    Help Translating Word Clock
    66 Posts 10 Posters 53.4k Views 10 Watching
      j.e.f.f Project Sponsor Module Developer @Lange
      @Lange Here is the Danish clock assembled:
      Also, is this contextually correct for 23:45?
        j.e.f.f Project Sponsor Module Developer @kruemel
        @kruemel Thanks. I fixed this, and will be pushing an update shortly.
          j.e.f.f Project Sponsor Module Developer @Guest
          @Sean I’ve got the CJK fonts worked out. I have one question though: Should these be in vertical layout? Typically I’ve laid out the other languages in sequential rows from read left-to-right from the top row down, but it is possible to arrange these in sequential columns, read top-to-bottom from the left column to the right (or even read from right to left). Should that be the case for any of the CJK layouts?
          ? 2 Replies Last reply Reply Quote 0
          • ? Offline
            A Former User @j.e.f.f
            @j.e.f.f said in Help Translating Word Clock:
            In Korea and China, People don’t use vertical layout anymore. Left-to-Right & Top-to-Bottom is enough.
            In Japan, I think 50-50. Many books or magazines are written vertically (Top-to-Bottom & Right-to-Left). But the Horizontal layout is also used.(Left-to-Right & Top-to-Bottom)
            • ? Offline
              @j.e.f.f
              You can see also;
              https://en.wikipedia.org/wiki/Horizontal_and_vertical_writing_in_East_Asian_scripts#Usage
                @Sean Ok Here is my attempt at the Japanese formal language clock, using vertical RTL layout. How did I do?
                • ? Offline
                  @j.e.f.f
                  Great!!
                  Only one, ‘午前’, ‘午後’ is a word unit which has meaning , so it’s better not to divide ‘午’ and ‘後’. (If you have enough space).
                  If you have still enough space, I can suggest you more natural form, but it needs some space. However current view is good enough.
                    @Sean I can re-arrange this any way as necessary. So if you have a more natural translation, I’d like to include it.
                    ? J 2 Replies Last reply Reply Quote 0
                    • ? Offline
                      @j.e.f.f Current view is enough, I think. :D
                        j.e.f.f Project Sponsor Module Developer @j.e.f.f
                        @j.e.f.f OK I made the one small change to the Japanese version. Here is the Korean layout:
                        • 6
                        • 7
                        • 6 / 7
