllAvFormat: Using libavformat system library
                                    21:51:55 T:1443636500 DEBUG: DBus connection succeeded
                                    Thank you and have a good evening!
                                    • evroomE Offline
                                      evroom @bill22
                                      @bill22
                                      2 more commands.
                                      Just to be sure of a few things.
                                      The --hw option did change the log output and the D-bus errors are gone.
                                      $ /usr/bin/omxplayer --version
                                      I get:
                                      omxplayer - Commandline multimedia player for the Raspberry Pi
                                              Build date: Fri, 07 Jun 2019 19:49:22 +0000
                                              Version   : f06235c [master]
                                              Repository: https://github.com/popcornmix/omxplayer.git
                                      And:
                                      /usr/bin/omxplayer --info --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '6351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
                                      I get:
                                      Input #0, rtsp, from 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov':
                                        Metadata:
                                          title           : BigBuckBunny_115k.mov
                                        Duration: 00:09:56.48, start: 0.000000, bitrate: N/A
                                          Stream #0:0: Audio: aac (LC), 12000 Hz, stereo, fltp
                                          Stream #0:1: Video: h264 (Constrained Baseline), yuv420p(progressive), 240x160, 24 fps, 24 tbr, 90k tbn, 48 tbc
                                      have a nice day ;)
                                        bill22
                                        @evroom
                                        Hi and good evening!
                                        Looks i get the same as you:
                                        I get:
                                        I get:
                                          Metadata:
                                        have a nice day ;)
                                        • evroomE Offline
                                          evroom @bill22
                                          @bill22
                                          Looks like you are doomed to watch Buck Bunny for the rest of your Magic Mirror life :-)
                                          You did not get an error with — hw in your previous mail.
                                          It did return with the prompt, right ?
                                          You did not have to stop it using control C, I mean to say?
                                          Normally omxplayer exits with: have a nice day ; )
                                          Can you try
                                          /usr/bin/omxplayer --genlog --hw --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                                          And check the log file.
                                            bill22
                                            @evroom
                                            Hopefully not…! we may need to find another one if we cannot fix it… :-)
                                            No i didn’t stop it using control C.
                                            returns:
                                            [1] 1897
                                            [2] 1898
                                            [3] 1899
                                            [4] 1900
                                            [5] 1901
                                            [6] 1902
                                            [7] 1903
                                            [2]   Fertig                  freq=394
                                            Log shows:
                                            17:08:24 T:2113103317 DEBUG: DllBcm: Using omx system library
                                            17:08:24 T:2113104714 DEBUG: DllOMX: Using omx system library
                                            17:08:24 T:2113105528 DEBUG: DllAvFormat: Using libavformat system library
                                            17:08:24 T:2113107746 DEBUG: DBus connection succeeded
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 30
                                            • 31
                                            • 16 / 31
