    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 858.6k Views 59 Watching
      airart @sdetweil
      @sdetweil it works ! I am so moved, evidently that was the problem.
      Does CMD remain active how do I leave the MM? fn + f11 reduces to window
      I also noticed some warnings
        sdetweil @airart
        @airart ctrl-c in ther terminal window will stop the active program
        ignore warnings
          matefits71
          Thanks for the tutorial, i’m running magicmirror on a surface pro 4,
          The installation worked perfectly but when i tried to run npm start it throw an error “> DISPLAY=”${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js"
          To bypass the error i edited the package.json by removing the DISPLAY="${DISPLAY:=:0} at the begining, tried npm start and it worked.
          I’m not sure for what is that display option.
            sdetweil @matefits71
            @matefits71 on Linux, the xwindows graphical system writes to a numbered ‘display’ , and there can be multiple.
            windows doesn’t have that. which is why I’ve written to remove that part, and also run the manual npm install in vendors and go ta folders
              angeldchaveza
              $ npm start
              magicmirror@2.16.0 start C:\Users\Tecsis\MagicMirror
              DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
              “DISPLAY” no se reconoce como un comando interno o externo,
              programa o archivo por lotes ejecutable.
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.16.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.16.0 start script.
              npm ERR! C:\Users\Tecsis\AppData\Roaming\npm-cache_logs\2021-09-02T01_57_52_304Z-debug.log
                angeldchaveza @angeldchaveza
                @angeldchaveza .
                im delete display of "matefits71 " error logs view
                1 verbose cli [
                1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
                1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
                1 verbose cli ‘start’
                1 verbose cli ]
                2 info using npm@6.14.14
                3 info using node@v14.17.5
                4 verbose stack Error: missing script: start
                4 verbose stack at run (C:\Program Files\nodejs\node_modules\npm\lib\run-script.js:155:19)
                4 verbose stack at C:\Program Files\nodejs\node_modules\npm\lib\run-script.js:63:5
                4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:116:5
                4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:436:5
                4 verbose stack at checkBinReferences_ (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:391:45)
                4 verbose stack at final (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:434:3)
                4 verbose stack at then (C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:161:5)
                4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\read-package-json\read-json.js:382:12
                4 verbose stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\graceful-fs.js:123:16
                4 verbose stack at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:73:3)
                5 verbose cwd C:\Users\Tecsis\MagicMirror
                6 verbose Windows_NT 10.0.19041
                7 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
                8 verbose node v14.17.5
                9 verbose npm v6.14.14
                10 error missing script: start
                11 verbose exit [ 1, true ]
                  sdetweil @angeldchaveza
                  @angeldchaveza u are on windows. there are extra steps for windows.
                  https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?page=15
                    angeldchaveza @sdetweil
                    @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                    these were the steps i followed
                      @angeldchaveza yes, but they changed.
                      my link has the updated steps
                        angeldchaveza
                        "Installing fonts …
                        "MagicMirror installation finished successfully!
                        magicmirror@2.16.0 prepare C:\Users\Tecsis\magicmirror
                        [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                        husky - Git hooks installed
                        npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                        npm WARN magicmirror@2.16.0 scripts[‘server’] should probably be scripts[‘start’].
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules\fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})
                        audited 923 packages in 21.766s
                        110 packages are looking for funding
                        run npm fund for details
                        found 0 vulnerabilities
                        Tecsis@DESKTOP-FGU3JGC MINGW64 ~/magicmirror (master)
                        $ npm start
                        npm ERR! missing script: start
                        npm ERR! C:\Users\Tecsis\AppData\Roaming\npm-cache_logs\2021-09-02T02_53_44_514Z-debug.log
                          @angeldchaveza do NOT install under
                          MINGW64
                          just straight windows
                          • K Offline
                            KillK
                            Hi, newby here… I have reinstaled MM in my win 10 laptop… It was working well until the reinstallation…
                            I am having an issue, i will try to translate it, cuz my cmd is in spanish…
                            magicmirror@2.17.1 start
                            “node_modules” doesn’t recognize it as an internal or external command,
                            program or file by executable lot.
                            At the same time i have notice, that “.bin” folder doesn’t contain “electron js” folder inside…
                            I have had to install manually npm for fonts ans vendor’s folders…
                            Please, help me Obi Wan Kenobi…
                            mumblebajM S 2 Replies Last reply Reply Quote 0
                            • mumblebajM Offline
                              mumblebaj Module Developer @KillK
                              @killk You have asked the same question in different posts a few times. This can be seen as spamming,
                              • K Offline
                                KillK @mumblebaj
                                @mumblebaj oh sorry, i have to delete the other one… I didn’t know it.
                                  sdetweil @KillK
                                  @killk we are all volunteers here. more folks around in the evenings, weekends. but it’s all volunteer. no commitment to answer any question or solve any problem . asking in multiple places doesn’t get help any faster.
                                    sdetweil @KillK
                                    @killk I had no problem
                                    Win 10, under Vmware
                                    git clone
                                    npm install
                                    and in vendors and fonts
                                    edit the package.json
                                    copy the default config.js from the sample
                                    npm start
                                      mounir @Mykle1
                                      @mykle1 how can i resolve this ?
                                      ‘DISPLAY’ is not recognized as an internal or external command,
                                      operable program or batch file.
                                        sdetweil @mounir
                                        @mounir have to scan further back
                                        see
                                        https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
                                          mounir @sdetweil
                                          @sdetweil no i see this
                                          listen EACCES: permission denied 127.0.0.1:8080
                                          can you help me fix it
                                            sdetweil @mounir
                                            @mounir where do u see that?
                                            u are installing in cmd terminal window, right?
                                            not PowerShell
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
