    Update
    10 Posts 3 Posters 5.8k Views 2 Watching
    • Z Offline
      zkab
      Thanks for your reply.
      It failed already on the first command …
      pi@mirror:~/MagicMirror $ git stash
      modules/default/currentweather/currentweather.js: needs merge
      modules/default/currentweather/currentweather.js: unmerged (73774c3dcc4a780ac9c42142224ab3bbb65e1a3d)
      modules/default/currentweather/currentweather.js: unmerged (050917657a61f6edc56195e8f502ff2c67a322e2)
      modules/default/currentweather/currentweather.js: unmerged (ff34891ca2036ea844e0d4f511a551593cbbdd52)
      fatal: git-write-tree: error building trees
      Cannot save the current index state
        shbatm Module Developer
        @zkab If you know what changes you made to that file, it’s easier to do the second option above and then redo your changes. If you must try to keep your changes as is, try git reset --merge first and then the git stash sequence above, otherwise you can manually edit the file and look for the conflicts.
        Google, “git resolve failed merge” for what you’re looking for, or see below for an excerpt.
        • Z Offline
          zkab
          OK - what I did before I read you answer was … made a copy of my changes and issued ‘git reset --hard’ … and copied back the changed moduled and after that following:
          git stash
          git pull && npm install
          git stash apply
          but got some warnings … how do I get rid of this …
          1. no such file or directory, open '/home/pi/MagicMirror/modules/package.json - this is not anything I have done
          2. what about Changes not staged for commit and Untracked files
          pi@mirror:~/MagicMirror/modules/default/currentweather $ git stash
          Saved working directory and index state WIP on master: 5e622ca Merge branch 'master' of https://github.com/MichMich/MagicMirror
          HEAD is now at 5e622ca Merge branch 'master' of https://github.com/MichMich/MagicMirror
          pi@mirror:~/MagicMirror/modules/default/currentweather $ git pull && npm install
          Already up-to-date.
          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
          npm WARN modules No description
          npm WARN modules No repository field.
          npm WARN modules No README data
          npm WARN modules No license field.
          pi@mirror:~/MagicMirror/modules/default/currentweather $ git stash apply
          On branch master
          Your branch is ahead of 'origin/master' by 4 commits.
            (use "git push" to publish your local commits)
            (use "git add ..." to update what will be committed)
            (use "git checkout -- ..." to discard changes in working directory)
          	modified:   ../../../css/custom.css
          	modified:   currentweather.js
          Untracked files:
            (use "git add ..." to include in what will be committed)
          	../../../css/custom.css.leo
          	../../../fonts/my_fonts/
          no changes added to commit (use "git add" and/or "git commit -a")
          Still confused but at a higher level …
            Make sure you’re in the ~/MagicMirror directory before running the command.
            Ignore them. For your purposes, you don’t need to worry about them as long as all the merge errors are gone.
            • Z Offline
              zkab
              OK - I went to ~/MagicMirror directory and fired the gun …
              pi@mirror:~/MagicMirror $ git pull && npm install
              remote: Counting objects: 70, done.
              remote: Compressing objects: 100% (24/24), done.
              remote: Total 70 (delta 38), reused 52 (delta 33), pack-reused 13
              Unpacking objects: 100% (70/70), done.
              From https://github.com/MichMich/MagicMirror
                 8893df1..86ae704  develop    -> origin/develop
              Already up-to-date.
              > magicmirror@2.1.2 install /home/pi/MagicMirror
              > cd vendor && npm install
              > magicmirror@2.1.2 postinstall /home/pi/MagicMirror
              > sh installers/postinstall/postinstall.sh
              MagicMirror installation successful!
              npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
              pi@mirror:~/MagicMirror $ git stash apply
              On branch master
              Changes not staged for commit: ~/MagicMirror
              	modified:   css/custom.css
              	modified:   modules/default/currentweather/currentweather.js
              Untracked files:
              	css/custom.css.leo
              	fonts/my_fonts/
                @zkab Looks like everything worked to me for what you’re trying to do.
                • bheplerB Offline
                  bhepler Module Developer
                  Please use the Markdown features to post code and console output. It makes it so much easier to read.
                  • Z Offline
                    zkab
                    OK and thanks for your support …
