    Error says Read-only file system?
    13 Posts 3 Posters 7.1k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @Iron_Reptar
      @Iron_Reptar
      Of course I am curious and I’m glad that you solved the problem. We both learned something, too. Anyway, enjoy your mirror!
      • cowboysdudeC Offline
        cowboysdude Module Developer @Iron_Reptar
        @Iron_Reptar said in Error says Read-only file system?:
        @Mykle1
        I’m about to go return my sd card and see if I can’t get another, but wanted to make sure before I mess with the new one that I’m even formatting it right.
        I’m using the program “SDFormatter”, setting the Format type to “Full (Erase)” and the Format Size Adjustment to “ON”
        Does that sound right to you?
        Yes sir that is correct.
        As I have also just found out that a USB port on a computer can also give you fits… If there’s problems writing to a card I’d try another port or another machine… ;) I realize the SD card was bad but is the exception generally.
        I 1 Reply Last reply Reply Quote 1
        • I Offline
          Iron_Reptar @cowboysdude
          @cowboysdude
          I think I got lucky with it actually being the micro-SD card. I’ve been using a SD card adapter to fit into the SD slot in my computer, and unfortunately there’s only one of those on my laptop :P
          For some reason, when I had the old card, formatting it (even when it was completely empty and fresh out of the box) took at least half an hour. Now with the new one it only took about 5 minutes.
