    Update
    10 Posts 3 Posters 6.0k Views 2 Watching
    • Z Offline
      zkab
      How can this be fixed ? Not an expert on git …
      pi@mirror:~/MagicMirror $ git pull && npm install
      D	19820
      M	css/custom.css
      M	css/custom.css.org
      U	modules/default/currentweather/currentweather.js
      Pull is not possible because you have unmerged files.
      Please, fix them up in the work tree, and then use 'git add/rm '
      as appropriate to mark resolution, or use 'git commit -a'.
      • Z Offline
        zkab
        OK - I went to ~/MagicMirror directory and fired the gun …
        pi@mirror:~/MagicMirror $ git stash
        Saved working directory and index state WIP on master: 5e622ca Merge branch 'master' of https://github.com/MichMich/MagicMirror
        HEAD is now at 5e622ca Merge branch 'master' of https://github.com/MichMich/MagicMirror
        remote: Counting objects: 70, done.
        remote: Compressing objects: 100% (24/24), done.
        remote: Total 70 (delta 38), reused 52 (delta 33), pack-reused 13
        Unpacking objects: 100% (70/70), done.
        From https://github.com/MichMich/MagicMirror
           8893df1..86ae704  develop    -> origin/develop
        Already up-to-date.
        > magicmirror@2.1.2 install /home/pi/MagicMirror
        > cd vendor && npm install
        > magicmirror@2.1.2 postinstall /home/pi/MagicMirror
        > sh installers/postinstall/postinstall.sh
        MagicMirror installation successful!
        npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
        pi@mirror:~/MagicMirror $ git stash apply
        On branch master
        Your branch is ahead of 'origin/master' by 4 commits.
          (use "git push" to publish your local commits)
        Changes not staged for commit: ~/MagicMirror
          (use "git add ..." to update what will be committed)
          (use "git checkout -- ..." to discard changes in working directory)
        	modified:   css/custom.css
        	modified:   modules/default/currentweather/currentweather.js
        Untracked files:
          (use "git add ..." to include in what will be committed)
        	css/custom.css.leo
        	fonts/my_fonts/
        no changes added to commit (use "git add" and/or "git commit -a")
          shbatm Module Developer
          It looks like you’ve made some changes to the currentweather modules’ source code.
          If you want to keep your changes - this should do it
          git stash
          git stash apply
          If you don’t need your changes to that file:
          git checkout -- modules/default/currentweather/currentweather.js
          • Z Offline
            zkab
            Thanks for your reply.
            It failed already on the first command …
            modules/default/currentweather/currentweather.js: needs merge
            modules/default/currentweather/currentweather.js: unmerged (73774c3dcc4a780ac9c42142224ab3bbb65e1a3d)
            modules/default/currentweather/currentweather.js: unmerged (050917657a61f6edc56195e8f502ff2c67a322e2)
            modules/default/currentweather/currentweather.js: unmerged (ff34891ca2036ea844e0d4f511a551593cbbdd52)
            fatal: git-write-tree: error building trees
            Cannot save the current index state
              @zkab If you know what changes you made to that file, it’s easier to do the second option above and then redo your changes. If you must try to keep your changes as is, try git reset --merge first and then the git stash sequence above, otherwise you can manually edit the file and look for the conflicts.
              Google, “git resolve failed merge” for what you’re looking for, or see below for an excerpt.
              • Z Offline
                zkab
                OK - what I did before I read you answer was … made a copy of my changes and issued ‘git reset --hard’ … and copied back the changed moduled and after that following:
                git stash
                git stash apply
                but got some warnings … how do I get rid of this …
                1. no such file or directory, open '/home/pi/MagicMirror/modules/package.json - this is not anything I have done
                2. what about Changes not staged for commit and Untracked files
                pi@mirror:~/MagicMirror/modules/default/currentweather $ git stash
                pi@mirror:~/MagicMirror/modules/default/currentweather $ git pull && npm install
                Already up-to-date.
                npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
                npm WARN modules No description
                npm WARN modules No repository field.
                npm WARN modules No README data
                npm WARN modules No license field.
                pi@mirror:~/MagicMirror/modules/default/currentweather $ git stash apply
                On branch master
                	modified:   ../../../css/custom.css
                	modified:   currentweather.js
                Untracked files:
                	../../../css/custom.css.leo
                	../../../fonts/my_fonts/
                Still confused but at a higher level …
                  Make sure you’re in the ~/MagicMirror directory before running the command.
                  Ignore them. For your purposes, you don’t need to worry about them as long as all the merge errors are gone.
                  • Z Offline
                    zkab
                    Already up-to-date.
                    On branch master
                    Untracked files:
                    	css/custom.css.leo
                    	fonts/my_fonts/
                      @zkab Looks like everything worked to me for what you’re trying to do.
                      • bheplerB Offline
                        bhepler Module Developer
                        Please use the Markdown features to post code and console output. It makes it so much easier to read.
                        • Z Offline
                          zkab
                          OK and thanks for your support …
