    npm do not start!
    6 Posts 0 Posters 4.8k Views 2 Watching
    • N Offline
      Neokamikaze
      After a new installation (no error during my installation). I start npm module and the module don’t start.
      > magicmirror@2.0.0 start /home/pi/MagicMirror
      > electron js/electron.js
      • MichMichM Offline
        MichMich
        We need a little more info to help.
        • Are you booting in CLI mode, or in the GUI mode (and starting this from a terminal window)?
        • What’s the Node version you’re running?
        • What RPi are you using?
        • What OS are you using?
        • N Offline
          Neokamikaze
          Hi MichMich,
          Yes i start with my terminal.
          My node.js version is 6.2.2.
          My OS is jessie
          My RPi is RPi0
          MitchfarinoM 1 Reply Last reply Reply Quote 0
          • KirAsh4K Offline
            KirAsh4 Moderator
            Are you using the term “terminal” as the actual Term app installed in the graphical environment, or as a command line environment? Meaning, when you boot up the rpi, does it boot up in the graphical screen, or does it stop at a black (text) screen that you log in to?
            • N Offline
              Neokamikaze
              When starting the GUI terminal and the commande “npm start” the script starts. I have a progress bar and after a few seconds the script stops. No interface starts. Node.js 6.2.2 is installed and the dependencies are ok too.
              • MitchfarinoM Offline
                Mitchfarino Module Developer @Neokamikaze
                @Neokamikaze The zero isn’t supposed at the moment, is it? @KirAsh4
