    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 369.4k Views 65 Watching
    • G Offline
      ganther
      Hi there,
      i followed the instructions, my calendars are shown in discovery.
      I copied the UUID and it starts syncing, but the saved files are 0kb.
      I tried several calendars and checked the UUID’s but can’t find any mistake?
      any ideas?
      thanks!!
      • G Offline
        Gailby @Beh
        @Beh Everything works fine until I’ll try to save the config file:
        1. ~/.vdirsyncer/config directory cannot be found
        2. Once I manuals create directories I also save config file as config.cfg and also tried config.config and save
        3. I haven’t filled in collections = [“HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC”] in conf. Could this make it crash?
        4. Running curl for timer ok.
          5.Then when vdirsyncer discover nothing happens I get Errno 21 and that’s where I get stuck…
        Really wonder what might be the issues here?
        • G Offline
          ganther @Gailby
          @Gailby
          The file is named config. It‘s not a directory, it‘s the name of the file. (No ending).
          • G Offline
            Gailby @ganther
            @ganther so if I put config in ~/.vdirsyncer/config it should work?
            I think I did try it but somehow wansn’t able to read it as a file nor save and getting empty file and no result forward…
            • G Offline
              ganther @Gailby
              @Gailby
              Yes. Just type these commands as given:
              touch ~/.vdirsyncer/config
              nano ~/.vdirsyncer/config
              • schwoediauerS Offline
                schwoediauer @l0cal
                @l0cal Hi !
                I’m also interrested on this solution to display reminders on this way, but It dosen’t work actually for me.
                Do you have a running configuration
                  maestro82
                  Two run two calendars, would I need to adjust config.js file as well?
                  • G Offline
                    Gailby @Beh
                    @Beh I had no problem adding several modules of same kind and several .ics files in Calendars…however it doesn’t seem to sync or retrieve anything…only says no upcomming events :/
                    • G Offline
                      ganther @Gailby
                      @Gailby
                      Is your ics-file in modules/calendars also 0kb?
                      • G Offline
                        Gailby @ganther
                        @ganther I don’t know…I need to check
                        • 6
                        • 16
                        • 17
                        • 4 / 17
