JSON-RPC need help
i´m a beginner with javascipt and need help . how can i call the json-rpc function ( getData ) to get
data from API and how can i parse it, to display the result an MM.
the result of the call should be an JSON-RPC string .getData : function(){ var self = this; var json = "http://xxx.xxx.xxx.xxx:3777/api/"; var retry = true; var HTTP = new XMLHttpRequest(); HTTP.open("POST",json,true); var rpc = JSON.stringify({"jsonrpc":"2.0", "method":"GetValue", "params":[18697], "id":0}); HTTP.setRequestHeader("Content-type", "application/json"); HTTP.send(rpc); },Thanks Thomas
@tbe You need to add an event listener to react to the response. example:
HTTP.onreadystatechange = function() { if (HTTP.readyState == 4 && HTTP.status == 200) { //response complete and OK //do something with HTTP.response; } else if (HTTP.readyState == 4) { //response complete but some error console.log("Error: " + HTTP.status + " " + HTTP.statusText); } }Alternatively you can add individual event listeners for different states:
HTTP.addEventListener("progress", updateProgress); HTTP.addEventListener("load", transferComplete); HTTP.addEventListener("error", transferFailed); HTTP.addEventListener("abort", transferCanceled);Full documentation on the XMLHttpRequest object here:
https://developer.mozilla.org/en/docs/Web/API/XMLHttpRequest -
Thanks. But i have an other problem.
The JSON request works per curl on console, but in js : "net::ERR_EMPTY_RESPONSE "Curl : curl -i -X POST -H "Content-Type: application/json" -d "{\"jsonrpc\": \"2.0\", \"id\": \"0\", \"method\": \"GetValue\", \"params\": [18697]}" http://xxx.xxx.x.xx:3777/api/but in the MM-JS-Script don´t work. Looks like the json parameter don´t work.
