    Unrecognized Config file
    14 Posts 5 Posters 9.0k Views 3 Watching
      dejayou
      Hi everyone, new coder here, but despite searching this forum for a solution and essentially duplicating the exact source code, I still can’t manage to have the raspberry pi recognize my Magic Mirror config file. I’ve renamed the file, dropping the “sample”, and saved and rebooted everything, but still no luck. After attempting to load the program, I am met with the same error screen others have mentioned that asks me to create a config file. I understand that since the config file exists, there must be some sort of error within the code, but after running it through both JSLint and JSHint, I haven’t found anything to be coming back as an error. Any ideas?
      The entire source code can be found below:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
          port: 8080,
          language: 'en',
          timeFormat: 24,
          units: 'metric',
          modules: [{
              module: 'alert',
              module: ‘wuforecast’,
              position: ‘top_right’, // This can be any of the regions.
              // Best results in left or right regions.
                  // See ‘Configuration options’ for more information.
                  appid: ‘abcde12345abcde12345abcde12345ab’ //wunderground.com API key.
              module: 'clock',
              position: 'top_left'
              module: 'calendar',
              header: 'US Holidays',
              position: 'top_left',
                  calendars: [{
                      symbol: 'calendar-check-o ',
                      url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
              module: 'compliments',
              position: 'lower_third'
              module: 'currentweather',
              position: 'top_right',
                  locationID: '', //ID from bulk.openweather.org/sample/
                  appid: 'YOUR_OPENWEATHER_API_KEY'
              module: 'weatherforecast',
              header: 'Weather Forecast',
                  locationID: '5128581', //ID from bulk.openweather.org/sample/
              module: 'newsfeed',
              position: 'bottom_bar',
                  feeds: [{
                      title: "New York Times",
                  showSourceTitle: true,
                  showPublishDate: true
      if (typeof module !== 'undefined') {
          module.exports = config;
      ADMIN NOTE: Please use markup for codeblock.
      • MichMichM Offline
        MichMich
        Copy paste your code into http://jshint.com and you’ll see why …
          dejayou @MichMich
          @MichMich
          Thank you for your swift response. I did copy and paste into JSHint and the only error note I received was specific to line 74 and “one undefined variable” the ‘module’ variable.
          This however is below the note exclaiming “do not edit the line below”. Should this actually read something different?
          • By Michael Teeuw http://michaelteeuw.nl
          • MIT Licensed.
            var config = {
            port: 8080,
            language: ‘en’,
            timeFormat: 24,
            units: ‘metric’,
            modules: [{
            module: ‘alert’,
            module: “wuforecast”,
            position: “top_right”, // This can be any of the regions.
            appid: “abcde12345abcde12345abcde12345ab” //wunderground.com API key.
            module: ‘clock’,
            position: ‘top_left’
            module: ‘calendar’,
            header: ‘US Holidays’,
            position: ‘top_left’,
            calendars: [{
            url: ‘webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics’
            module: ‘compliments’,
            position: ‘lower_third’
            module: ‘currentweather’,
            locationID: ‘’, //ID from bulk.openweather.org/sample/
            appid: ‘YOUR_OPENWEATHER_API_KEY’
            module: ‘weatherforecast’,
            header: ‘Weather Forecast’,
            locationID: ‘5128581’, //ID from bulk.openweather.org/sample/
            module: ‘newsfeed’,
            position: ‘bottom_bar’,
            feeds: [{
            title: “New York Times”,
            url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
          if (typeof module !== ‘undefined’) {
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @dejayou
            @dejayou i can find a couple of errors in your config
            module: 'alert',  // remove comma
            module: ‘wuforecast’, // you often used wrong single quotes
            module: ‘newsfeed’,
            feeds: [{
            }, ]  // remove comma
              dejayou
              Thanks Strawberry, I still seem to be having some issues and receiving the same error message even after I made these edits. Any chance you could take another quick look and see if anything here seems out of place?
