    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 223.7k Views 38 Watching
      dmcinnes Module Developer
      This module adds super localized, up to the minute weather using the forecast.io API – the same service that powers the Dark Sky App.
      It will tell you exactly when the rain will start or stop.
      screenshot
      https://github.com/dmcinnes/MMM-forecast-io
      • I Offline
        ianperrin
        @dmcinnes - Looks good.
        There was a fork(?) of the original Magic Mirror (version 1) code which replaced the standard weather module using data from Dark Sky’s forecast.io API - see https://github.com/jangellx/MagicMirror
        This included a graph of temperature/rain, a forecast for the week ahead and a summary of current weather - see https://github.com/jangellx/MagicMirror#important-installation-note
        alt text
        Code seems to be contained in https://github.com/dmcinnes/MMM-forecast-io/blob/master/MMM-forecast-io.js
        Any chance your MM² module could be extended to include this too?
        "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
          Wow that looks great! Particularly the weather forecast.
          I looked at creating a graph since the data is all right there in the response. I might as well see I can port the code over to this module!
          L 1 Reply Last reply Reply Quote 1
            Forecast.io API has been rebranded as darksky.net: http://blog.darksky.net/introducing-darksky-net/
            I’ve updated this module with the default URLs, otherwise it doesn’t seem to support the redirect properly.
            I’m continuing to work on this module, more soon!
            • L Offline
              Les @dmcinnes
              @dmcinnes said in MMM-forecast-io -- Localized up to the minute weather:
              Just wanted to say thanks for the great module, and ask if you were planning on implementing the graph like the abovepicture? As it looks really awesome!
                dmcinnes Module Developer @Les
                @Les sure thing! I am working on a precipitation graph and I have a forecast set up. Check out the weather-forecast branch for a work in progress:
                https://github.com/dmcinnes/MMM-forecast-io/tree/weather-forecast
                • L Offline
                  Les
                  @dmcinnes Testing it out. Got 2 questions…
                  1. is it possible to activate the chart yet? (if so how)
                  2. does the 7 day forecast work? I have showForcast: “true” in config.js but it is not displayed. Is there something else I have to set?
                    @Les the rain graph should show up when the API responds with “minutely”, when there’s minute-by-minute rain data.
                    Not sure why the forecast isn’t showing, it should appear by default. I’ll have to look at it later today.
                    • L Offline
                      Les
                      Just for reference, this is what i have in config.js
                                          module: 'MMM-forecast-io',
                                          position: 'top_right',
                                            showForecast: 'true',
                                            apiKey: 'keyvalue',  // Dark Sky $
                                            // Only required if geolocation doesn't work:
                                            latitude:   43.955907,
                                            longitude: -78.906245,
                                              updateInterval: 600000
                      Note from admin: Please use Markdown on code snippets for easier reading!
                      • P Offline
                        paulocarrasco
                        Hi, I’m trying to use this module but it keep showing an error on the config file.
                        Here is the code->
                              position: 'top_right',  // This can be any of the regions.
                                apiKey: 'my api key' // Dark Sky API key.
                                latitude:   37.1468,
                                longitude: -8.5846
                        When I remove this code part the config works, so all the rest is ok.
                        I already have cloned the module on git to the newest version.
                        Can someone help me?..
                        idoodlerI 1 Reply Last reply Reply Quote 0
                        • yawnsY Offline
                          yawns Moderator
                          There is a comma missing after your apiKey
                            @Les make sure you’re on the right branch:
                            git checkout weather-forecast
                            • P Offline
                              paulocarrasco @yawns
                              @yawns Thanks, it was the comma. I miss it.
                              • L Offline
                                Les @dmcinnes
                                @dmcinnes I was in the main branch. Now I got the graph and full forecast…Thanks!
                                I don’t know if this is because your still working on it, or whether it’s just my setup but the days are on top of the icons. If it’s just my setup then I’m guessing adding some padding in the css file would do the trick.
                                  @Les yeah still working on it :) My testing config file had the “small” class, though I’m surprised it looks so bad without it.
                                    @Les thanks for the screenshot!
                                    • L Offline
                                      Les @dmcinnes
                                      @dmcinnes No Problem. Thanks for the great module…can’t wait to see it when it’s complete. :)
                                      • P Offline
                                        paulocarrasco
                                        Can’t wait for the finished weather module ;-).
                                        I’ve been thinking about screen optimisation and I’ve tried working on module code to make something like this “photoshopped” image, but my skills on JS are very, very limited :-(.
                                        I think that would be a nice add-on a “fusion” of the MMM-moon-phases module (with a bigger moon image), a analog clock (with a minimalist face) and the a weather/forecast module.
                                        What do you think?
                                        • L Offline
                                          Les @paulocarrasco
                                          @paulocarrasco said in MMM-forecast-io -- Localized up to the minute weather:
                                          What do you think?
                                          Just my 2 cents, but the picture looks amazing. I also like that you showed a few temperatures from later in the day before giving the future day forecasts. Daily percipitation % is also a great idea. :)
                                          However, for the purpose of screen real estate may I suggest making things switchable (on/off). So for example, date/time at the top. then moon/analog cloock. Then current weather, then forecast. So people can pick what is important to them… And this is just me, but I like having the current weather at the top So the moon/clock is distracting to me. if I could move it (I know I’m asking for a lot…but if I could move it to the bottom…would look great, and still give me info in the order of priority I need.) Anyways, just take this as once persons views :) Good luck with your module, can’t wait to see it when it’s complete!
                                          • P Offline
                                            plumcraft
                                            Looking forward to try this module too. It looks very nice
                                            • 6
                                            • 7
                                            • 1 / 7
