    Annother IPWhitelist question
    12 Posts 4 Posters 6.6k Views 4 Watching
    • P Offline
      psteimann
      hi.
      whats the string to get all ip-ranges (internal and external) access to MM2?
      as documented
      MM2 stays black and there is also no access via http
      anybody can explain exactly the parameters of the string?
      tnx
        Mykle1 Project Sponsor Module Developer @psteimann
        @psteimann
        I think they have some sort of workaround in this topic
        https://forum.magicmirror.builders/topic/4716/issue-with-white-list-ip-s-not-working/13
        I just upgraded to MM 2.1.2 and my Whitelist went on extended vacation. :-(
          roramirez Core Contributors @Mykle1
          @Mykle1 What configuration for your ipWhiteList have it?
          Easy module development with MagicMirror Module Template
            Mykle1 Project Sponsor Module Developer @roramirez
            @roramirez
            In v2.1.1.
            var config = {
            	port: 8080,
            	ipWhitelist: [], // Set [] to allow all IP addresses.
            I tried this in v 2.1.2 and it crashed the mirror
              @Mykle1 said in Annother IPWhitelist question:
              Can you provider more information of the crash…?
                @roramirez said in Annother IPWhitelist question:
                No, because I was unable to get out of the mirror to look at the console or the terminal. I had to power down the mirror and reboot. I deleted the install of 2.1.2 and moved back to v 2.1.1
                  See https://forum.magicmirror.builders/post/27658
                  • P Offline
                    psteimann @Mykle1
                    @Mykle1 @roramirez
                    Exactly the same issue and behaviour here…
                      B3nihana
                      When I use
                      ipWhitelist: [],
                      Any IP I use shows as blocked. I’m using an RPi 2 with “node serveronly”.
                        roramirez Core Contributors @B3nihana
                        @B3nihana Please, use a develop branch or apply the patch https://github.com/MichMich/MagicMirror/commit/a7297d2685f5ed9b6b34df496065f05ee0d36568#diff-9d4f93dd73c92e4e5730a5c2e0146ad4L33