              • MIT Licensed.
                var config = {
                port: 8080,
                language: ‘en’,
                timeFormat: 24,
                units: ‘metric’,
                modules: [{
                module: “alert”
                appid: “5095830b868b90bcc31affdad4911325” //wunderground.com API key.
                module: “clock”,
                position: “top_left”
                module: “calendar”,
                header: “US Holidays”,
                position: “top_left”,
                calendars: [{
                url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
                module: “compliments”,
                position: “lower_third”
                module: “currentweather”,
                locationID: “4614088”, //ID from bulk.openweather.org/sample/
                module: “weatherforecast”,
                header: “Weather Forecast”,
                module: “newsfeed”,
                position: “bottom_bar”,
                feeds: [{
              if (typeof module !== “undefined”) {
                @dejayou you’re still using the wrong ones
                    MIT Licensed.
                    var config = {
                    port: 8080,
                    language: 'en',
                    timeFormat: 24,
                    units: 'metric',
                    modules: [{
                    module: 'alert'
                    module: 'wuforecast',
                    position: 'top_right', // This can be any of the regions.
                    appid: '5095830b868b90bcc31affdad4911325' //wunderground.com API key.
                    module: 'clock',
                    module: 'calendar',
                    calendars: [{
                    locationID: '4614088', //ID from bulk.openweather.org/sample/
                    module: 'newsfeed',
                    feeds: [{
                    title: 'New York Times',
                    url: 'http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml'
                  dejayou
                  That’s odd. In the actual source code I am using the double quotes, but then in your yellow block text readout is somehow reverts back to single quotes in those same instances. Is this a Javascript thing?
                    dejayou @strawberry 3.141
                    @strawberry-3.141 So i’ve gone back through on the Linux system and checked that OS system and sure enough, when copying and pasting from a PC (here) and to a Linux, or vice versa, these quote marks have a tendency to alter.
                    At any rate, the code in the config file is now in a place where everything checks out ok in both the JSHint and JSLint tools, save for the last portion beneath the final line of demarcation where it reads not to edit the lines of code.
                    Here the error reads:
                    undeclared ‘module’.
                    unexpected ‘typeof’. Use ‘===’ to compare directly with undefined.
                    undeclared 'module"
                    Is this why the config file ultimately won’t be recognized by my raspberry pi/magic mirror program?
                    • K Offline
                      KirAsh4 Moderator
                      Do not copy/paste from one OS to another, the language translations between them will be different, UTF-8, Windows, it’s all foobar. Edit the config file ON the rpi. You can use the command 'nano' for that, as in 'nano config.js'. Doing the copy/paste is why your ‘'’, ‘"’ and others get translated wrong.
                        dejayou
                        Thanks KirAsh4. I am assuming that you meant to open the actual Terminal and edit the config file directly from within that environment, which is what I did with still no luck.
                        At this point I really don’t know what else to do. I am going to try and essentially start over from the beginning and see if I have better luck.
                        • K Offline
                          KirAsh4 Moderator
                          Yep, open Terminal and edit there, or use an SSH client remotely. The config is a bit finicky I discovered. Try not to change the layout too much, like for example, in your pastes above, I see this:
                          … in between modules. While I don’t think that would cause a problem, it also wouldn’t surprise me if that’s tripping up the parser. Keep them on separate lines:
                            dejayou
                            Hi KirAsh4 -
                            After walking back through this setup tutorial again (https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/) I am happy to report that I am no longer getting the error message asking about setting up a config file. Instead I now arrive at a blank black screen, absent any copy or modules. Do you know what might be causing this to occur?
                            • K Offline
                              KirAsh4 Moderator
                              Likely a bug recently discovered. Follow the instructions in the first post here to try the 'develop' branch:
                              https://forum.magicmirror.builders/topic/445/looking-for-beta-testers
                              • L Offline
                                L_i_v_e
                                This post is deleted!
