    Update
    10 Posts 3 Posters 6.0k Views 2 Watching
    • Z Offline
      zkab
      OK - what I did before I read you answer was … made a copy of my changes and issued ‘git reset --hard’ … and copied back the changed moduled and after that following:
      git stash
      git pull && npm install
      git stash apply
      but got some warnings … how do I get rid of this …
      1. no such file or directory, open '/home/pi/MagicMirror/modules/package.json - this is not anything I have done
      2. what about Changes not staged for commit and Untracked files
      pi@mirror:~/MagicMirror/modules/default/currentweather $ git stash
      Saved working directory and index state WIP on master: 5e622ca Merge branch 'master' of https://github.com/MichMich/MagicMirror
      HEAD is now at 5e622ca Merge branch 'master' of https://github.com/MichMich/MagicMirror
      pi@mirror:~/MagicMirror/modules/default/currentweather $ git pull && npm install
      Already up-to-date.
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
      npm WARN modules No description
      npm WARN modules No repository field.
      npm WARN modules No README data
      npm WARN modules No license field.
      pi@mirror:~/MagicMirror/modules/default/currentweather $ git stash apply
      On branch master
      Your branch is ahead of 'origin/master' by 4 commits.
        (use "git push" to publish your local commits)
        (use "git add ..." to update what will be committed)
        (use "git checkout -- ..." to discard changes in working directory)
      	modified:   ../../../css/custom.css
      	modified:   currentweather.js
      Untracked files:
        (use "git add ..." to include in what will be committed)
      	../../../css/custom.css.leo
      	../../../fonts/my_fonts/
      no changes added to commit (use "git add" and/or "git commit -a")
      Still confused but at a higher level …
        shbatm Module Developer
        Make sure you’re in the ~/MagicMirror directory before running the command.
        Ignore them. For your purposes, you don’t need to worry about them as long as all the merge errors are gone.
        • Z Offline
          zkab
          OK - I went to ~/MagicMirror directory and fired the gun …
          pi@mirror:~/MagicMirror $ git stash
          pi@mirror:~/MagicMirror $ git pull && npm install
          remote: Counting objects: 70, done.
          remote: Compressing objects: 100% (24/24), done.
          remote: Total 70 (delta 38), reused 52 (delta 33), pack-reused 13
          Unpacking objects: 100% (70/70), done.
          From https://github.com/MichMich/MagicMirror
             8893df1..86ae704  develop    -> origin/develop
          Already up-to-date.
          > magicmirror@2.1.2 install /home/pi/MagicMirror
          > cd vendor && npm install
          > magicmirror@2.1.2 postinstall /home/pi/MagicMirror
          > sh installers/postinstall/postinstall.sh
          MagicMirror installation successful!
          npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
          pi@mirror:~/MagicMirror $ git stash apply
          On branch master
          Changes not staged for commit: ~/MagicMirror
          	modified:   css/custom.css
          	modified:   modules/default/currentweather/currentweather.js
          Untracked files:
          	css/custom.css.leo
          	fonts/my_fonts/
            @zkab Looks like everything worked to me for what you’re trying to do.
            • bheplerB Offline
              bhepler Module Developer
              Please use the Markdown features to post code and console output. It makes it so much easier to read.
              • Z Offline
                zkab
                OK and thanks for your support …
