    Updating Compliments using a spreadsheet
    14 Posts 4 Posters 5.6k Views 4 Watching
      bwente
      I just discovered MagicMirror last week and got things setup this weekend. It has been a blast trying out new modules. A big thank you to everyone in the community that has given their time.
      I am not a programmer and not much for command line. But I can follow instructions and copy and paste. I was looking for ways to update my mirror without having to touch terminal. I wanted an easy way to update my Compliments without making an JSON file by hand. I setup a new google sheets document.
      Then published it.
      It turns out the JSON that google exports is not the JSON that Compliments needs. I tired my hand at jquery and html and got it to create the same format in the browser. But what is rendered in the browser window isn’t JSON either, it looks like it but it isn’t. I tried specifying the remotefile path as the html file that I made didn’t work.
      I then tried writing to the file system and javascript can’t do that in the browser either. Then I discovered that node.js can write a file. I converted my jquery JSON looper into a node file.
      I started this morning with my first javascript, and this afternoon my first node.js, now tonight I am trying to figure out how to best make it work. I have to manually run
      node remotefile.js
      config.js
           module: 'compliments',
           position: 'lower_third',
      	 remoteFile: 'remotefile.json'
      And finally my noob code…
      'use strict';
      var request = require('request');
      var url = 'https://spreadsheets.google.com/feeds/list/YOUR_SECRET_SHEET_LINK_ID/od6/public/values?alt=json';
      var compliments = '';
      var anytime = '';
      var morning = '';
      var afternoon = '';
      var evening = '';
      request.get({
          url: url,
          json: true,
          headers: { 'User-Agent': 'request' }
      }, (err, res, data) => {
          if (err) {
              console.log('Error:', err);
          } else if (res.statusCode !== 200) {
              console.log('Status:', res.statusCode);
          } else {
              // data is already parsed as JSON:
              var entry = data.feed.entry;
              // anytime column
              anytime += '\t"anytime" : [\r\n';
              for (var i = 0; i < entry.length; i++) {
                  if (entry[i]['gsx$anytime']['$t']) {
                      anytime += '\t\t"' + entry[i]['gsx$anytime']['$t'] + '",\r\n';
              anytime = anytime.replace(/,\s*$/, "") + '\r\n';
              anytime += '\t],\r\n';
              // morning column
              morning += '\t"morning" : [\r\n';
                  if (entry[i]['gsx$morning']['$t']) {
                      morning += '\t\t"' + entry[i]['gsx$morning']['$t'] + '",\r\n';
              morning = morning.replace(/,\s*$/, "") + '\r\n';
              morning += '\t],\r\n';
              // afternoon column
              afternoon += '\t"afternoon" : [\r\n';
                  if (entry[i]['gsx$afternoon']['$t']) {
                      afternoon += '\t\t"' + entry[i]['gsx$afternoon']['$t'] + '",\r\n';
              afternoon = afternoon.replace(/,\s*$/, "") + '\r\n';
              afternoon += '\t],\r\n';
              // evening column
              evening += '\t"evening" : [\r\n';
                  if (entry[i]['gsx$evening']['$t']) {
                      evening += '\t\t"' + entry[i]['gsx$evening']['$t'] + '",\r\n';
              evening = evening.replace(/,\s*$/, "") + '\r\n';
              evening += '\t]';
              compliments = '{\r\n' + anytime + morning + afternoon + evening + '\r\n}';
              var fs = require('fs');
              fs.writeFile("remotefile.json", compliments, function(err) {
                  if (err) {
                      return console.log(err);
                  console.log("The file was saved!");
      I know the code could be a lot better. I also know I could use PHP to make it easier (just return JSON from the url). What would be the best MagicMirror way?
      strawberry 3.141S 1 Reply Last reply Reply Quote 1
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @bwente
        @bwente can you post the data structure you are receiving from spreadsheet?
