Navigation
    • Search
    MagicMirror² v2.15.0 is available! For more information about this release, check out this topic.
    My config.js file is messed up. someone want to help? :P
    Troubleshooting
    • K
      KMH0 last edited by yawns
      var config = {
              port: 8080,
              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
              language: 'en',
              timeFormat: 24,
              units: 'metric',
                              module: 'alert',
                              module: "updatenotification",
                              position: "top_bar"
                              module: 'clock',
                              position: 'top_left'
                              module: 'calendar',
                              header: 'US Holidays',
                              position: 'top_left',
                                                      symbol: 'calendar-check-o ',
                                                      url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
                               module: 'MMM-SoccerLiveScore',
                               header: 'Live-Scores',
                               leagues: [17, 17, 17],
                               showNames: true,
                               showLogos: true,
                               displayTime: 60 * 1000,
                               showTables: true
                               module: 'MMM-Globe',
                               position: 'center',
                               style: 'europeDiscNat',
                               imageSize: 600,
                               ownImagePath:'',                         updateInterval: 10*60*1000
                               module: 'helloworld',
                               position: 'bottom_right', // This can be any of the regions.
        // See 'Configuration options' for$
                               text: 'MIA by Karl M. Holst'
                              module: 'MMM-Carousel',
                              transitionInterval: 30000,
                              ignoreModules: ['clock', 'alert', 'currentweather'],
                              mode: 'slides',
                              slides: [
                                      ['calendar', 'MMM-Globe', 'weatherforecast', 'helloworld'],
                                      ['weatherforecast', 'MMM-Globe', 'MMM-SoccerLiveScore', 'helloworld'],
                                      ['MMM-iHaveBeenThere']
                              module: 'MMM-ethereum',
                              position: 'top_right',
                              updateInterval: 30000,
                              exchange: "bitfinex"
      schlachtkreuzer6 1 Reply Last reply Reply Quote 0
      • schlachtkreuzer6
        schlachtkreuzer6 @KMH0 last edited by schlachtkreuzer6
        @KMH0 check for missing { } one is missing @ soccer live score
                             showNames: true,
                             showLogos: true,
                             showTables: true
        • strawberry 3.141
          strawberry 3.141 Project Sponsor Module Developer last edited by strawberry 3.141
          same problem for the carousel module
          • lavolp3
            lavolp3 Module Developer last edited by
            Hi KMHO,
            1. you have some missing indentations (how are these things called in english again??) making it hard to read. It’s advisable always to make the right indentations.
              Also, you didn’t include the whole config in code tags. Making it also harder to read.
            2. a good way to check your config is running
            npm run config:check
            from the MagicMirror folder. This gives you the lines of the errors and the errors in the config.
            You can then run e.g.
            sudo nano -c config/config.js
            The -c gives you the line numbers in nano.
            Always only check and correct the FIRST error shown.
            Then run the config:check again.
            The successive errors can easily be errors resulting from the first one.
            • yawns
              yawns Moderator last edited by
              var config = {
                      port: 8080,
                      language: 'en',
                      timeFormat: 24,
                      units: 'metric',
                                      module: 'alert',
                                      position: "top_bar"
                                      module: 'clock',
                                      module: 'calendar',
              								showNames: true,
              								showLogos: true,
              								showTables: true
                                       position: 'center',
              								imageSize: 600,
              								ownImagePath:'',
              								mode: 'slides',
              								slides: [
