    MMM-TelegramBot : Control MM on Telegram
    47 Posts 20 Posters 27.8k Views 21 Watching
      A Former User
      MMM-TelegramBot
      TelegramBot module for MagicMirror
      Screenshot
      Feature
      • You can remote-control your MagicMirror and modules within Telegram.
      • The Bot is implemented in this module thus you don’t need to manage antoher daemon.
      • Other module developers can add their commands easily. (See the Wiki : https://github.com/eouia/MMM-TelegramBot/wiki )
      Download:
      [card:eouia/MMM-TelegramBot]
        A Former User
        How can I resize screenshot… :(
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Guest
          @Sean said in MMM-TelegramBot : Control MM on Telegram:
          Don’t! It looks great! :^)
          • K
            krisalexroberts
            I think this is one of the best modules I’ve seen in a long time - now… how do we get developers to add support?
              A Former User @krisalexroberts
              @krisalexroberts By pledging? :)
              • michael5rM
                michael5r Module Developer
                This is a great module - I’m adding Telegram support to all my modules shortly :thumbs_up:
                • L
                  lolobyte
                  Hello,
                  can somebody help me with this module?
                  here is my config.js entry including the MMM-Tools. Tools are running very well.
                                          module: 'MMM-Tools',
                                          position: 'bottom_right',
                                                  device : "RPI", // "RPI" is also available
                                                  refresh_interval_ms : 10000,
                                                  warning_interval_ms : 1000 * 60 * 5,
                                                  enable_warning : true,
                                                  warning : {
                                                          CPU_TEMPERATURE : 65,
                                                          GPU_TEMPERATURE : 65,
                                                          CPU_USAGE : 75,
                                                          STORAGE_USED_PERCENT : 80,
                                                          MEMORY_USED_PERCENT : 80
                                                  warning_text: {
                                                          CPU_TEMPERATURE : "The temperature of CPU is over %VAL%",
                                                          GPU_TEMPERATURE : "The temperature of GPU is over %VAL%",
                                                          CPU_USAGE : "The usage of CPU is over %VAL%",
                                                          STORAGE_USED_PERCENT : "The storage is used over %VAL% percent",
                                                          MEMORY_USED_PERCENT : "The memory is used over %VAL% percent",
                                          module: 'MMM-TelegramBot',
                                                  telegramAPIKey : 'xxxxxxxxxxxxxxxmy_API_keyxxxxxxxxxxxxxxxxxxxx',
                                                  allowedUser : ['my_Telegram_username without @'], // This is NOT the username of bot.
                  The logs of MM2!
                  0|mm  | [TELBOT] Error: ETELEGRAM
                  0|mm  | { ok: false,
                  0|mm  |   error_code: 400,
                  0|mm  |   description: 'Bad Request: chat_id is empty' }
                  0|mm  | ERR_RESPONSE { type: 'TEXT',
                  0|mm  |   chat_id: undefined,
                  0|mm  |   text: 'Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.' }
                  0|mm  | { ok: false,
                  0|mm  | { ok: false,
                  0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```"}}\n```',
                  0|mm  |   option:
                  0|mm  |    { disable_notification: false,
                  0|mm  |      parse_mode: 'Markdown',
                  0|mm  |      chat_id: '',
                  0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"chat_id\\":null,\\"text\\":\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\"}\\n```"}}\n```' } }
                  0|mm  | { ok: false,
                  0|mm  | { ok: false,
                  0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","chat_id":null,"text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```',
                  0|mm  |   option:
                  0|mm  |      chat_id: '',
                  0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","chat_id":null,"text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```' } }
                  0|mm  | { ok: false,
                  0|mm  | { ok: false,
                  0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```"}}\n```',
                  0|mm  |   option:
                  0|mm  |      chat_id: '',
                  0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```","option":{"disable_notification":false,"parse_mode":"Markdown","chat_id":"","text":"`ERROR`\\n```\\nBad Request: chat_id is empty\\n```\\nat\\n```\\n{\\"type\\":\\"TEXT\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\",\\"option\\":{\\"disable_notification\\":false,\\"parse_mode\\":\\"Markdown\\",\\"chat_id\\":\\"\\",\\"text\\":\\"`ERROR`\\\\n```\\\\nBad Request: chat_id is empty\\\\n```\\\\nat\\\\n```\\\\n{\\\\\\"type\\\\\\":\\\\\\"TEXT\\\\\\",\\\\\\"chat_id\\\\\\":null,\\\\\\"text\\\\\\":\\\\\\"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren.\\\\\\"}\\\\n```\\"}}\\n```"}}\n```' } }
                  0|mm  | { ok: false,
                  0|mm  |   text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```',
                  0|mm  |   option:
                  0|mm  |      chat_id: '',
                  0|mm  |      text: '`ERROR`\n```\nBad Request: chat_id is empty\n```\nat\n```\n{"type":"TEXT","text":"Ein Fehler ist aufgetreten. Bitte den Admin kontaktieren."}\n```' } }
                  0|mm  | { ok: false,
                  0|mm  | { ok: false,
                  0|mm  |   option:
                  0|mm  |      chat_id: '',
                  0|mm  | { ok: false,
                  ^C
                  and it’s never ending.
