    Starting/monitoring remotely
    4 Posts 3 Posters 3.4k Views 3 Watching
      amanzimdwini
      Probably something I should know, but
      I am in the process of customizing my MM2 - and I am NOT in front of it.
      So I RDP over to it on one of my monitors, start a terminal and launch MM.
      Since I am now locked out, I have to use PUTTY to work on it on a different monitor.
      i change stuff and then sudo reboot. Every time.
      There must be a better way of stopping and starting MM2.
      Help?
      Thanks!
      • BangeeB Offline
        Bangee Module Developer
        if you are loged in on putty, you can restart your mirror using this command:
        pm2 restart mm
        or you’ll have to install a VNC Server on Raspberry to display your screen remotly.
        https://www.google.ch/search?q=raspberry+pi+vnc+server+autostart&ie=utf-8&oe=utf-8&client=firefox-b&gfe_rd=cr&ei=hdJ0V-eKPOLI8geiy5igDg
        And then you’ll be able to reload the mm pushing CTRL + R
          amanzimdwini @Bangee
          @Bangee
          THAT was easy (duh)
          Thanks. How do I mark this as closed/resolved?
          • paviroP Offline
            paviro Admin
            I did it for you :) But you can also find it here:
            We're all stories in the end. Just make it a good one, eh?
            – The Doctor
