    MMM-TelegramBot : Control MM on Telegram
    47 Posts 20 Posters 24.4k Views 21 Watching
    • ? Offline
      A Former User @polzy
      @polzy
      normal. bots in telegram cannot converse with each other. It cannot be caught.
        Mrtrol2013
        I can not get my chat id
        thymonT 1 Reply Last reply Reply Quote 0
        • thymonT Offline
          thymon @Mrtrol2013
          This post is deleted!
            DinoDog
            hi
            When i use /alert, i see the message on my MM, but /telecast don’t show any on my MM
            How can i found, whats the error?
            The IDs are all correct
            B R 2 Replies Last reply Reply Quote 0
            • K Offline
              kontranik
              can a bot send a notification to other module when a message recived?
              • ? Offline
                A Former User
                sure if you code it in a module
                • ? Offline
                  A Former User
                  TelegramBot in now on v1.3.3
                  it can now display stickers, Gifs, play official telegram notification sound on message received
                    bryan_1 @Guest
                    @Sean Hi, is it possible to save some shown modules as default with Telegram, when magic mirror restarted?
                    • ? Offline
                      A Former User
                      @bryan_1 said in MMM-TelegramBot : Control MM on Telegram:
                      why @Sean this question ? He stops developing
                      It’s me now
                      after if you want a @Sean response it’s not a problem :)
                        bryan_1 @Guest
                        @Bugsounet Oh, sorry for that, I don’t know it. I’ll be glad to hear your response.
                        • K Offline
                          krisalexroberts
                          I’ve tried linking IFTTT with TelegramBot in a group chat, before learning bots cannot converse, which is annoying.
                          Can I control telecast with an API or outside of telegram, then I can use IFTTT Webhooks?
                            Bronno @DinoDog
                            @DinoDog Did you know the solution? I have the same problem…
                              robiv8 @DinoDog
                              @DinoDog said in MMM-TelegramBot : Control MM on Telegram:
                              hi
                              Hallo,
                              any help is welcome.
                              I have the same problem. Any codes and numbers are correct.
                              No error in logs.
                              /alert is coming and displayed
                              but when I send a message like TEST123 nothing happens?
                              The Modul is on top_left~~
                              So now I understand! This is only with telecast possible!
                              • ? Offline
                                A Former User
                                  robiv8
                                  Yes! You are right :-)
                                  by the way, is it possible to clear the chat
                                  or to delete a message
                                  or to delete the message after a while -> telecastLife OK
                                  so that when you have sent a few messages you can delete them so that this don’t stand there forever.
                                  and
                                  Videos are not going?
                                  Robert
                                  • ? Offline
                                    A Former User
                                    And …
                                    The ReadMe file says:
                                    New Updates
                                    **[1.3.7] 2020-09-11
                                    • add TelegramBot Service (catch all Errors of Telegram)
                                    [1.3.5-1.3.6] 2020-09-08
                                    • add telecast directly on allowedUser
                                    • add emojis (@eouia purpose)
                                    • add telecastContainer feature
                                    • add Play audio on received audio file
                                    • add Video play… (if codec is there…)
                                    • add Voice audio ! @MIRCO
                                    [1.3.4] 2020-09-07
                                    • add /clean command for clean telecast screen
                                    • update fr translations
                                    • add dateFormat feature
                                    [1.3.3] 2020-09-05
                                    • Add stickers support (not animated)
                                    • Add gifs support
                                    • Add native default sound on message received
                                    Just little part of the file…
                                      robiv8
                                      :man_facepalming_light_skin_tone:
                                      Thank you!
                                      Send a video from iPhone is not display! are you now what kind of codec are necessary
                                      • ? Offline
                                        A Former User
                                        Need some modification in MagicMirror Core but i think send a video file for playing is actually optional, video cast is better
                                          robiv8
                                            alex1258
                                            • 2 / 3
