    New and confused.
    55 Posts 5 Posters 33.1k Views 5 Watching
    • mickyasM Offline
      mickyas
      Thanks Mykle 1,
      I’d already done most of that (trial and error), up to Section 4 (cleaning and updating…) although the screenshots were completely different to what i was seeing on my TV when i had the Pi3 hooked up.
      In the MM install do i need to reconfigure the pi software to display in portrait (as the samsung monitor i’m using has a built in function to be viewed in landscape or portrait)?
      As stated in my original post, i’ve managed to work out how to get Alexa operational but how do i ‘save’ this so that it starts again when i switch on the pi instead of losing it altogether when i switch off? Thanks for your help, really is appreciated by this aged learner :-))))))
      Mick
        Mykle1 Project Sponsor Module Developer @mickyas
        @mickyas said in New and confused.:
        No, you don’t have to do that at all. Some people have made their mirrors in landscape view. It’s a matter of preference.
        I’m not really sure what you are asking me. Do you want the mirror software to load automatically upon booting? Are you losing your Alexa setup? I’m not familiar with Alexa at all but we can surely find out.
        mickyasM 1 Reply Last reply Reply Quote 0
        • mickyasM Offline
          mickyas @Mykle1
          @Mykle1 Yes, once i’ve entered all of the code etc and have Alexa up and running (with the 3 terminal screens open as instructed), it’s all good until i switched off, unplug or close the terminals, then i lose everything and i have to start all over again. I’d like Alexa to remain on the PI 3 so that when i make my mirror fully operational (frame, monitor, wiring harness etc), and i put it all into ‘standyby’, i don’t lose it all.
          Mick
          • mickyasM Offline
            mickyas
            OOPS…having a play around and managed to get the Magic Mirror up and running :-)))) BUT i changed the screen configuration/layout and changed it to portrait…how do i undo it??? :-))))))))))) Also is there a way to change the 'compliments and to have the weather widget etc 'floating around the screen instead of being static??? Thanks
            Mick
            • SexyTroggS Offline
              SexyTrogg
              I don’t believe that it is possible to have the compliments floating around. If you take a peek here:
              https://forum.magicmirror.builders/topic/286/regions
              You can see color coded regions for where the modules are allowed to be displayed. You (or someone else) could always change the code to possibly rotate which region the module is displayed but I think that may lead to other problems.
              Also, check out here for how to rotate the screen orientation:
              https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
              I used that guide to change mine to landscape and to disable the screensaver (which i recommend).
              Cheers!
              mickyasM 2 Replies Last reply Reply Quote 1
                There must be a way to save your Alexa state so that it reloads on reboot/restart. However, I’ve never used Alexa. It would be best if you created a new topic in “Troubleshooting”, naming it, “How to save the state of Alexa?” and describe your problem there. This way the question will be seen by everyone instead of being lost in this topic
                  All the info you need for changing the compliments is here:
                  https://github.com/MichMich/MagicMirror/tree/develop/modules/default/compliments
                  @SexyTrogg has given you good advice. The links he gave you are very informative. You can change the screen orientation by reversing the directions in the 2nd link that he gave you.
                  In lieu of disabling the screensaver directions on that page, I would do this instead. It’s just easier and it works like a charm.
                  My solution was to install xscreensaver and use the desktop control panel to disable the screensaver.
                  In your terminal:
                  sudo apt-get install xscreensaver
                  sudo reboot
                  On reboot open the desktop start menu (via the GUI, not the terminal) Preferences/Screensaver/Mode:/Disable Screen Saver.
                  mickyasM 1 Reply Last reply Reply Quote 1
                  • mickyasM Offline
                    mickyas @SexyTrogg
                    @SexyTrogg Thank you :-))) Only problem is the first link you posted doesn’t have any instruction as to what to do, or is it just an example of the only options available? If so, is there a link showing how to change the colours etc?
                    Mick
                    SexyTroggS 1 Reply Last reply Reply Quote 0
                    • mickyasM Offline
                      mickyas @Mykle1
                      @Mykle1 Thank you (again) mykle, but that link is as clear as mud to me :-)))))))))))))))))))))))))))))))) I have NO knowledge or experience of coding, terminology or anything even closely resembling this (ask anything you want about building work or fibre optic production facility set-ups and i’m your man, but this !!!..) :-))))
                        SexyTrogg @mickyas
                        @mickyas Its an example of what options are available. Every module has to be placed into the Magic Mirror config file and inside of that file will be the settings for each module. For example:
                        	module: "compliments",
                        	position: "lower_third",	// This can be any of the regions.
                        								// Best results in one of the middle regions like: lower_third
                        		// The config property is optional.
                        		// If no config is set, the default compliments are shown.
                        Above is taken from the compliments module. As you can see there is the position:“lower_third” option. The link I gave you gives you all of the other options for where you can place your module.
                        As for colors, the link only used colors to help make each region stand out. Modules set their colors through their .css files so you can always go into that and change it to your needs.
                        • 6
                        • 5 / 6
