Default MagicMirror clock config timezone error
5 Posts 3 Posters 3.2k Views 3 Watching
    Adaman134
    So I have been trying to switch the timezone in the clock.js file for the default MM clock module to New York
    I changed the timezone under analog clock to America/New_York as instructed in the module and then the clock doesn’t show up anymore
    I am using the clock in digital but I can’t find a specific timezone setting for digital
    Am I typing the timezone wrong?
    thanks,
    Adam
    If you need more information let me know
    S 1 Reply Last reply Jul 24, 2017, 1:42 PM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @Adaman134
      @Adaman134 you shouldn’t touch the clock.js file, instead do the changes in your config file
      	module: "clock",
      		timezone: 'America/New_York'
      if you are in new york you don’t have to do this at all, I would recommend to set your rpi timezone correctly instead.
        Adaman134
        Ok thank you, so for all the modules I should be changing it in the config.js file? So if it says I can change something like for this clock make it digital or analog I should add that line to the config.js under that module?
        M 1 Reply Last reply Jul 24, 2017, 4:03 PM Reply Quote 0
          Mykle1 Project Sponsor Module Developer @Adaman134
          @Adaman134
          Yes, every module should come with a readme file that describes the options that you can manage. All of these options should be managed in the config file entry for each module. Editing the module.js files is not recommended.
          A 1 Reply Last reply Jul 24, 2017, 4:27 PM Reply Quote 1
            Adaman134 @Mykle1
            @Mykle1 ok thank you very much now I understand :)
