    Philips Hue Light Switches based wakeup
    utility
    3 Posts 3 Posters 3.9k Views 2 Watching
    • T Offline
      Tomekkkkk
      i need some help with an Python Script which should wake up the Mirror by pressing the button. I got some Philips Hue Light Switches but have trouble to curl the right data. I think the switch is pretty good for this, because no installation is needed. alt text
      The Script should wake up the Mirror with libcec over HDMI, also turn the LCD off in Standby by pressing the button.
      In the Philips Hue Bridge i have whitelisted the Pi and with curl i can read the last Buttonevents of the right switch over the existing API (http://192.168.X.XXX/api/WBLu***UNIQUEUSERID***bdQ0-iEetTe5/sensors/5)
      This Site gave me the following JSON Data:
      {„state": {"buttonevent":1002,"lastupdated":"2016-05-04T15:00:51"},"config":{"on":true,"battery":100,"reachable":true},"name":"Hue dimmer switch 1","type":"ZLLSwitch","modelid":"RWL021","manufacturername":"Philips","swversion":"5.45.1.16265","uniqueid":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"}
      buttonevent 1002 is for turn on and 4002 is for turn off
      So i worked on a script which will should check all 10 seconds the Buttonstatus and regarding this Wake Up the LCD.
      import urllib2
import time
         def SensorState( SensorName ):
          s = "buttonevent\":"
  a = urllib2.urlopen("http://192.168.X.XXX/api/monitor/sensors/" + SensorName    ).read()
  b =  a.find(s) + len(s)
  e = a.find(",",b)
         return a[b:e];
        while 1 == 1:
         lastState = SensorState("2")
 while (SensorState ("2") == lastState):
   time.sleep(0.5)
         print "State Changed!" + SensorState("2")
      For LIBCEC the action for Turn on is echo "on 0" | sudo cec-client -s -d 1 and echo "standby 0" | sudo cec-client -s -d 1 to turn it off.
      Over SSH all commands will work good on its own, but i need a script…
      It is my first time with Phyton, the Script should be easy for someone with more experience in this. Maybe someone could help mit with this?
      Thank you for your help!
      • P Offline
        paviro
        Why not use NodeJS for the script?
        – The Doctor
        • MichMichM Offline
          MichMich
          Go for node. Adding a python solution would make no sense.