          bwente @strawberry 3.141
          @strawberry-3.141
          Google being very through with their JSON…
            "version": "1.0",
            "encoding": "UTF-8",
            "feed": {
              "xmlns": "http://www.w3.org/2005/Atom",
              "xmlns$openSearch": "http://a9.com/-/spec/opensearchrss/1.0/",
              "xmlns$gsx": "http://schemas.google.com/spreadsheets/2006/extended",
              "id": {
                "$t": "https://spreadsheets.google.com/feeds/list/YOUR_SECRET_SHEET_LINK_ID/od6/public/values"
              "updated": {
                "$t": "2017-08-14T03:28:11.565Z"
              "category": [
                  "scheme": "http://schemas.google.com/spreadsheets/2006",
                  "term": "http://schemas.google.com/spreadsheets/2006#list"
              "title": {
                "type": "text",
                "$t": "Sheet1"
              "link": [
                  "rel": "alternate",
                  "type": "application/atom+xml",
                  "href": "https://docs.google.com/spreadsheets/d/YOUR_SECRET_SHEET_LINK_ID/pubhtml"
                  "rel": "http://schemas.google.com/g/2005#feed",
                  "href": "https://spreadsheets.google.com/feeds/list/YOUR_SECRET_SHEET_LINK_ID/od6/public/values"
                  "rel": "http://schemas.google.com/g/2005#post",
                  "rel": "self",
                  "href": "https://spreadsheets.google.com/feeds/list/YOUR_SECRET_SHEET_LINK_ID/od6/public/values?alt=json"
              "author": [
                  "name": {
                    "$t": "bwente"
                  "email": {
                    "$t": "bwente@email.com"
              "openSearch$totalResults": {
                "$t": "3"
              "openSearch$startIndex": {
                "$t": "1"
              "entry": [
                  "id": {
                    "$t": "https://spreadsheets.google.com/feeds/list/YOUR_SECRET_SHEET_LINK_ID/od6/public/values/cokwr"
                  "updated": {
                  "category": [
                  "title": {
                    "type": "text",
                    "$t": "How you doing?"
                  "content": {
                    "type": "text",
                    "$t": "morning: Good morning, sunshine!, afternoon: Hitting your stride!, evening: You made someone smile today, I know it."
                  "link": [
                      "rel": "self",
                      "href": "https://spreadsheets.google.com/feeds/list/YOUR_SECRET_SHEET_LINK_ID/od6/public/values/cokwr"
                  "gsx$anytime": {
                  "gsx$morning": {
                    "$t": "Good morning, sunshine!"
                  "gsx$afternoon": {
                    "$t": "Hitting your stride!"
                  "gsx$evening": {
                    "$t": "You made someone smile today, I know it."
                  "id": {
                    "$t": "https://spreadsheets.google.com/feeds/list/YOUR_SECRET_SHEET_LINK_ID/od6/public/values/cpzh4"
                  "updated": {
                  "category": [
                  "title": {
                    "type": "text",
                    "$t": "Row: 3"
                  "content": {
                    "type": "text",
                    "$t": "morning: Who needs coffee when you have your smile?, afternoon: You are making a difference!, evening: You are making a difference."
                  "link": [
                      "rel": "self",
                      "href": "https://spreadsheets.google.com/feeds/list/YOUR_SECRET_SHEET_LINK_ID/od6/public/values/cpzh4"
                  "gsx$anytime": {
                    "$t": ""
                  "gsx$morning": {
                    "$t": "Who needs coffee when you have your smile?"
                  "gsx$afternoon": {
                    "$t": "You are making a difference!"
                  "gsx$evening": {
                    "$t": "You are making a difference."
                  "id": {
                    "$t": "https://spreadsheets.google.com/feeds/list/YOUR_SECRET_SHEET_LINK_ID/od6/public/values/cre1l"
                  "updated": {
                  "category": [
                  "title": {
                    "type": "text",
                    "$t": "Row: 4"
                  "content": {
                    "type": "text",
                    "$t": "morning: Go get 'em, Tiger!, afternoon: You're more fun than bubble wrap!, evening: The day was better for your efforts."
