    Help Translating Word Clock
    66 Posts 10 Posters 61.7k Views 10 Watching
      j.e.f.f Project Sponsor Module Developer @j.e.f.f
      @strawberry-3-141 As promised, here are screenshots of the layout integrated, both for the tall and wide layouts. Please let me know if it looks good
      Tall:
      Wide:
      • kruemelK
        kruemel
        09:40 would be correct:
        Es isch zwanzg vor zäni
        12:40 the same:
        Es isch zwanzg vor eis
        The rest looks fine :-)
        By the way (you dont have to change it) but usualy we say “zwänzg” not “zwanzg” ;-)
        J 1 Reply Last reply
          j.e.f.f Project Sponsor Module Developer @Lange
          @Lange Here is the Danish clock assembled:
          Also, is this contextually correct for 23:45?
            j.e.f.f Project Sponsor Module Developer @kruemel
            @kruemel Thanks. I fixed this, and will be pushing an update shortly.
              j.e.f.f Project Sponsor Module Developer @Guest
              @Sean I’ve got the CJK fonts worked out. I have one question though: Should these be in vertical layout? Typically I’ve laid out the other languages in sequential rows from read left-to-right from the top row down, but it is possible to arrange these in sequential columns, read top-to-bottom from the left column to the right (or even read from right to left). Should that be the case for any of the CJK layouts?
              ? 2 Replies Last reply
                A Former User @j.e.f.f
                @j.e.f.f said in Help Translating Word Clock:
                In Korea and China, People don’t use vertical layout anymore. Left-to-Right & Top-to-Bottom is enough.
                In Japan, I think 50-50. Many books or magazines are written vertically (Top-to-Bottom & Right-to-Left). But the Horizontal layout is also used.(Left-to-Right & Top-to-Bottom)
                  @j.e.f.f
                  You can see also;
                  https://en.wikipedia.org/wiki/Horizontal_and_vertical_writing_in_East_Asian_scripts#Usage
                    @Sean Ok Here is my attempt at the Japanese formal language clock, using vertical RTL layout. How did I do?
                    ? 1 Reply Last reply
                      @j.e.f.f
                      Great!!
                      Only one, ‘午前’, ‘午後’ is a word unit which has meaning , so it’s better not to divide ‘午’ and ‘後’. (If you have enough space).
                      If you have still enough space, I can suggest you more natural form, but it needs some space. However current view is good enough.
                        @Sean I can re-arrange this any way as necessary. So if you have a more natural translation, I’d like to include it.
                        ? J 2 Replies Last reply
                          @j.e.f.f Current view is enough, I think. :D
                            @j.e.f.f OK I made the one small change to the Japanese version. Here is the Korean layout:
                              @j.e.f.f Cool!
                                @Sean …and Chinese:
                                  @j.e.f.f good.
                                    @Sean Thanks for all your help! I just pushed the release with these three added.
                                    pjkoelemanP 1 Reply Last reply
                                    • pjkoelemanP
                                      pjkoeleman @j.e.f.f
                                      @j.e.f.f
                                      Love it with all these translations.
                                        j.e.f.f Project Sponsor Module Developer @pjkoeleman
                                        @pjkoeleman indeed! I love seeing some random language on my mirror when I glance over.
                                        I want more translations!!!
                                        • 3 / 4
