    Countdown Module?
    8 Posts 4 Posters 5.0k Views 4 Watching
    • L Offline
      LittleFirework
      Hi there.
      I’m looking for a module that can display the following information:
      How many months left of the year
      How many weeks left of the year
      How many days left of the year
      How many hours left of the year
      How many minutes left of the year
      How many seconds left of the year
      Is this possible?
        mydiva
        Hi @LittleFirework Take this module doomsday and change a few lines…0_1499777645940_Bildschirmfoto 2017-07-11 um 14.52.26.png
          jasondreher
          Can you post your changes? I would love to have this countdown to the second.
            mydiva
            Module.register("MMM-doomsDay", {
                // Default module config.
                defaults: {
                    doomsDay: "2018-03-01 24:00:00", // YYYY-MM-DD HH:MM:SS
                    updateInterval: 60 * 60 * 1000,
                    toWhat: "Leaving for Paris!",
                    singular: "Left ",
                    plural: "Left",
                    present: "Let's Fly!",
                    timesUp: "death and despair, your time is up."
                // Define start sequence.
                start: function() {
                    var self = this;
                    Log.info("Starting module: " + this.name);
                    if (this.config.updateInterval < 10 * 60 * 1000) {
                        // 10 min minimum update interval
                        this.config.updateInterval = 10 * 60 * 1000;
                    setInterval(function() {
                        self.updateDom();
                    }, this.config.updateInterval);
                // Define required styles
                getStyles: function () {
                    return ["MMM-doomsDay.css"];
                // Override dom generator.
                getDom: function() {
                    var doomsDay = new Date(this.config.doomsDay);
                    var now = new Date();
                    var timeparser = Date.parse(doomsDay) - Date.parse(now);
                    var weeks = Math.floor(timeparser / (1000 * 60 * 60 * 24 * 7));
                    var days = Math.floor((timeparser % (1000 * 60 * 60 * 24 * 7)) / (1000 * 60 * 60 * 24));
                    var hours = Math.floor((timeparser % (1000 * 60 * 60 * 24)) / (1000 * 60 * 60));
                    var minutes = Math.floor((timeparser % (1000 * 60 * 60)) / (1000 * 60));
                    var seconds = Math.floor((timeparser % (1000 * 60)) / 1000);
                    daysLeft = weeks + " Wochen " + days + " Tage " + hours + " Stunden " + minutes + " Minuten " + seconds + " Sekunden ";;
                    //daysLeft = Math.floor(timeparser/(1000*60*60*24));
                    var headerD = document.createElement("span");
                    headerD.innerHTML = this.config.toWhat + "<br />";
                    headerD.className = "doooom";
                    if (daysLeft == 0) {
                        var daysLeft = document.createElement("span")
                        timeLeft.innerHTML = this.config.present;
                        timeLeft.className = "timeLeft";
                    else if (daysLeft == 1) {
                      var timeLeft = document.createElement("span");
                      timeLeft.innerHTML = daysLeft + " " + this.config.singular;
                    else if (daysLeft >= 2) {
                        timeLeft.innerHTML = daysLeft + " " + this.config.plural;
                    else {
                    wrapper.appendChild(headerD);
                    wrapper.appendChild(timeLeft);
                    return wrapper;
              mydiva
              config:
                  			module: 'MMM-doomsDay',
                  			position: 'bottom_right', // This can be any of the regions, best results in center regions
                      			doomsDay: "2018-02-09 12:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                      			updateInterval: 1000 * 60 * 60 * 4,
              				toWhat: "Your text",
                      			singular: '',
              				plural: '',
                mydiva
                I know this is not really a nice code because I’m a noob… but it works ;o)
                  jasondreher
                  Fantastic, worked for me, thanks!!!
                  • cowboysdudeC Offline
                    cowboysdude Module Developer
                    Here is what I did to get the seconds actually ‘ticking’ instead of just sitting there:
                    Module.register("MMM-CountDown", {
                        defaults: {
                            updateInterval: 1000,
                            singular: "Left ",
                            plural: "Left",
                        start: function() {
                            var self = this;
                                self.updateDom();
                            return ["MMM-CountDown.css"];
                            if (this.config.updateInterval == 1000) {
                             daysLeft = weeks + " W " + days + " D " + hours + " H " + minutes + " M " + seconds + " S ";
                             } else {
                            daysLeft = weeks + " W " + days + " D " + hours + " H " + minutes + " M ";
                            else {
                            return wrapper;
                    And in your config file change your updateInterval to 1000 if you want it to actually tick seconds or use the other format and it will not show the seconds because it just updates when the interval was called so instead of seeing
                    S 20… then update S 7…
                    It looks much cleaner to either have the seconds and they work or don’t have them… just my 2 cents… but the above code will make the seconds actually work.
