Problem after installing MM on Pi Zero W
Hey ,
I have installed MM on mir Pi Zero W with this tutorial :
after that my Pi output is :
pi@magicmirror:~/MagicMirror $ npm start > magicmirror@2.1.2 start /home/pi/MagicMirror > sh run-start.sh /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory npm ERR! Linux 4.9.35+ npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start" npm ERR! node v4.2.1 npm ERR! npm v2.14.7 npm ERR! file sh npm ERR! code ELIFECYCLE npm ERR! errno ENOENT npm ERR! syscall spawn npm ERR! magicmirror@2.1.2 start: `sh run-start.sh` npm ERR! spawn ENOENT npm ERR! npm ERR! Failed at the magicmirror@2.1.2 start script 'sh run-start.sh'. npm ERR! This is most likely a problem with the magicmirror package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! sh run-start.sh npm ERR! You can get their info via: npm ERR! npm owner ls magicmirror npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /home/pi/MagicMirror/npm-debug.logBut the Midori starts and says that there is no config.js file. So it seems to be running ?!?
If I move the config.js.sample to config.js the Midori screen ist completley black…
Could please someone help me
@abergy said in Problem after installing MM on Pi Zero W:
You are missing some linux libraries. Look at this line:/home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
It says it is missing library libgconf-2.so.4, install it with
sudo apt-get install libgconf-2-4.You are probably missing more libraries but it will only show 1 error at a time. So execute above command and then rerun MM. Look for the next missing library and install that. I had this error too and I was missing two libraries, I can’t remember what the other was tho.
Hey @Ultimatum22 ,
thank you very much.
I was missing two libaries as you said :
- libgconf-2-4
- libnss3
no errors occur after installation.
Ok I was a bit too fast.
After installing the libaries no errors occur, but after rebooting the PiZeroW this happens:
pi@magicmirror:~ $ npm start npm ERR! Linux 4.9.35+ npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start" npm ERR! node v4.2.1 npm ERR! npm v2.14.7 npm ERR! path /home/pi/package.json npm ERR! code ENOENT npm ERR! errno -2 npm ERR! syscall open npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json' npm ERR! enoent This is most likely not a problem with npm itself npm ERR! enoent and is related to npm not being able to find a file. npm ERR! enoent npm ERR! Please include the following file with any support request: npm ERR! /home/pi/npm-debug.logI did not search for this in the forum yet, maybe you have a quick answer for this again.
(maybe this is easy again, but I’m not good at debuging this error output) -
@Mykle1 said in Problem after installing MM on Pi Zero W:
Are you running npm start from your MagicMirror directory?
pi@magicmirror~/MagicMirror
no I didn’t , now there are no errors. Thanks.
But now the screen is black again.
npm startworks, … hmm …is the configsample.js maybe not working with the Pi Zero ?Is there a way to test the MM with an other method ? ( I’m using Midori, like in the tutorial)
@abergy if there is a module using es6 features it could be a reason for the black screen. can you check the developer console in midori for errors?
Can I check the errorlog over the commandline somehow?
If I google the “Black screen” problem with the Pi zero W, there are a lot of questions but now solutions.
Someone said ist maybe because of the ARM6 Arch. on the Pi Zero!?Should I buy a Raspi3 to save my nerves ^^?
There is certainly less trouble with a Pi3. Installation is more direct and you don’t need any work-arounds. Your nerves are another matter. :^)
@abergy actually you can’t as the logs are related to your browser (midori)
