Update
How can this be fixed ? Not an expert on git …
pi@mirror:~/MagicMirror $ git pull && npm install D 19820 M css/custom.css M css/custom.css.org U modules/default/currentweather/currentweather.js Pull is not possible because you have unmerged files. Please, fix them up in the work tree, and then use 'git add/rm ' as appropriate to mark resolution, or use 'git commit -a'. pi@mirror:~/MagicMirror $ -
OK - I went to ~/MagicMirror directory and fired the gun …
pi@mirror:~/MagicMirror $ git stash Saved working directory and index state WIP on master: 5e622ca Merge branch 'master' of https://github.com/MichMich/MagicMirror HEAD is now at 5e622ca Merge branch 'master' of https://github.com/MichMich/MagicMirror pi@mirror:~/MagicMirror $ git pull && npm install remote: Counting objects: 70, done. remote: Compressing objects: 100% (24/24), done. remote: Total 70 (delta 38), reused 52 (delta 33), pack-reused 13 Unpacking objects: 100% (70/70), done. From https://github.com/MichMich/MagicMirror 8893df1..86ae704 develop -> origin/develop Already up-to-date. > magicmirror@2.1.2 install /home/pi/MagicMirror > cd vendor && npm install > magicmirror@2.1.2 postinstall /home/pi/MagicMirror > sh installers/postinstall/postinstall.sh MagicMirror installation successful! npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed. pi@mirror:~/MagicMirror $ git stash apply On branch master Your branch is ahead of 'origin/master' by 4 commits. (use "git push" to publish your local commits) Changes not staged for commit: ~/MagicMirror (use "git add ..." to update what will be committed) (use "git checkout -- ..." to discard changes in working directory) modified: css/custom.css modified: modules/default/currentweather/currentweather.js Untracked files: (use "git add ..." to include in what will be committed) css/custom.css.leo fonts/my_fonts/ no changes added to commit (use "git add" and/or "git commit -a") pi@mirror:~/MagicMirror $ -
It looks like you’ve made some changes to the currentweather modules’ source code.
If you want to keep your changes - this should do it
git stash git pull && npm install git stash applyIf you don’t need your changes to that file:
git checkout -- modules/default/currentweather/currentweather.js git pull && npm install -
Thanks for your reply.
It failed already on the first command …pi@mirror:~/MagicMirror $ git stash modules/default/currentweather/currentweather.js: needs merge modules/default/currentweather/currentweather.js: needs merge modules/default/currentweather/currentweather.js: unmerged (73774c3dcc4a780ac9c42142224ab3bbb65e1a3d) modules/default/currentweather/currentweather.js: unmerged (050917657a61f6edc56195e8f502ff2c67a322e2) modules/default/currentweather/currentweather.js: unmerged (ff34891ca2036ea844e0d4f511a551593cbbdd52) fatal: git-write-tree: error building trees Cannot save the current index state pi@mirror:~/MagicMirror $ -
@zkab If you know what changes you made to that file, it’s easier to do the second option above and then redo your changes. If you must try to keep your changes as is, try
git reset --mergefirst and then thegit stashsequence above, otherwise you can manually edit the file and look for the conflicts.Google, “git resolve failed merge” for what you’re looking for, or see below for an excerpt.
OK - what I did before I read you answer was … made a copy of my changes and issued ‘git reset --hard’ … and copied back the changed moduled and after that following:
git stash
git stash apply
but got some warnings … how do I get rid of this …- no such file or directory, open '/home/pi/MagicMirror/modules/package.json - this is not anything I have done
- what about Changes not staged for commit and Untracked files
pi@mirror:~/MagicMirror/modules/default/currentweather $ git stash Saved working directory and index state WIP on master: 5e622ca Merge branch 'master' of https://github.com/MichMich/MagicMirror HEAD is now at 5e622ca Merge branch 'master' of https://github.com/MichMich/MagicMirror pi@mirror:~/MagicMirror/modules/default/currentweather $ git pull && npm install Already up-to-date. npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json' npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json' npm WARN modules No description npm WARN modules No repository field. npm WARN modules No README data npm WARN modules No license field. pi@mirror:~/MagicMirror/modules/default/currentweather $ git stash apply On branch master Your branch is ahead of 'origin/master' by 4 commits. (use "git push" to publish your local commits) Changes not staged for commit: (use "git add ..." to update what will be committed) (use "git checkout -- ..." to discard changes in working directory) modified: ../../../css/custom.css modified: currentweather.js Untracked files: (use "git add ..." to include in what will be committed) ../../../css/custom.css.leo ../../../fonts/my_fonts/ no changes added to commit (use "git add" and/or "git commit -a") pi@mirror:~/MagicMirror/modules/default/currentweather $Still confused but at a higher level …
Make sure you’re in the
~/MagicMirrordirectory before running the command.what about Changes not staged for commit and Untracked files
Ignore them. For your purposes, you don’t need to worry about them as long as all the merge errors are gone.
@zkab Looks like everything worked to me for what you’re trying to do.
Please use the Markdown features to post code and console output. It makes it so much easier to read.
OK and thanks for your support …
