    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 126.0k Views 27 Watching
    • M
      microkost
      This post is deleted!
      M 1 Reply Last reply
      • M
        microkost @microkost
        Is this module still working? Because after clonning and providing access_token according to manual is still stucked on Loading… warning.
        Output from starting MagicMirror:
        Connecting socket for: MMM-Instagram
        Starting node_helper for module [MMM-Instagram]
        OK, some debug… I finally used multi account fork from O5ten and used his API key from README 1160247792.b119586.49fa97770ee34deb92e621069c760cee then it started to show pictures, so finall problem is on my access_token. Good to know for debuging, should help someone else…
        How to test that access token is OK?
        Put to web browser:
        https://api.instagram.com/v1/users/self/media/recent?access_token=1160247792.b119586.49fa97770ee34deb92e621069c760cee
        did you see some data as result?
        "data": [{"id": "1698285770916717663...
        So now test your key
        https://api.instagram.com/v1/users/self/media/recent?access_token=[TOKEN_HERE]
        If there is result, everything is OK, if you get
        data	[]
        then is time to investigate! Do you have content on your wall? Because your’s last 20 posts are only accessible in sandbox https://www.instagram.com/developer/sandbox/ (!!!)
        For rest and another use cases read carefully https://www.instagram.com/developer/ guide.
        My problem was empty my wall… Sorry for spam, but maybe it helps someone not familiar with that with debuging.
        Reply Quote 1
        • N
          nobita @kapsolas
          @kapsolas
          I have 3 questions
          1. What happen after install this module, Loading…status on monitor (not show photo)
          2. How to get API KEY
          3. in config, ask access_token so I have to put access_token or API KEY
            Thanks for all your kind
          • B
            benderstwin
            This works great, but is it possible to make it actually reload the pictures from instagram without reloading MM?
            • A
              AlexanderSalter
              Hi all, had the same problem, Instagram was acquired by Facebook who have updated the way the API works.
              I spent a couple of days writing and testing a new module for Instagram that was based off the original.
              It requires a Facebook developer account and app, but I have explained it as best i can in readme
              Intro_Post
              MMM-Instagram2020
              C 1 Reply Last reply
              • C
                chassain 0 @AlexanderSalter
                @AlexanderSalter
                It works fine. Thanks Alexander.
                • K
                  Kkardi
                  @yo-less said in MMM-Instagram - Pull and animate photos from Instagram feed:
                  @kapsolas
                  @kapsolas is it possible to show only the photos you liked with this??
                  • 5 / 5
