    Can not start MM anymore
    2 Posts 2 Posters 1.3k Views 2 Watching
      bd5hty
      pi@raspberrypi:~/MagicMirror$ npm start
      > magicmirror@2.1.3 start /home/pi/MagicMirror
      > sh run-start.sh
      /home/pi/MagicMirror/node_modules/electron/index.js:9
        throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
          at Module._compile (module.js:570:32)
          at Object.Module._extensions..js (module.js:579:10)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
          at Module.require (module.js:497:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
      npm ERR! Linux 4.9.41-v7+
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
      npm ERR! node v6.11.4
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.1.3 start: `sh run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      tks!
        Mykle1 Project Sponsor Module Developer @bd5hty
        @bd5hty said in Can not start MM anymore:
        Your answer is right there in the error message. Delete the electron folder from inside the node_modules folder. Then run npm install in the MagicMirror directory