                  "link": [
                      "rel": "self",
                      "href": "https://spreadsheets.google.com/feeds/list/YOUR_SECRET_SHEET_LINK_ID/od6/public/values/cre1l"
                  "gsx$anytime": {
                    "$t": ""
                  "gsx$morning": {
                    "$t": "Go get 'em, Tiger!"
                  "gsx$afternoon": {
                    "$t": "You're more fun than bubble wrap!"
                  "gsx$evening": {
                    "$t": "The day was better for your efforts."
          • E Offline
            emrah_asl
            Hi, where did you write this code ? When I try write on “compliments.js” my console does not recognize ‘require’ tag. Could you please share fullcode ?
              sdetweil @emrah_asl
              @emrah_asl the modulename.js does not allow require(). as it runs inside the browser. anything needing require() must be done in the node_helper.js, and the two parts must send data back and forth with socketNotifications per the mm spec.
              • E Offline
                emrah_asl
                Hi @sdetweil thanks I missed up
                , so what should I customize compliment.js ?
                Here is my change on compliement.js
                remoteFile: "remotefile.json",
                I created my json link and create node_helper.js file and put my folder with these codes.
                But I think I missed somethings, it doesn’t work, and there is no file creation on folder called “remotefile.json”
                  sdetweil @emrah_asl
                  @emrah_asl well, what does the node_helper do? there is a specific structure to that file, as it is a program under mm as part of a module. if u created it as a standalone pgm, then it won’t work like u want.
                  • E Offline
                    emrah_asl @sdetweil
                    @sdetweil after I created node__helper.js manually, then I typed ‘npm start’ , the file has created, bu this time there was electron error (MM closed) interesting.
                      sdetweil @emrah_asl
                      @emrah_asl yeh, that won’t work
                      • E Offline
                        emrah_asl
                        @sdetweil so, what is formula to run this ? what do you think acording your experience ?
                          sdetweil @emrah_asl
                          @emrah_asl well, the problem is coming up w something u have the skills to do.
                            sdetweil
                            so, thinking more.
                            do you have a js routine that will download the sheet in json and convert to the proper format now? you would execute it with
                            node ???whatever your script name is???
                            if so, you could add it to the installers/mm.sh script that is used by pm2 to start mm.
                            this way every time mm is started, you would download the new compliments file sheet and convert it
                            • E Offline
                              emrah_asl
                              Hi @sdetweil ,
                              Thanks for reply.
                              my code in node_helper.js (under compliments folder) are creating file on root normally when you start mm with npm start
                              The problems are,
                              1 - I need to change save folder not root side, it needs to be under compliements folder, so I change this but not works
                                      fs.writeFile("modules/default/compliments/remotefile.json", compliments, function(err) {
                                          if (err) {
                              1. The second problem , my magic mirror fires electron.js error when I try to create file. I’m new on these, how can i use mm.sh for create&locate remotefile.json under compliments folder ?
                                sdetweil @emrah_asl
                                @emrah_asl said in Updating Compliments using a spreadsheet:
                                1. my code in node_helper.js (under compliments folder) are creating file on root normally when you start mm with npm start
                                don’t make this node_helper.js as MM has a special use for that…
                                make it createCompliments.js
                                then the best thing is use the full path for the file
                                     fs.writeFile("/home/pi/MagicMirror/modules/default/compliments/remotefile.json", compliments, function(err) {
                                how do you start MM?
                                pm2 start 0 (and it starts on boot too…) If you used the automated install script u would have been prompted to set this up.
                                (if u want to add it now, you can run the fixuppm2.sh script from here
                                just one line to copy/paste
                                now, if you use pm2, it launches MM by using the installers/mm.sh script. you can add your
                                node modules/default/compliments/createCompliments.js
                                to the mm.sh and all will continue as normal.
                                i don’t understand this.
                                npm start fires electron.js
                                npm reads the package,json file and looks for the command requested
                                	"scripts": {
                                		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                                the ‘start’ command executes that line.
