    Parse HTML String
    7 Posts 5 Posters 6.2k Views 5 Watching
      alihallo
      Currently I try to create my first little module and could need a hint from an experienced person.
      In my node_helper.js I request the html code from an simple website by using:
      var options = {url: URL};
              request(options, (error, response, body) => {
                  if (response.statusCode === 200) {
                      this.sendSocketNotification("DATA", this.parseData(body));
      So in the variable body there is something like
      <head>
      </head>
      <body><a name="top"></a>
         <div id="data_1">
            <p>The relevant data 1</p>
         </div>
         <div id="data_2">
            <p>The relevant data 2</p>
         </div>
      My question is: What would you recommend to get the relevant data from this body into an local variable?
      I first thought to use javascript & regex, but I guess that is not a good way to solve the issue, isn’t it?
      Best regards,
      alihallo
      • cowboysdudeC Offline
        cowboysdude Module Developer
        I could be wrong but I believe you could request it using NPM request…
          alihallo
          Thank you for your answer, but I coudn’t find out how to use the NPM request to parse the html code.
          But I found another solution to solve the issue:
          https://github.com/cheeriojs/cheerio
          This way I could get the data out of the html code like this:
          var $ = cheerio.load(body, {
             normalizeWhitespace: true,
             xmlMode: false
          $('div[class=data_1]').find('p').each(function (index, element) {
          	data_array.push($(element).text());
          This way I could solve my problem.
          Best regards,
          alihallo
          • strawberry 3.141S Offline
            I think it’s weird that this works, because your looking for attribute class = data_1 but it’s an id
            the css selector for an id is #, and when you put p behind it will look for paragraphs in the element with the id data_1
            when you replace
            with
            data_array.push($('#data_1 p').text());
            does it still work? Not sure if it will return the element if just one occurance is found or will return an array anyways
            • I Offline
              ianperrin @alihallo
              @alihallo
              If your input html file is fairly simple, you may be able to avoid the use of the cheerio library entirely
              // an array to hold the data from the file
              var data_array = [];
              // Get all p tag elements inside div tag elements with an id that starts with 'data_'
              var data_tags = body.querySelectorAll('div[id^=data_] p');
              // Loop through data tags and add content to data array
              for (i = 0; i < data_tags.length; i++) {
                  data_array.push(data_tags[i].innerHTML);
              Of course the more complex your input file is the more you might benefit from the use of cheerio.
              “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
              • P Offline
                Plati
                I want to create a module that gets data from a website in div id.
                Example:
                Website code:
                <b class="b2 nieb" title="Kurs EUR na żywo" id="EURPLN">4.33320</b>
                And i want display value of id="EURPLN"
                I want to set the config which site is to collect data and from which the ID
                example:
                defaults: {
                		url: http://domain.com/
                		findID: "EURPLN"
                how to do it?
                Note from admin: Please use Markdown on code snippets!
                  alihallo
                  @strawberry-3-141 You are absolutly right, I made a bad example. The real html code is a little bit more complicated, so I mixed the real code with this example.
                  @ianperrin My input html is more complicated, but thanks for your answer, good to know!
                  @Plati It helped me a lot to look at other modules. You should use a node_helper.js, there you can create a function which gets the html code of the website.
                  //function which gets the data from the given URL
                  getTheData: function(theURLtoCatch) {
                     var options = {url: theURLtoCatch};
                           this.sendSocketNotification("DATA", this.parseHTML(body));
                        } else {
                           console.log("Error getting Data " + response.statusCode);
                           this.sendSocketNotification("ERROR", response.statusCode);
                  parseHTML: function(dataBody) {
                     //use something like ianperrin and strawberry showed in his example
