Annother IPWhitelist question
12 Posts 4 Posters 6.4k Views 4 Watching
    psteimann
    hi.
    whats the string to get all ip-ranges (internal and external) access to MM2?
    as documented
    MM2 stays black and there is also no access via http
    anybody can explain exactly the parameters of the string?
    tnx
    M 1 Reply Last reply Sep 4, 2017, 12:22 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @psteimann
      @psteimann
      I think they have some sort of workaround in this topic
      https://forum.magicmirror.builders/topic/4716/issue-with-white-list-ip-s-not-working/13
      I just upgraded to MM 2.1.2 and my Whitelist went on extended vacation. :-(
      R 1 Reply Last reply Sep 5, 2017, 1:04 AM Reply Quote 0
        roramirez Core Contributors @Mykle1
        @Mykle1 What configuration for your ipWhiteList have it?
        M 1 Reply Last reply Sep 5, 2017, 1:07 AM Reply Quote 0
          Mykle1 Project Sponsor Module Developer @roramirez
          @roramirez
          In v2.1.1.
          var config = {
          	port: 8080,
          	ipWhitelist: [], // Set [] to allow all IP addresses.
          I tried this in v 2.1.2 and it crashed the mirror
          R 1 Reply Last reply Sep 5, 2017, 1:09 AM Reply Quote 0
            @Mykle1 said in Annother IPWhitelist question:
            Can you provider more information of the crash…?
            M 1 Reply Last reply Sep 5, 2017, 1:11 AM Reply Quote 0
              @roramirez said in Annother IPWhitelist question:
              No, because I was unable to get out of the mirror to look at the console or the terminal. I had to power down the mirror and reboot. I deleted the install of 2.1.2 and moved back to v 2.1.1
              P 1 Reply Last reply Sep 5, 2017, 8:44 AM Reply Quote 0
                See https://forum.magicmirror.builders/post/27658
                  psteimann @Mykle1
                  @Mykle1 @roramirez
                  Exactly the same issue and behaviour here…
                    B3nihana
                    When I use
                    ipWhitelist: [],
                    Any IP I use shows as blocked. I’m using an RPi 2 with “node serveronly”.
                    R 1 Reply Last reply Sep 5, 2017, 2:50 PM Reply Quote 0
                      roramirez Core Contributors @B3nihana
                      @B3nihana Please, use a develop branch or apply the patch https://github.com/MichMich/MagicMirror/commit/a7297d2685f5ed9b6b34df496065f05ee0d36568#diff-9d4f93dd73c92e4e5730a5c2e0146ad4L33
                      P 1 Reply Last reply Sep 5, 2017, 5:55 PM Reply Quote 1
