    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 241.0k Views 38 Watching
    • C Offline
      ChickenBeard
      Is it possible to have the precipitation graph ONLY? I enabled it (and disabled the general “Forecast”). But it seems like the graph doesn’t update. It will load the “current” graph and just stay there until I restart MM.
      • lavolp3L Offline
        lavolp3 Module Developer @ChickenBeard
        @ChickenBeard How did you disable the forecast? Via CSS or by commenting it out in the code?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • C Offline
          ChickenBeard @lavolp3
          @lavolp3 in ~/MagicMirror/config/config.js:
          module: 'MMM-forecast-io',
                                 disabled:false,
                                 position: 'bottom_center',  // This can be any of the regions.
                                         apiKey: 'xxxxx', // Dark Sky API key.
                                         // Only required if geolocation doesn't work:
                                         latitude:   xxxx,
                                         longitude: xxxx,
                                         ***enablePrecipitationGraph: true,***
                                         ***showForecast:false,***
                                         precipitationGraphWidth: 325,
                                         showWind: false,
                                         showSunriseSunset: false,
                                         ***alwaysShowPrecipitationGraph:true,***
          • lavolp3L Offline
            @ChickenBeard I can’t see why it wouldn’t update. showForecast only determines if the forecast div is added to the DOM. I have currently no idea.
            Any error messages in the console?
            Maybe try
            debug: true
            in the config?
            • C Offline
              @lavolp3 Will do! Which log does it write to?
              • lavolp3L Offline
                @ChickenBeard usually this gives extended output to the server-side console in case of node_helper.js or to the browser console in case of the MMM-forecast-io.js.
                • lavolp3L Offline
                  For anyone interested:
                  I have played around with this module quite intensively, implemented the chartjs library and did a few other tweaks and it looks like this now on my mirror.
                  https://imgur.com/ZqJBGLp
                  https://imgur.com/JmxnJ3p
                  Most important changes:
                  • the graph now shows several things:
                    – cloud cover in the background
                    – day and night cycle through different colors
                    – rain amount in the foreground
                  • temperature bars are colored according to temperature scale (currently only °C)
                  • rain amount instead of rain percentage for daily forecast
                  Anyone interested can try out my fork
                  https://github.com/lavolp3/MMM-forecast-io
                  If you install it, don’t forget to do a npm install in the module folder after cloning the module. The Readme has not yet been brought up to date.
                  • 6
                  • 7
                  • 7 / 7