                  What is wrong?
                    A Former User @lolobyte
                    @lolobyte
                    Your telegrambot config is not completed. Read instructions of module on github
                    • L
                      lolobyte
                      Hi, i know.
                      But ongoing with step 4 is not possible because Telegranm don’t know the /commands or the /mychatid command!
                      This is the reson why i don’t have actually the adminChatId.
                        @lolobyte
                        To make things simple, Disable other modules except MMM-TelegramBot.
                        Then execute MM again. Show me which logs are displayed.
                        • L
                          lolobyte
                          OK, here the new config .js only with telegram module.
                                  units: "metric",
                          //                      module: 'MMM-Tools',
                          //                      position: 'top_right',
                          //                      config: {
                          //                              device : "RPI", // "RPI" is also available
                          //                              refresh_interval_ms : 10000,
                          //                              warning_interval_ms : 1000 * 60 * 5,
                          //                              enable_warning : true,
                          //                              warning : {
                          //                                      CPU_TEMPERATURE : 65,
                          //                                      GPU_TEMPERATURE : 65,
                          //                                      CPU_USAGE : 75,
                          //                                      STORAGE_USED_PERCENT : 80,
                          //                                      MEMORY_USED_PERCENT : 80
                          //                              warning_text: {
                          //                                      CPU_TEMPERATURE : "The temperature of CPU is over %VAL%",
                          //                                      GPU_TEMPERATURE : "The temperature of GPU is over %VAL%",
                          //                                      CPU_USAGE : "The usage of CPU is over %VAL%",
                          //                                      STORAGE_USED_PERCENT : "The storage is used over %VAL% percent",
                          //                                      MEMORY_USED_PERCENT : "The memory is used over %VAL% percent",
                          and here the log data.
                          pi@raspi-MM2:~ $ pm2 logs mm
                          [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                          /home/pi/.pm2/logs/mm-error.log last 15 lines:
                          0|mm       |     at Request.emit (events.js:214:7)
                          0|mm       |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-iCloud-Client/node_modules/request/request.js:1161:10          )
                          0|mm       |     at emitOne (events.js:116:13)
                          0|mm       |     at Request.emit (events.js:211:7)
                          0|mm       |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-iCloud-Client/node_modules/request/request.js          :1083:12)
                          0|mm       |     at Object.onceWrapper (events.js:313:30)
                          0|mm       | TypeError: PythonShell is not a constructor
                          0|mm       |     at Class.loadDataFromAPI (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:216:17)
                          0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:69:          9)
                          0|mm       |     at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                          0|mm       |     at emitTwo (events.js:126:13)
                          0|mm       |     at Socket.emit (events.js:214:7)
                          0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                          0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
                          0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
                          /home/pi/.pm2/logs/mm-out.log last 15 lines:
                          0|mm       | starting network connection testing
                          0|mm       | Serving iCal
                          0|mm       | Serving iCal
                          0|mm       |
                          0|mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
                          0|mm       | > sh run-start.sh
                          0|mm       |
                          0|mm  | Starting MagicMirror: v2.6.0
                          0|mm  | Loading config ...
                          0|mm  | Loading module helpers ...
                          0|mm  | Initializing new module helper ...
