    Blackscreen with no errors.
    6 Posts 2 Posters 3.5k Views 2 Watching
    • zimmcognitoZ
      zimmcognito
      Hi there!
      So I have a problem that when I run sudo npm start the blank screen pops up.
      Starting MagicMirror: v2.1.2
      Loading config ...
      Loading module helpers ...
      All module helpers loaded.
      Server started ...
      Starting module: newsfeed
      Launching application.
      This is terminal log, as you can see there is no error.
      I have tried several ways to fix it like deleting modules or changing the language, Im using Kubuntu and actually wanted to try it out on my laptop before buying pi3, any idea what could cause this problem?
      Thanksies
      • zimmcognitoZ
        zimmcognito
        You were totally right about administrative rights @Mykle1, I have done it from beggining and it works like a charm.
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @zimmcognito
          @zimmcognito
          You shouldn’t have to run sudo to launch the mirror. The installation guide states, “DO NOT INSTALL MagicMirror² as the root user! Always do it as the regular, non privileged pi user.”
          With that being said, is your console reporting any errors? cd into your MagicMirror directory and run npm start dev and see what you get there
          • zimmcognitoZ
            zimmcognito
            Oh, the sudo part might be infact my bad.
            Here is the paste bin of console errors
            • Mykle1M
              @zimmcognito
              You have more than a few problems going on there. Did you install your dependencies? I would try that first. Did you have the mirror running at all and it later failed when you added something? Or have you not got it to run at all?
              Personally, if installing the dependencies is not the problem, I would do a whole new installation manually, installing the latest node and npm first, then installing the dependencies, then try to running the mirror with the defaults before trying to edit anything.
              • zimmcognitoZ
                zimmcognito
                • Mykle1M
                  @zimmcognito
                  Oh, that’s good news. Enjoy your mirror