                          0|mm  | Module helper loaded: MMM-TelegramBot
                          0|mm  | All module helpers loaded.
                          0|mm  | Starting server on port 8080 ...
                          0|mm  | Server started ...
                          0|mm  | Connecting socket for: MMM-TelegramBot
                          0|mm  | Sockets connected & modules started ...
                          0|mm  | Launching application.
                          the /commands or the /mychatid command doesn’t work.
                          second time restartin MM2
                          0|mm       |         _started: true,
                          0|mm       |         href: 'https://api.telegram.org/bot%3C718051157:AAFqI9VPBUE5W0FTYeZi770CWaq9mLYEBEQ%3E/getUpdates',
                          0|mm       |         req: [Object],
                          0|mm       |         ntick: true,
                          0|mm       |         response: [Circular],
                          0|mm       |         originalHost: 'api.telegram.org',
                          0|mm       |         originalHostHeaderName: 'host',
                          0|mm       |         responseContent: [Circular],
                          0|mm       |         _destdata: true,
                          0|mm       |         _ended: true,
                          0|mm       |         _callbackCalled: true },
                          0|mm       |      toJSON: [Function: responseToJSON],
                          0|mm       |      caseless: Caseless { dict: [Object] },
                          0|mm       |      read: [Function],
                          0|mm       |      body: { ok: false, error_code: 404, description: 'Not Found' } } }
                            @lolobyte More error logs are needed. your mm-error.log is showing just last 15 lines.
                            If your file is too long, send me via email : eouia0819@gmail.com.
                            And If you don’t mind, send me your TelegramAPIKey also. (You can make new thing after my researching)
                            • L
                              lolobyte
                              I searche’d the log files and has found this 2:
                              mm-error.log is empty
                              mm-out.log
                              > sh run-start.sh
                              Loading config ...
                              Server started ...
                              Shutting down server...
                              Stopping module helper: MMM-TelegramBot
                              > sh run-start.sh
                              Loading config ...
                              Server started ...
                                @lolobyte
                                Well,
                                mm-out.log
                                It means there’s no error in module on installation phase or running phase.
                                So I have to represent your issue but it might be related your account specific. So I need your TelegramBotAPI Key to represent your issue. Without it, I can help you only limitedly.
                                • T
                                  teitlebot
                                  @Sean
                                  Is it possible to use this module to display on my mirror every time a specific telegram person posts a message? not me. another account.
                                    A Former User @teitlebot
                                    @teitlebot
                                    no, it’s just a bot for interacting in a soecific chat room. not telegram monitor.
                                      A Former User
                                      New Update
                                      [1.0.1] : 2019-09-10
                                      • Added: useWelcomeMessage and verbose
                                        A Former User
                                        New Updates
                                        [1.1.0] 2020-02-27
                                        • added: new commands
                                          • /recent : load telegram keyboard for recent used commands
                                          • /favor : load telegram keyboard for favorite commands
                                          • /shell : execute shell script or shell command (e.g: /shell echo hello world)
                                          • /notification : emit MagicMirror notification (e.g: /notification SHOW_ALERT {"title":"test", "timer":1000})
                                          • /screenshot : take a screenshot of MagicMirror
                                          I will remove screenshot feature from MMM-Tools on next updates at near future, so use this instead.
                                        • added: new features
                                          • custom command by user available.
                                          • abbreviation of command available (e.g: You can use just /noti or /n instead of full /notification)
                                          • detail option of telegramBot constructor(API) available. (e.g: proxy setting) - experimental
                                        • changed: kinder logging message.
                                        • changed: parse_mode:"MarkdownV2" is supported.(natively by API)
                                        • Some translate files are not completed. Please PR for others.
                                        B 1 Reply Last reply Reply Quote 2
                                          A Former User
                                          New Updates
                                          [1.2.0] 2020-03-13
                                          • Added: Telecast. Now you can telecast your chat or message on MagicMirror screen. (Read the wiki)
                                          • Changed: position is needed for telecast (You need to re-configure)
                                          • P
                                            polzy
                                            really good !
                                            Works great. But, just a question, I have a Telegram’s group with another bot and the messages in this bot are not in my MM.
                                            it’s normal ?
                                            Best regards.
                                            • 1 / 3
